Hey guys! I’m new to this whole thing and have been trying to make my Lights work for about 11 hours now. I think I’ve got most of what I need figured out. But, I was wondering if There was a way to create a loop.
I have a virtual Switch set up. My piston if set that when the switch is on, the lights will flicker red and orange for 1 second a flicker at 10 times each.
Then the statement below shuts off the switch and turns it back on. This triggers the event to happen again, but the switch will not kick off a second time.
Am I going about creating a loop wrong? I tried to cycle the flickers 1800 times to have them go for an hour, but it bogged down too much.
Any advice for a noob would be appreciated.
My end goal is to figure out how to make the colored bulbs flicker different colors for at least an hour, if not more. We host parties and I haven’t found any way to do this yet.
Edit:
SOLUTION FOUND! Check a few posts down to see the piston build and details. Faster party lights than the others I’ve seen and themed lights flashing!
