My piston is sending multilple notifications when we leave. Today it sent “Jane has left the Building” then again “Jane has left the building” then it sent "Jane and Jane has left the building. It seems to be duplicating. Here are the logs…
1/30/2018, 8:58:22 AM +341ms
+0ms ╔Received event [Home].time = 1517320703779 with a delay of -1439ms
+209ms ║RunTime Analysis CS > 48ms > PS > 36ms > PE > 125ms > CE
+212ms ║Runtime (64290 bytes) successfully initialized in 36ms (v0.2.102.20180116) (211ms)
+213ms ║╔Execution stage started
+225ms ║║Calculating (datetime) 1517320702563 - (datetime) 1517320673779 >> (datetime) 28784
+230ms ║║Comparison (datetime) 28784 is_greater_than (integer) 300000 = false (2ms)
+231ms ║║Condition #27 evaluated false (11ms)
+232ms ║║Condition group #24 evaluated false (state did not change) (12ms)
+255ms ║║Condition #56 evaluated false (17ms)
+256ms ║║Condition group #55 evaluated false (state did not change) (17ms)
+257ms ║║Condition group #11 evaluated false (state did not change) (19ms)
+267ms ║║Comparison (time) 32302601 happens_daily_at (datetime) 1517320673779 = true (5ms)
+268ms ║║Time restriction check passed
+270ms ║║Cancelling condition #49’s schedules…
+270ms ║║Condition #49 evaluated true (11ms)
+279ms ║║Cancelling statement #49’s schedules…
+283ms ║║Requesting time schedule wake up at Wed, Jan 31 2018 @ 8:58:23 AM EST
+296ms ║║Comparison (boolean) true is (boolean) false = false (2ms)
+297ms ║║Cancelling condition #48’s schedules…
+298ms ║║Condition #48 evaluated false (12ms)
+299ms ║║Condition group #38 evaluated false (state did not change) (40ms)
+306ms ║║Comparison (integer) 0 is_greater_than (integer) 0 = false (2ms)
+307ms ║║Cancelling condition #65’s schedules…
+308ms ║║Condition #65 evaluated false (6ms)
+309ms ║║Cancelling condition #61’s schedules…
+310ms ║║Condition group #61 evaluated false (state changed) (8ms)
+313ms ║╚Execution stage complete. (100ms)
+314ms ║Setting up scheduled job for Wed, Jan 31 2018 @ 8:58:23 AM EST (in 86401.124s)
+322ms ╚Event processed successfully (323ms)
1/30/2018, 8:58:06 AM +709ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+211ms ║RunTime Analysis CS > 23ms > PS > 48ms > PE > 141ms > CE
+215ms ║Runtime (64294 bytes) successfully initialized in 48ms (v0.2.102.20180116) (214ms)
+216ms ║╔Execution stage started
+217ms ║╚Execution stage complete. (2ms)
+219ms ║Setting up scheduled job for Tue, Jan 30 2018 @ 8:58:23 AM EST (in 16.852s)
+229ms ╚Event processed successfully (229ms)
1/30/2018, 8:57:59 AM +198ms
+203ms ║RunTime Analysis CS > 17ms > PS > 52ms > PE > 135ms > CE
+207ms ║Runtime (64302 bytes) successfully initialized in 52ms (v0.2.102.20180116) (206ms)
+208ms ║╔Execution stage started
+259ms ║║Cancelling statement #76’s schedules…
+266ms ║║Executed virtual command setVariable (5ms)
+273ms ║║Executed virtual command setVariable (4ms)
+277ms ║╚Execution stage complete. (68ms)
+279ms ║Setting up scheduled job for Tue, Jan 30 2018 @ 8:58:23 AM EST (in 24.303s)
+289ms ╚Event processed successfully (288ms)
1/30/2018, 8:57:53 AM +462ms
+1ms ╔Received event [Jane].presence = not present with a delay of 146ms
+205ms ║RunTime Analysis CS > 18ms > PS > 58ms > PE > 129ms > CE
+208ms ║Runtime (64230 bytes) successfully initialized in 58ms (v0.2.102.20180116) (206ms)
+210ms ║╔Execution stage started
+222ms ║║Calculating (datetime) 1517320673680 - (datetime) 1517320638815 >> (datetime) 34865
+227ms ║║Comparison (datetime) 34865 is_greater_than (integer) 300000 = false (2ms)
+228ms ║║Condition #27 evaluated false (12ms)
+229ms ║║Condition group #24 evaluated false (state did not change) (13ms)
+237ms ║║Cancelling statement #3’s schedules…
+250ms ║║Executed virtual command setVariable (4ms)
+266ms ║║Calculating (integer) 3 - (integer) 1 >> (integer) 2
+269ms ║║Comparison (integer) 0 is_inside_of_range (integer) 0 … (integer) 2 = true (2ms)
+271ms ║║Condition #8 evaluated true (18ms)
+272ms ║║Condition group #2 evaluated true (state did not change) (19ms)
+275ms ║║Cancelling statement #34’s schedules…
