I’m trying to motion control my hall lights. I started out using an if with the motion detect, with a timer and the off state all in the same execution section, on the basis that repeated motion would re-trigger and break out of the wait, as it felt like an efficient way of doing it.
That didn’t work properly, so I copied the favoured method of triggering on active motion, and then separately watching for a period of inactivity & switching off.
I’ve still clearly not got to grips with the execution & cancellation behaviour of WebCore, as it behaves erratically - the lights always come on, but don’t always go off.
lights go off after 10 mins
works mostly, but not always, it seems to be “white bulb 9” that fails to switch off.
+1ms ╔Received event [Dining Room Sensor].motion = active with a delay of 59ms
+105ms ║RunTime Analysis CS > 16ms > PS > 29ms > PE > 60ms > CE
+107ms ║Runtime (39837 bytes) successfully initialized in 29ms (v0.3.110.20191009) (105ms)
+108ms ║╔Execution stage started
+123ms ║║Comparison (enum) active is (string) active = true (1ms)
+125ms ║║Condition #2 evaluated true (12ms)
+134ms ║║Comparison (integer) 1 is_less_than_or_equal_to (integer) 5 = true (1ms)
+135ms ║║Condition #3 evaluated true (9ms)
+136ms ║║Condition group #1 evaluated true (state did not change) (24ms)
+144ms ║║Comparison (integer) 23 is_inside_of_range (integer) 16 .. (integer) 22 = false (1ms)
+145ms ║║Condition #5 evaluated false (6ms)
+147ms ║║Condition group #4 evaluated false (state did not change) (8ms)
+149ms ║║Cancelling statement #6's schedules...
+156ms ║║Skipped execution of physical command [Hall 9].on([]) because it would make no change to the device. (4ms)
+157ms ║║Executed [Hall 9].on (6ms)
+173ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+176ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+178ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+180ms ║║Cancelling any timed trigger schedules for condition 15
+181ms ║║Cancelling statement #15's schedules...
+182ms ║║Condition #15 evaluated false (21ms)
+183ms ║║Condition group #14 evaluated false (state did not change) (23ms)
+185ms ║╚Execution stage complete. (77ms)
+186ms ╚Event processed successfully (186ms)
30/11/2020, 23:10:48 +874ms
+1ms ╔Received event [LGF Sensor].motion = inactive with a delay of 55ms
+93ms ║RunTime Analysis CS > 16ms > PS > 27ms > PE > 49ms > CE
+95ms ║Runtime (39828 bytes) successfully initialized in 27ms (v0.3.110.20191009) (93ms)
+113ms ║║Comparison (enum) active is (string) active = true (2ms)
+115ms ║║Condition #2 evaluated true (14ms)
+122ms ║║Comparison (integer) 1 is_less_than_or_equal_to (integer) 5 = true (1ms)
+124ms ║║Condition #3 evaluated true (8ms)
+125ms ║║Condition group #1 evaluated true (state did not change) (25ms)
+132ms ║║Comparison (integer) 23 is_inside_of_range (integer) 16 .. (integer) 22 = false (2ms)
+134ms ║║Condition #5 evaluated false (7ms)
+135ms ║║Condition group #4 evaluated false (state did not change) (8ms)
+138ms ║║Cancelling statement #6's schedules...
+145ms ║║Skipped execution of physical command [Hall 9].on([]) because it would make no change to the device. (4ms)
+146ms ║║Executed [Hall 9].on (6ms)
+160ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+163ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+165ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+167ms ║║Cancelling any timed trigger schedules for condition 15
+168ms ║║Cancelling statement #15's schedules...
+169ms ║║Condition #15 evaluated false (20ms)
+171ms ║║Condition group #14 evaluated false (state did not change) (21ms)
+172ms ║╚Execution stage complete. (76ms)
+174ms ╚Event processed successfully (173ms)
30/11/2020, 23:10:28 +737ms
+1ms ╔Received event [LGF Sensor].motion = active with a delay of 60ms
+90ms ║RunTime Analysis CS > 15ms > PS > 27ms > PE > 48ms > CE
+93ms ║Runtime (39828 bytes) successfully initialized in 27ms (v0.3.110.20191009) (90ms)
+109ms ║║Comparison (enum) active is (string) active = true (1ms)
+111ms ║║Condition #2 evaluated true (13ms)
+118ms ║║Comparison (integer) 1 is_less_than_or_equal_to (integer) 5 = true (1ms)
+119ms ║║Condition #3 evaluated true (7ms)
+120ms ║║Condition group #1 evaluated true (state did not change) (23ms)
+127ms ║║Comparison (integer) 23 is_inside_of_range (integer) 16 .. (integer) 22 = false (2ms)
+129ms ║║Condition #5 evaluated false (7ms)
+130ms ║║Condition group #4 evaluated false (state did not change) (8ms)
+132ms ║║Cancelling statement #6's schedules...
+139ms ║║Skipped execution of physical command [Hall 9].on([]) because it would make no change to the device. (4ms)
+140ms ║║Executed [Hall 9].on (6ms)
+154ms ║║Comparison (enum) active stays (string) inactive = false (2ms)
+156ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+158ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+161ms ║║Cancelling any timed trigger schedules for condition 15
+162ms ║║Cancelling statement #15's schedules...
+162ms ║║Condition #15 evaluated false (19ms)
+163ms ║║Condition group #14 evaluated false (state did not change) (20ms)
+165ms ║╚Execution stage complete. (72ms)
+166ms ╚Event processed successfully (166ms)
30/11/2020, 23:09:26 +930ms
+1ms ╔Received event [LGF Sensor].motion = inactive with a delay of 74ms
+112ms ║RunTime Analysis CS > 20ms > PS > 39ms > PE > 54ms > CE
+115ms ║Runtime (39829 bytes) successfully initialized in 39ms (v0.3.110.20191009) (113ms)
+116ms ║╔Execution stage started
+133ms ║║Comparison (enum) active is (string) active = true (1ms)
+135ms ║║Condition #2 evaluated true (14ms)
+142ms ║║Comparison (integer) 1 is_less_than_or_equal_to (integer) 5 = true (1ms)
+144ms ║║Condition #3 evaluated true (7ms)
+145ms ║║Condition group #1 evaluated true (state did not change) (24ms)
+152ms ║║Comparison (integer) 23 is_inside_of_range (integer) 16 .. (integer) 22 = false (1ms)
+153ms ║║Condition #5 evaluated false (6ms)
+154ms ║║Condition group #4 evaluated false (state did not change) (7ms)
+157ms ║║Cancelling statement #6's schedules...
+166ms ║║Skipped execution of physical command [Hall 9].on([]) because it would make no change to the device. (5ms)
+167ms ║║Executed [Hall 9].on (7ms)
+182ms ║║Comparison (enum) active stays (string) inactive = false (1ms)
+185ms ║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+187ms ║║Comparison (enum) inactive stays (string) inactive = true (2ms)
+190ms ║║Cancelling any timed trigger schedules for condition 15
+191ms ║║Cancelling statement #15's schedules...
+192ms ║║Condition #15 evaluated false (22ms)
+193ms ║║Condition group #14 evaluated false (state did not change) (23ms)
+195ms ║╚Execution stage complete. (79ms)
+197ms ╚Event processed successfully (196ms)
