Lights off when Home Monitor Armed Away
I would like to have all the lights turn off when I leave and arm my system to away.
Arm to away-lights, and various other i.e. coffee machine all off
Lights do not turn off.
10/29/2020, 12:12:08 PM +444ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+540ms ║╔Subscribing to devices…
+571ms ║║Subscribing to Home.alarmSystemStatus…
+895ms ║║Subscribing to Heating Pad Master…
+897ms ║║Subscribing to La Pavoni…
+898ms ║║Subscribing to Light Bath Downstairs…
+899ms ║║Subscribing to Light Bath Upstairs…
+900ms ║║Subscribing to Light Closet Guest…
+901ms ║║Subscribing to Light Closet Master…
+902ms ║║Subscribing to Light Closet Outdoor Ground…
+903ms ║║Subscribing to Light Dining Dimmer…
+904ms ║║Subscribing to Light Guest Desk…
+906ms ║║Subscribing to Light Living Middle…
+907ms ║║Subscribing to Light Living Slide Door…
+908ms ║║Subscribing to Light Master Left…
+909ms ║║Subscribing to Light Master Right…
+910ms ║║Subscribing to Light Office Floor Lamp…
+911ms ║║Subscribing to Light Office Desk…
+912ms ║║Subscribing to Projector Master…
+913ms ║╚Finished subscribing (394ms)
+940ms ║Comparison (string) stay changes_away_from (string) off = false (1ms)
+946ms ║Comparison (string) stay changes_to (string) away = false (1ms)
+963ms ╚Piston successfully started (963ms))
STHM is not working in webcore right now. You have to create switches in the IDE. See Clear instructions on Virtual Switches for STHM?
If you have already done that, try just triggering with your alarm system changing to ARMED and see if that works.
Thanks for the suggestion. That seems to work.