+283ms ║║Calculating (dynamic) not present == (dynamic) present >> (boolean) false
+289ms ║║Executed virtual command setVariable (3ms)
+307ms ║║Calculating (string) Jane + (string) , >> (string) Jane,
+310ms ║║Calculating (string) Jane, + (string) Jane >> (string) Jane, Jane
+316ms ║║Executed virtual command setVariable (4ms)
+322ms ║║Executed virtual command setVariable (3ms)
+342ms ║║Comparison (enum) not present changes_to (string) present = false (0ms)
+344ms ║║Condition #56 evaluated false (17ms)
+345ms ║║Condition group #55 evaluated false (state did not change) (18ms)
+346ms ║║Condition group #11 evaluated false (state did not change) (19ms)
+352ms ║║Comparison (time) 32273811 happens_daily_at (datetime) 1517320673779 = false (0ms)
+354ms ║║Cancelling condition #49’s schedules…
+355ms ║║Condition #49 evaluated false (6ms)
+356ms ║║Cancelling statement #49’s schedules…
+360ms ║║Requesting time schedule wake up at Tue, Jan 30 2018 @ 8:58:23 AM EST
+362ms ║║Cancelling condition #38’s schedules…
+363ms ║║Condition group #38 evaluated false (state changed) (15ms)
+371ms ║║Comparison (integer) 2 is_greater_than (integer) 0 = true (1ms)
+372ms ║║Condition #65 evaluated true (6ms)
+373ms ║║Condition group #61 evaluated true (state did not change) (7ms)
+375ms ║║Cancelling statement #52’s schedules…
+389ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+589ms ║║Calculating (integer) 10 - (integer) 4 >> (integer) 6
+592ms ║║Calculating (integer) 6 - (integer) 2 >> (integer) 4
+599ms ║║Calculating (string) Jane + (string) and >> (string) Jane and
+603ms ║║Calculating (string) Jane and + (string) Jane >> (string) Jane and Jane
+607ms ║║Calculating (integer) 4 > (integer) 0 >> (boolean) true
+613ms ║║Executed virtual command [Kitchen Sonos].setVariable (4ms)
+633ms ║║Calculating (integer) 10 - (integer) 4 >> (integer) 6
+636ms ║║Calculating (integer) 6 - (integer) 2 >> (integer) 4
+644ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+654ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+661ms ║║Calculating (string) Jane + (string) and >> (string) Jane and
+666ms ║║Calculating (string) Jane and + (string) Jane >> (string) Jane and Jane
+670ms ║║Calculating (string) Jane and Jane + (string) have >> (string) Jane and Jane have
+674ms ║║Calculating (string) Jane, Jane + (string) has >> (string) Jane, Jane has
+677ms ║║Calculating (integer) 4 > (integer) 0 >> (boolean) true
+683ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+694ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+698ms ║║Calculating (string) Jane and Jane have + (string) left the building. >> (string) Jane and Jane have left the building.
+703ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+724ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+743ms ║║Calculating (integer) 2 == (integer) 2 >> (boolean) true
+749ms ║║Calculating (string) Have a nice day + (string) Jane and Jane >> (string) Have a nice day Jane and Jane
+752ms ║║Calculating (string) Have a nice day Jane and Jane + (string) , >> (string) Have a nice day Jane and Jane,
+755ms ║║Calculating (string) Have a nice day Jane and Jane, + (string) Jane and Jane have >> (string) Have a nice day Jane and Jane, Jane and Jane have
+758ms ║║Calculating (string) Have a nice day Jane and Jane, Jane and Jane have + (string) popped out. >> (string) Have a nice day Jane and Jane, Jane and Jane have popped out.
+763ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+786ms ║║Executed virtual command [Kitchen Sonos].sendPushNotification (18ms)
+799ms ║║Comparison (time) 32274251 is_between (time) 25200000 … (time) 79200000 = true (7ms)
+800ms ║║Time restriction check passed
+801ms ║║Condition #75 evaluated true (12ms)
+802ms ║║Condition group #74 evaluated true (state did not change) (14ms)
+803ms ║║Cancelling statement #74’s schedules…
+810ms ║║Calculating (string) http://192.168.1.100:5005/sayall/ + (string) Have a nice day Jane and Jane, Jane and Jane have popped out. >> (string) http://192.168.1.100:5005/sayall/Have a nice day Jane and Jane, Jane and Jane have popped out.
