Good news bad and bad news…
The piston runs great when the forecasted temp are above 82 to day the temp is going to be in the warm category, but awoke to the heat on…we originally had if all of the other variables failed that it would be a cold day…I changed that to being below 68.
All variables below Hot are coming up false.
6/11/2018, 8:10:16 AM +238ms
+1ms ╔Received event [Home].test = 1528726216238 with a delay of 0ms
+250ms ║RunTime Analysis CS > 18ms > PS > 98ms > PE > 133ms > CE
+255ms ║Runtime (74823 bytes) successfully initialized in 98ms (v0.3.104.20180323) (253ms)
+256ms ║╔Execution stage started
+276ms ║║Comparison (time) 29416506 is_between (time) 15000000 … (time) 75000000 = true (6ms)
+277ms ║║Time restriction check passed
+278ms ║║Condition #346 evaluated true (11ms)
+279ms ║║Cancelling condition #180’s schedules…
+280ms ║║Condition group #180 evaluated true (state changed) (12ms)
+288ms ║║Comparison (decimal) 74.0 is_greater_than_or_equal_to (integer) 75 = false (1ms)
+289ms ║║Condition #173 evaluated false (8ms)
+290ms ║║Cancelling condition #180’s schedules…
+291ms ║║Condition group #180 evaluated false (state changed) (11ms)
+296ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+298ms ║║Condition #340 evaluated false (5ms)
+299ms ║║Condition group #177 evaluated false (state did not change) (5ms)
+304ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+306ms ║║Condition #341 evaluated false (4ms)
+306ms ║║Condition group #218 evaluated false (state did not change) (5ms)
+312ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+313ms ║║Condition #342 evaluated false (4ms)
+314ms ║║Condition group #234 evaluated false (state did not change) (6ms)
+320ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+321ms ║║Condition #347 evaluated false (5ms)
+322ms ║║Condition group #259 evaluated false (state did not change) (5ms)
+326ms ║║Comparison (time) 29416563 happens_daily_at (time) 15000000 = false (0ms)
+328ms ║║Condition #284 evaluated false (4ms)
+330ms ║║Cancelling statement #284’s schedules…
+332ms ║║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+335ms ║║Condition group #283 evaluated false (state did not change) (11ms)
+349ms ║║Comparison (time) 29416579 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+351ms ║║Condition #360 evaluated false (9ms)
+351ms ║║Condition group #313 evaluated false (state did not change) (10ms)
+362ms ║║Comparison (time) 29416592 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+363ms ║║Condition #361 evaluated false (9ms)
+364ms ║║Condition group #325 evaluated false (state did not change) (11ms)
+370ms ║╚Execution stage complete. (115ms)
+374ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 9:10:00 AM MDT (in 3583.388s), with 4 more jobs pending
+388ms ╚Event processed successfully (387ms)
6/11/2018, 8:09:59 AM +91ms
+0ms ╔Received event [Home].time = 1528726200000 with a delay of -910ms
+415ms ║RunTime Analysis CS > 15ms > PS > 79ms > PE > 322ms > CE
+419ms ║Runtime (74828 bytes) successfully initialized in 79ms (v0.3.104.20180323) (418ms)
+420ms ║╔Execution stage started
+434ms ║║Cancelling statement #335’s schedules…
+440ms ║║Executed virtual command setVariable (3ms)
+446ms ║║Executed virtual command setVariable (2ms)
+451ms ║║Executed virtual command setVariable (3ms)
+457ms ║║Executed virtual command setVariable (2ms)
+10579ms ║║Comparison (dynamic) is_greater_than (integer) 82 = false (3ms)
+10580ms ║║Condition #189 evaluated false (10120ms)
+10581ms ║║Condition group #184 evaluated false (state did not change) (10122ms)
+10854ms ║║Error calling comparison comp_is_between: java.lang.ClassCastException
+10856ms ║║Condition #375 evaluated false (272ms)
