I made a circadian schedule for level and color temp that updates when each included bulb is turned on. I also made a child piston that cycles through and updates the circadian bulbs at each mode change.
The problem is, when your turn on a bunch of bulbs at once, the piston skips like 30% to 40% of them.
Every bulb should update, not just most of them.
See above. There are issues with the child piston leaving bulbs on instead of restoring the captured switch state, but that’s another problem.
No logs yet, but I can post one if the problem isn’t obvious from the code.