+813ms ║║Calculating (string) http://192.168.1.100:5005/sayall/Have a nice day Jane and Jane, Jane and Jane have popped out. + (string) /50 >> (string) http://192.168.1.100:5005/sayall/Have a nice day Jane and Jane, Jane and Jane have popped out./50
+819ms ║║Sending internal web request to: 192.168.1.100:5005/sayall/Have%20a%20nice%20day%20Jane%20and%20Jane,%20Jane%20and%20Jane%20have%20popped%20out./50
+822ms ║║Executed virtual command httpRequest (3ms)
+823ms ║║Requesting a wake up for Tue, Jan 30 2018 @ 8:58:14 AM EST (in 20.0s)
+830ms ║╚Execution stage complete. (621ms)
+832ms ║Setting up scheduled job for Tue, Jan 30 2018 @ 8:58:14 AM EST (in 19.992s), with 1 more job pending
+841ms ╚Event processed successfully (841ms)
1/30/2018, 8:57:46 AM +308ms
+1ms ╔Received event [Home].time = 1517320667581 with a delay of -1273ms
+209ms ║RunTime Analysis CS > 21ms > PS > 38ms > PE > 149ms > CE
+213ms ║Runtime (64240 bytes) successfully initialized in 38ms (v0.2.102.20180116) (211ms)
+214ms ║╔Execution stage started
+231ms ║║Calculating (datetime) 1517320666534 - (datetime) 1517320638815 >> (datetime) 27719
+237ms ║║Comparison (datetime) 27719 is_greater_than (integer) 300000 = false (2ms)
+238ms ║║Condition #27 evaluated false (15ms)
+239ms ║║Condition group #24 evaluated false (state did not change) (17ms)
+264ms ║║Cancelling condition #56’s schedules…
+265ms ║║Condition #56 evaluated false (19ms)
+266ms ║║Cancelling condition #55’s schedules…
+267ms ║║Condition group #55 evaluated false (state changed) (21ms)
+268ms ║║Cancelling condition #11’s schedules…
+269ms ║║Condition group #11 evaluated false (state changed) (24ms)
+281ms ║║Comparison (time) 32266581 happens_daily_at (datetime) 1517320638815 = true (4ms)
+282ms ║║Time restriction check passed
+283ms ║║Cancelling condition #49’s schedules…
+284ms ║║Condition #49 evaluated true (12ms)
+285ms ║║Cancelling statement #49’s schedules…
+291ms ║║Requesting time schedule wake up at Tue, Jan 30 2018 @ 8:57:48 AM EST
+306ms ║║Comparison (boolean) false is (boolean) false = true (2ms)
+308ms ║║Condition #48 evaluated true (14ms)
+309ms ║║Cancelling condition #38’s schedules…
+310ms ║║Condition group #38 evaluated true (state changed) (38ms)
+312ms ║║Cancelling statement #39’s schedules…
+318ms ║║Executed virtual command setVariable (2ms)
+326ms ║║Comparison (integer) 2 is_greater_than (integer) 0 = true (2ms)
+328ms ║║Cancelling condition #65’s schedules…
+329ms ║║Condition #65 evaluated true (6ms)
+330ms ║║Cancelling condition #61’s schedules…
+330ms ║║Condition group #61 evaluated true (state changed) (9ms)
+333ms ║║Cancelling statement #52’s schedules…
+352ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+374ms ║║Calculating (integer) 4 - (integer) -1 >> (integer) 5
+377ms ║║Calculating (integer) 5 - (integer) 2 >> (integer) 3
+385ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+389ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) ane >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane
+393ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+400ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+422ms ║║Calculating (integer) 4 - (integer) -1 >> (integer) 5
+425ms ║║Calculating (integer) 5 - (integer) 2 >> (integer) 3
+434ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+445ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+452ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+457ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) ane >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane
+462ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane + (string) have >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane have
+466ms ║║Calculating (string) Jane + (string) has >> (string) Jane has
+470ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+476ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+488ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+494ms ║║Calculating (string) Jane has + (string) left the building. >> (string) Jane has left the building.
+500ms ║║Executed virtual command [Kitchen Sonos].setVariable (4ms)
+526ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+547ms ║║Calculating (integer) 2 == (integer) 2 >> (boolean) true
+554ms ║║Calculating (string) Have a nice day + (string) Jane >> (string) Have a nice day Jane
+559ms ║║Calculating (string) Have a nice day Jane + (string) , >> (string) Have a nice day Jane,
+562ms ║║Calculating (string) Have a nice day Jane, + (string) Jane has >> (string) Have a nice day Jane, Jane has
+566ms ║║Calculating (string) Have a nice day Jane, Jane has + (string) gone out. >> (string) Have a nice day Jane, Jane has gone out.
