Hi Paul
I actually had to turn off TCP twice. Now it is working perfectly. Here is a screenshot of the working Piston:
Seems to work perfectly. Voice Activate virtual device Patio Mister. Misting Pump cycles every 30 seconds On and Off until Voice Turn Off virtual device Patio Mister.
I also think moving to 30 seconds helped. Smartthings Z-Wave lag is very bothersome. I’ll try shorter periods as I test it out as 30 seconds On is too long. Need around 15 seconds On and 30 seconds Off.
Now I’m moving on to add a trigger for the Cooling Fans to be sure they are On when the Patio Mister is On and then a safety kill switch for both if left on too long. WebCoRE is awesome!! Not as intuitive as I need but extremely powerful once you get the hang of it.
Thank you to you and Pantheon for all your support.
Steve