+10857ms ║║Condition group #190 evaluated false (state did not change) (273ms)
+10865ms ║║Error calling comparison comp_is_between: java.lang.ClassCastException
+10867ms ║║Condition #374 evaluated false (7ms)
+10868ms ║║Condition group #196 evaluated false (state did not change) (8ms)
+10875ms ║║Comparison (dynamic) 80.4 is_less_than (decimal) 68.9 = false (2ms)
+10876ms ║║Condition #373 evaluated false (6ms)
+10877ms ║║Condition group #368 evaluated false (state did not change) (7ms)
+10882ms ║╚Execution stage complete. (10462ms)
+10884ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 9:10:00 AM MDT (in 3590.025s), with 4 more jobs pending
+10895ms ╚Event processed successfully (10895ms)
6/11/2018, 8:08:44 AM +395ms
+1ms ╔Received event [Home].test = 1528726124395 with a delay of 0ms
+222ms ║RunTime Analysis CS > 12ms > PS > 64ms > PE > 145ms > CE
+226ms ║Runtime (74824 bytes) successfully initialized in 64ms (v0.3.104.20180323) (225ms)
+227ms ║╔Execution stage started
+245ms ║║Comparison (time) 29324632 is_between (time) 15000000 … (time) 75000000 = true (7ms)
+246ms ║║Time restriction check passed
+247ms ║║Condition #346 evaluated true (11ms)
+248ms ║║Cancelling condition #180’s schedules…
+249ms ║║Condition group #180 evaluated true (state changed) (13ms)
+256ms ║║Comparison (decimal) 74.0 is_greater_than_or_equal_to (integer) 75 = false (1ms)
+258ms ║║Condition #173 evaluated false (8ms)
+259ms ║║Cancelling condition #180’s schedules…
+259ms ║║Condition group #180 evaluated false (state changed) (9ms)
+265ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+266ms ║║Condition #340 evaluated false (4ms)
+267ms ║║Condition group #177 evaluated false (state did not change) (6ms)
+273ms ║║Comparison (boolean) false is (boolean) true = false (2ms)
+274ms ║║Condition #341 evaluated false (5ms)
+275ms ║║Condition group #218 evaluated false (state did not change) (6ms)
+281ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+282ms ║║Condition #342 evaluated false (5ms)
+283ms ║║Condition group #234 evaluated false (state did not change) (6ms)
+288ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+290ms ║║Condition #347 evaluated false (4ms)
+291ms ║║Condition group #259 evaluated false (state did not change) (5ms)
+296ms ║║Comparison (time) 29324689 happens_daily_at (time) 15000000 = false (0ms)
+297ms ║║Condition #284 evaluated false (4ms)
+298ms ║║Cancelling statement #284’s schedules…
+301ms ║║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+303ms ║║Condition group #283 evaluated false (state did not change) (10ms)
+320ms ║║Comparison (time) 29324707 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+322ms ║║Condition #360 evaluated false (10ms)
+323ms ║║Cancelling condition #313’s schedules…
+324ms ║║Condition group #313 evaluated false (state changed) (11ms)
+334ms ║║Comparison (time) 29324721 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+336ms ║║Condition #361 evaluated false (10ms)
+337ms ║║Condition group #325 evaluated false (state did not change) (11ms)
+345ms ║╚Execution stage complete. (118ms)
+347ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 8:10:00 AM MDT (in 75.258s), with 4 more jobs pending
+360ms ╚Event processed successfully (360ms)
6/11/2018, 8:08:29 AM +426ms
+1ms ╔Starting piston… (v0.3.104.20180323)
+300ms ║╔Subscribing to devices…
+377ms ║║Subscribing to Den Temp.temperature…
+441ms ║║Subscribing to Nest Downstairs…
+442ms ║║Subscribing to Nest Upstairs…
+442ms ║╚Finished subscribing (154ms)
+821ms ║Comparison (dynamic) 80.4 is_greater_than (integer) 82 = false (2ms)
+836ms ║Error calling comparison comp_is_between: java.lang.ClassCastException
+849ms ║Error calling comparison comp_is_between: java.lang.ClassCastException
