Light Timer Efficiency
Is there a more efficient way to do what I’m trying to do here? The part I don’t like is that the piston has to be evaluated every 30 seconds even when no lights are on at all. I want to keep all of this configurable as it is now though.
The goal here is to turn a group of lights on based on motion, for minimum of 120 seconds. Once the motion sensor goes inactive, a 60 second countdown is started. Then every 30 seconds the lights dim by 10%, until they finally turn off. Any motion will reset the process.
It works, but I don’t want to put too much load on the webcore server(s).
I think there’s a fade function for lights, you can just try using it, then set the fade out time you prefer.
Hmm, that’s cool, but it seems there is no way to cancel the fade once it has started:
That’s inconvenient… I tired fade once but was scared by that function because it keeps sending commands to the light. So I use manual fade (hard coded brightness level) since I fear the load to the light as well as to the piston.
