"Manual" Light Switch Interaction
#21
BTW…I was just wondering if the inverse was possible. I don’t suppose it’s possible for ST to trigger on a change that happens to a switch that ST did not initiate? IE - It get’s an on message that it didn’t request the action.
#22
Yeah, I get what you’re after. But the reason I setup what I have is that you can’t get what you’re trying to do to work. These switches do not send any special code/instruction/notification that would allow ST or WC to know that the interaction with them was physical versus programmatic.
On the other side, there’s no way for WC to know that an event (the light turned on) came from the physical switch or from the ST hub or from the Alexa device. All WC knows is that the light turned on.
That’s why I built what I have… Since you cannot know what turned on the light…I decided to instead change the way the lights work when they are turned on.
Yeah, I think that would work…a pain, but it should work.
I have the GE Z-Wave plus switches that support double-tap on them…so that’s what I did, the effect is not native in the switch though, so I just wrote a few WC pistons to make that happen. If i hit the double-tap up I have the associated lights immediately go to 100, otherwise if I just press the light on once they go to the level they were last set to. Turning them on thru ST or the Echo also has them go to the level they last had.
Nope. Again there’s nothing sent that provides that type of information. .