+858ms ║Comparison (dynamic) 80.4 is_less_than (decimal) 68.9 = false (1ms)
+879ms ║Comparison (dynamic) 76.0 is_less_than (integer) 69 = false (2ms)
+880ms ║Cancelling condition #276’s schedules…
+881ms ║Cancelling condition #271’s schedules…
+896ms ║Comparison (time) 29310314 is_between (time) 15000000 … (time) 75000000 = true (6ms)
+897ms ║Time restriction check passed
+899ms ║Cancelling condition #180’s schedules…
+907ms ║Comparison (decimal) 74.0 is_greater_than_or_equal_to (integer) 75 = false (1ms)
+909ms ║Cancelling condition #180’s schedules…
+914ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+921ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+928ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+934ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+941ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+948ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+955ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+962ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+968ms ║Comparison (time) 29310392 happens_daily_at (time) 15000000 = false (0ms)
+969ms ║Cancelling statement #284’s schedules…
+972ms ║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+977ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+983ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+990ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+996ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+1004ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+1020ms ║Comparison (dynamic) 78.3 is_greater_than (integer) 77 = true (1ms)
+1021ms ║Cancelling condition #300’s schedules…
+1022ms ║Cancelling condition #296’s schedules…
+1030ms ║Comparison (dynamic) 78.3 is_less_than_or_equal_to (integer) 68 = false (1ms)
+1031ms ║Cancelling condition #306’s schedules…
+1032ms ║Cancelling condition #302’s schedules…
+1048ms ║Comparison (dynamic) 78.3 is_greater_than (integer) 77 = true (1ms)
+1049ms ║Cancelling condition #312’s schedules…
+1050ms ║Cancelling condition #308’s schedules…
+1064ms ║Comparison (time) 29310481 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+1069ms ║Comparison (boolean) true is (boolean) true = true (1ms)
+1070ms ║Cancelling condition #313’s schedules…
+1085ms ║Comparison (time) 29310503 is_between (time) 76200000 … (time) 13200000 = false (7ms)
+1092ms ║Comparison (decimal) 74.0 is_greater_than (integer) 76 = false (1ms)
+1097ms ║Comparison (boolean) true is (boolean) false = false (2ms)
+1108ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 8:10:00 AM MDT (in 89.467s), with 4 more jobs pending
+1131ms ╚Piston successfully started (1130ms)
6/11/2018, 8:06:20 AM +505ms
+0ms ╔Received event [Home].test = 1528725980504 with a delay of 0ms
+236ms ║RunTime Analysis CS > 16ms > PS > 82ms > PE > 138ms > CE
+240ms ║Runtime (74809 bytes) successfully initialized in 82ms (v0.3.104.20180323) (239ms)
+241ms ║╔Execution stage started
+266ms ║║Comparison (time) 29180763 is_between (time) 15000000 … (time) 75000000 = true (6ms)
+267ms ║║Time restriction check passed
+269ms ║║Condition #346 evaluated true (11ms)
+270ms ║║Cancelling condition #180’s schedules…
+271ms ║║Condition group #180 evaluated true (state changed) (13ms)
+279ms ║║Comparison (decimal) 74.0 is_greater_than_or_equal_to (integer) 75 = false (1ms)
+280ms ║║Condition #173 evaluated false (8ms)
+281ms ║║Cancelling condition #180’s schedules…
+282ms ║║Condition group #180 evaluated false (state changed) (10ms)
+287ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+289ms ║║Condition #340 evaluated false (4ms)
+290ms ║║Condition group #177 evaluated false (state did not change) (6ms)
+295ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+297ms ║║Condition #341 evaluated false (5ms)