+571ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+606ms ║║Executed virtual command [Kitchen Sonos].sendPushNotification (30ms)
+620ms ║║Comparison (time) 32266918 is_between (time) 25200000 … (time) 79200000 = true (8ms)
+621ms ║║Time restriction check passed
+623ms ║║Cancelling condition #75’s schedules…
+624ms ║║Condition #75 evaluated true (14ms)
+625ms ║║Cancelling condition #74’s schedules…
+626ms ║║Condition group #74 evaluated true (state changed) (17ms)
+627ms ║║Cancelling statement #74’s schedules…
+634ms ║║Calculating (string) http://192.168.1.100:5005/sayall/ + (string) Have a nice day Jane, Jane has gone out. >> (string) http://192.168.1.100:5005/sayall/Have a nice day Jane, Jane has gone out.
+637ms ║║Calculating (string) http://192.168.1.100:5005/sayall/Have a nice day Jane, Jane has gone out. + (string) /50 >> (string) http://192.168.1.100:5005/sayall/Have a nice day Jane, Jane has gone out./50
+650ms ║║Sending internal web request to: 192.168.1.100:5005/sayall/Have%20a%20nice%20day%20Jane,%20Jane%20has%20gone%20out./50
+653ms ║║Executed virtual command httpRequest (10ms)
+654ms ║║Requesting a wake up for Tue, Jan 30 2018 @ 8:58:06 AM EST (in 20.0s)
+662ms ║║Fast executing schedules, waiting for 1846ms to sync up
+2522ms ║║Calculating (datetime) 1517320668826 - (datetime) 1517320638815 >> (datetime) 30011
+2528ms ║║Comparison (datetime) 30011 is_greater_than (integer) 300000 = false (2ms)
+2529ms ║║Condition #27 evaluated false (13ms)
+2530ms ║║Condition group #24 evaluated false (state did not change) (14ms)
+2556ms ║║Condition #56 evaluated false (20ms)
+2557ms ║║Condition group #55 evaluated false (state did not change) (21ms)
+2558ms ║║Condition group #11 evaluated false (state did not change) (23ms)
+2565ms ║║Comparison (time) 32268869 happens_daily_at (datetime) 1517320638815 = true (1ms)
+2566ms ║║Time restriction check passed
+2567ms ║║Condition #49 evaluated true (6ms)
+2568ms ║║Cancelling statement #49’s schedules…
+2573ms ║║Requesting time schedule wake up at Wed, Jan 31 2018 @ 8:57:48 AM EST
+2582ms ║║Comparison (boolean) false is (boolean) false = true (2ms)
+2584ms ║║Condition #48 evaluated true (8ms)
+2585ms ║║Condition group #38 evaluated true (state did not change) (23ms)
+2587ms ║║Cancelling statement #39’s schedules…
+2594ms ║║Executed virtual command setVariable (4ms)
+2602ms ║║Comparison (integer) 2 is_greater_than (integer) 0 = true (2ms)
+2603ms ║║Condition #65 evaluated true (5ms)
+2604ms ║║Condition group #61 evaluated true (state did not change) (7ms)
+2607ms ║║Cancelling statement #52’s schedules…
+2619ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+2640ms ║║Calculating (integer) 4 - (integer) -1 >> (integer) 5
+2643ms ║║Calculating (integer) 5 - (integer) 2 >> (integer) 3
+2650ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+2654ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) ane >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane
+2658ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+2664ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+2685ms ║║Calculating (integer) 4 - (integer) -1 >> (integer) 5
+2688ms ║║Calculating (integer) 5 - (integer) 2 >> (integer) 3
+2696ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+2707ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+2714ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and
+2718ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) ane >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane
+2722ms ║║Calculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane + (string) have >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and ane have
+2727ms ║║Calculating (string) Jane + (string) has >> (string) Jane has
+2731ms ║║Calculating (integer) -1 > (integer) 0 >> (boolean) false
+2736ms ║║Executed virtual command [Kitchen Sonos].setVariable (2ms)
+2746ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+2751ms ║║Calculating (string) Jane has + (string) left the building. >> (string) Jane has left the building.
+2756ms ║║Executed virtual command [Kitchen Sonos].setVariable (3ms)
+2775ms ║║Calculating (integer) 2 == (integer) 1 >> (boolean) false
+2793ms ║║Calculating (integer) 2 == (integer) 2 >> (boolean) true
+2798ms ║║Calculating (string) Bye + (string) Jane >> (string) Bye Jane
+2802ms ║║Calculating (string) Bye Jane + (string) , >> (string) Bye Jane,
+2805ms ║║Calculating (string) Bye Jane, + (string) Jane has >> (string) Bye Jane, Jane has
+2808ms ║║Calculating (string) Bye Jane, Jane has + (string) buggered off. >> (string) Bye Jane, Jane has buggered off.
+2812ms ║║Executed virtual command [Kitchen Sonos].setVariable (2ms)
+2832ms ║║Executed virtual command [Kitchen Sonos].sendPushNotification (15ms)
+2848ms ║║Comparison (time) 32269145 is_between (time) 25200000 … (time) 79
And the Piston I am using.
