There is also this snippet of information from @ady624 that you may find useful for additional clarification.
_____________________________________
A piston is usually executed on events that trigger it. Therefore, triggers - by definition - will always run pistons. In the event no trigger is present, conditions then fulfill that role by acting as triggers themselves (all the conditions in the piston do that when no triggers are present). The moment a trigger exists, conditions step down and act as just that, conditions (or restrictions, if you want), therefore not triggering pistons themselves.
Only conditions >>> all conditions act as triggers and they all subscribe to events
Mixed conditions and triggers >>> only the triggers subscribe to events
Only triggers >>> only the triggers subscribe to events
There is, of course, the manual modification of this behaviour, by forcing a condition or trigger to either subscribe regardless, or never subscribe. Those settings take priority over the logic described above.