+298ms ║║Condition group #218 evaluated false (state did not change) (6ms)
+305ms ║║Condition #342 evaluated false (5ms)
+306ms ║║Condition group #234 evaluated false (state did not change) (6ms)
+312ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+313ms ║║Condition #347 evaluated false (5ms)
+314ms ║║Condition group #259 evaluated false (state did not change) (6ms)
+319ms ║║Comparison (time) 29180822 happens_daily_at (time) 15000000 = false (1ms)
+320ms ║║Condition #284 evaluated false (3ms)
+321ms ║║Cancelling statement #284’s schedules…
+326ms ║║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+343ms ║║Condition group #283 evaluated false (state did not change) (27ms)
+359ms ║║Comparison (time) 29180855 is_between (time) 76200000 … (time) 13200000 = false (7ms)
+361ms ║║Condition #360 evaluated false (11ms)
+362ms ║║Condition group #313 evaluated false (state did not change) (12ms)
+374ms ║║Comparison (time) 29180870 is_between (time) 76200000 … (time) 13200000 = false (8ms)
+375ms ║║Condition #361 evaluated false (11ms)
+376ms ║║Condition group #325 evaluated false (state did not change) (12ms)
+388ms ║╚Execution stage complete. (147ms)
+392ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 9:10:00 AM MDT (in 3819.104s), with 4 more jobs pending
+406ms ╚Event processed successfully (407ms)
6/11/2018, 8:04:59 AM +74ms
+0ms ╔Received event [Home].time = 1528725900000 with a delay of -927ms
+247ms ║RunTime Analysis CS > 19ms > PS > 79ms > PE > 150ms > CE
+252ms ║Runtime (74799 bytes) successfully initialized in 79ms (v0.3.104.20180323) (251ms)
+253ms ║╔Execution stage started
+269ms ║║Cancelling statement #335’s schedules…
+276ms ║║Executed virtual command setVariable (2ms)
+282ms ║║Executed virtual command setVariable (2ms)
+287ms ║║Executed virtual command setVariable (2ms)
+294ms ║║Executed virtual command setVariable (3ms)
+533ms ║║Comparison (dynamic) 80.4 is_greater_than (integer) 82 = false (2ms)
+535ms ║║Condition #189 evaluated false (238ms)
+536ms ║║Condition group #184 evaluated false (state did not change) (239ms)
+554ms ║║Error calling comparison comp_is_between: java.lang.ClassCastException
+556ms ║║Condition #375 evaluated false (16ms)
+557ms ║║Condition group #190 evaluated false (state did not change) (19ms)
+566ms ║║Error calling comparison comp_is_between: java.lang.ClassCastException
+568ms ║║Condition #374 evaluated false (8ms)
+570ms ║║Condition group #196 evaluated false (state did not change) (10ms)
+578ms ║║Comparison (dynamic) 80.4 is_less_than (decimal) 68.9 = false (2ms)
+580ms ║║Cancelling condition #373’s schedules…
+581ms ║║Condition #373 evaluated false (9ms)
+582ms ║║Cancelling condition #368’s schedules…
+583ms ║║Condition group #368 evaluated false (state changed) (11ms)
+592ms ║╚Execution stage complete. (339ms)
+616ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 9:10:00 AM MDT (in 3900.311s), with 4 more jobs pending
+729ms ╚Event processed successfully (729ms)
6/11/2018, 8:02:54 AM +347ms
+2ms ╔Received event [Den Temp].temperature = 74 with a delay of 1131ms
+263ms ║RunTime Analysis CS > 16ms > PS > 105ms > PE > 141ms > CE
+268ms ║Runtime (74801 bytes) successfully initialized in 105ms (v0.3.104.20180323) (265ms)
+269ms ║╔Execution stage started
+292ms ║║Comparison (time) 28974630 is_between (time) 15000000 … (time) 75000000 = true (7ms)
+293ms ║║Time restriction check passed
+294ms ║║Condition #346 evaluated true (12ms)
+296ms ║║Cancelling condition #180’s schedules…
+296ms ║║Condition group #180 evaluated true (state changed) (14ms)
+302ms ║║Comparison (decimal) 74.0 is_greater_than_or_equal_to (integer) 75 = false (2ms)
