I’ve seen this as well. Twice I had to re-include the Sensor to get it going again.
Mood Cube Piston
Maybe I’m missing something: I have a Multi Sensor, set as a “SmartSense Multi Sensor”.
In webcore, I only get the “status” state (?):
In the IDE, I see:
temperature: 23 C
battery: 83
contact: open
threeAxis: 40,1035,-23
acceleration: inactive
checkInterval: 720
status: open
What am I doing wrong? Shouldn’t I see an “orientation” state somewhere?
(Ideally I would like a device handler that only shows BATTERY and ORIENTATION, rather than threeAxis and the other states which are irrelevant when the sensor is used as a mood cube.)
Thanks!
The handler I’m using is SmartSense Multi, there is another handler listed as SmartSense Multi Sensor.
I’m not sure if you have the same device, but with my SmartThings Multipurpose Sensor, there is no DH required.
thanks. i removed it and re-paired (again, as a “SmartSense Multi Sensor”) and now I get all the options!
I just did this a few days ago with a newer SmartThings Multipurpose sensor as well. Next step is to see if I can get some other ‘advanced features’ to work like the magic cube product. Would be cool if rotate would dim up/down which color is up, tap to toggle on/off, toss/roll to random or party lights, etc