+304ms ║║Condition #173 evaluated false (6ms)
+305ms ║║Cancelling condition #180’s schedules…
+305ms ║║Condition group #180 evaluated false (state changed) (8ms)
+313ms ║║Condition #340 evaluated false (5ms)
+314ms ║║Condition group #177 evaluated false (state did not change) (7ms)
+321ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+322ms ║║Condition #341 evaluated false (5ms)
+323ms ║║Condition group #218 evaluated false (state did not change) (7ms)
+329ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+331ms ║║Condition #342 evaluated false (5ms)
+332ms ║║Condition group #234 evaluated false (state did not change) (7ms)
+338ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+340ms ║║Condition #347 evaluated false (6ms)
+341ms ║║Condition group #259 evaluated false (state did not change) (6ms)
+346ms ║║Comparison (time) 28974691 happens_daily_at (time) 15000000 = false (0ms)
+347ms ║║Condition #284 evaluated false (3ms)
+348ms ║║Cancelling statement #284’s schedules…
+352ms ║║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+354ms ║║Condition group #283 evaluated false (state did not change) (11ms)
+371ms ║║Comparison (time) 28974709 is_between (time) 76200000 … (time) 13200000 = false (7ms)
+373ms ║║Condition #360 evaluated false (11ms)
+374ms ║║Condition group #313 evaluated false (state did not change) (12ms)
+386ms ║║Comparison (time) 28974724 is_between (time) 76200000 … (time) 13200000 = false (7ms)
+388ms ║║Condition #361 evaluated false (10ms)
+389ms ║║Condition group #325 evaluated false (state did not change) (12ms)
+394ms ║╚Execution stage complete. (125ms)
+397ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 8:05:00 AM MDT (in 125.257s), with 4 more jobs pending
+411ms ╚Event processed successfully (411ms)
6/11/2018, 8:01:22 AM +541ms
+1ms ╔Received event [Home].test = 1528725682541 with a delay of 0ms
+276ms ║RunTime Analysis CS > 18ms > PS > 101ms > PE > 156ms > CE
+280ms ║Runtime (74797 bytes) successfully initialized in 101ms (v0.3.104.20180323) (279ms)
+281ms ║╔Execution stage started
+301ms ║║Comparison (time) 28882834 is_between (time) 15000000 … (time) 75000000 = true (7ms)
+302ms ║║Time restriction check passed
+304ms ║║Condition #346 evaluated true (11ms)
+304ms ║║Cancelling condition #180’s schedules…
+305ms ║║Condition group #180 evaluated true (state changed) (13ms)
+314ms ║║Comparison (decimal) 73.0 is_greater_than_or_equal_to (integer) 75 = false (2ms)
+315ms ║║Condition #173 evaluated false (9ms)
+316ms ║║Cancelling condition #180’s schedules…
+317ms ║║Condition group #180 evaluated false (state changed) (11ms)
+323ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+324ms ║║Condition #340 evaluated false (5ms)
+325ms ║║Condition group #177 evaluated false (state did not change) (6ms)
+331ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+332ms ║║Condition #341 evaluated false (5ms)
+333ms ║║Condition group #218 evaluated false (state did not change) (6ms)
+339ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+340ms ║║Condition #342 evaluated false (5ms)
+341ms ║║Condition group #234 evaluated false (state did not change) (6ms)
+347ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+348ms ║║Condition #347 evaluated false (5ms)
+349ms ║║Condition group #259 evaluated false (state did not change) (6ms)
+354ms ║║Comparison (time) 28882893 happens_daily_at (time) 15000000 = false (1ms)
+355ms ║║Condition #284 evaluated false (3ms)
+356ms ║║Cancelling statement #284’s schedules…
+359ms ║║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+361ms ║║Condition group #283 evaluated false (state did not change) (10ms)
+377ms ║║Comparison (time) 28882910 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+379ms ║║Condition #360 evaluated false (10ms)
+380ms ║║Cancelling condition #313’s schedules…
+381ms ║║Condition group #313 evaluated false (state changed) (12ms)
+391ms ║║Comparison (time) 28882924 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+393ms ║║Condition #361 evaluated false (10ms)
+394ms ║║Condition group #325 evaluated false (state did not change) (11ms)
+401ms ║╚Execution stage complete. (120ms)
+404ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 8:05:00 AM MDT (in 217.056s), with 4 more jobs pending
+417ms ╚Event processed successfully (417ms)
6/11/2018, 8:00:30 AM +146ms
+0ms ╔Starting piston… (v0.3.104.20180323)
+511ms ║╔Subscribing to devices…
+610ms ║║Subscribing to Den Temp.temperature…
+685ms ║║Subscribing to Nest Downstairs…
+686ms ║║Subscribing to Nest Upstairs…
+687ms ║╚Finished subscribing (185ms)
+10850ms ║Comparison (dynamic) is_greater_than (integer) 82 = false (3ms)
+12162ms ║Comparison (dynamic) is_between (integer) 75 … (decimal) 81.9 = false (4ms)
+12175ms ║Comparison (dynamic) is_between (integer) 69 … (decimal) 74.9 = false (4ms)
+12176ms ║Cancelling condition #196’s schedules…
+12186ms ║Comparison (dynamic) is_less_than (decimal) 68.9 = true (2ms)
+12188ms ║Cancelling condition #373’s schedules…
+12188ms ║Cancelling condition #368’s schedules…
+12208ms ║Comparison (dynamic) is_less_than (integer) 69 = true (2ms)
+12210ms ║Cancelling condition #276’s schedules…
+12211ms ║Cancelling condition #271’s schedules…
+12230ms ║Comparison (time) 28842366 is_between (time) 15000000 … (time) 75000000 = true (7ms)
+12231ms ║Time restriction check passed
+12233ms ║Cancelling condition #180’s schedules…
+12242ms ║Comparison (decimal) 73.0 is_greater_than_or_equal_to (integer) 75 = false (1ms)
+12243ms ║Cancelling condition #180’s schedules…
+12248ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12255ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12262ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12269ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+12276ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+12283ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12289ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12296ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12302ms ║Comparison (time) 28842446 happens_daily_at (time) 15000000 = false (0ms)
+12308ms ║Cancelling statement #284’s schedules…
+12325ms ║Requesting time schedule wake up at Tue, Jun 12 2018 @ 4:10:00 AM MDT
+12330ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12336ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12343ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+12350ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+12357ms ║Comparison (boolean) false is (boolean) true = false (2ms)
+12372ms ║Comparison (dynamic) is_greater_than (integer) 77 = false (2ms)
+12381ms ║Comparison (dynamic) is_less_than_or_equal_to (integer) 68 = true (1ms)
+12383ms ║Cancelling condition #306’s schedules…
+12383ms ║Cancelling condition #302’s schedules…
+12400ms ║Comparison (dynamic) is_greater_than (integer) 77 = false (2ms)
+12414ms ║Comparison (time) 28842551 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+12419ms ║Comparison (boolean) true is (boolean) true = true (1ms)
+12420ms ║Cancelling condition #313’s schedules…
+12436ms ║Comparison (time) 28842574 is_between (time) 76200000 … (time) 13200000 = false (6ms)
+12444ms ║Comparison (decimal) 73.0 is_greater_than (integer) 76 = false (2ms)
+12448ms ║Comparison (boolean) true is (boolean) false = false (1ms)
+12468ms ║Setting up scheduled job for Mon, Jun 11 2018 @ 8:05:00 AM MDT (in 257.386s), with 4 more jobs pending
+12492ms ╚Piston successfully started (12492ms)
