The piston have 2 main arguments, where it uses the condition “is and stays for X time”. Even though I change the environment to that if stop meeting the rule the piston continues and execute both statements
By the time the argument is not met anymore, the “stays for X time” should reset an the actual value disconsidered
the piston after initiated just goes on without stopping
2/8/2021, 11:59:41 PM +210ms
+3ms ╔Received event [Home].time = 1612839580981 with a delay of 229ms,canQueue: true, calledMyself: false
+6ms ║RunTime initialize > 5 LockT > 0ms > rtDT > 1ms > pistonT > 0ms (first state access 4 4 1)
+10ms ║Runtime (10648 bytes) successfully initialized in 1ms (v0.3.113.20210203_HE)
+53ms ║╔Execution stage started
+65ms ║║Cancelling condition #16's schedules...
+67ms ║║Condition #16 evaluated true (2ms)
+68ms ║║Cancelling condition #15's schedules...
+69ms ║║Condition group #15 evaluated true (state changed) (5ms)
+71ms ║║Cancelling statement #17's schedules...
+101ms ║║Executed physical command [Luz Ale].off() (27ms)
+102ms ║║Executed virtual command [Luz Ale].toggle (29ms)
+107ms ║║Error while executing physical command virtual-tts-Alexa-porta quarto.off([]): java.lang.IllegalArgumentException: Command 'off' is not supported by device.
+145ms ║║Executed virtual command [virtual-tts-Alexa-porta quarto].toggle (41ms)
+168ms ║╚Execution stage complete. (115ms)
+187ms ╚Event processed successfully (185ms)
2/8/2021, 11:59:25 PM +767ms
+4ms ╔Received event [Home].time = 1612839565939 with a delay of -172ms,canQueue: true, calledMyself: false
+7ms ║RunTime initialize > 6 LockT > 0ms > rtDT > 1ms > pistonT > 0ms (first state access 5 4 2)
+10ms ║Runtime (10646 bytes) successfully initialized in 1ms (v0.3.113.20210203_HE)
+54ms ║Synchronizing scheduled event, waiting for 119ms
+175ms ║╔Execution stage started
+183ms ║║Cancelling condition #7's schedules...
+185ms ║║Condition #7 evaluated true (2ms)
+187ms ║║Cancelling condition #6's schedules...
+188ms ║║Condition group #6 evaluated true (state changed) (6ms)
+190ms ║║Cancelling statement #8's schedules...
+221ms ║║Executed physical command [virtual-tts-Alexa-porta quarto].active() (27ms)
+223ms ║║Executed [virtual-tts-Alexa-porta quarto].active (30ms)
+232ms ║║Comparison (enum) on is (string) on = true (1ms)
+234ms ║║Condition #11 evaluated true (6ms)
+241ms ║║Comparison (enum) off is (string) on = false (1ms)
+243ms ║║Condition #13 evaluated false (7ms)
+248ms ║║Condition #14 evaluated false (4ms)
+250ms ║║Condition group #12 evaluated false (state did not change) (14ms)
+252ms ║║Condition group #10 evaluated false (state did not change) (24ms)
+298ms ║║Condition #7 evaluated true (1ms)
+299ms ║║Condition group #6 evaluated true (state did not change) (2ms)
+300ms ║║Cancelling statement #8's schedules...
+342ms ║║Executed physical command [virtual-tts-Alexa-porta quarto].active() (38ms)
+343ms ║║Executed [virtual-tts-Alexa-porta quarto].active (41ms)
+353ms ║║Comparison (enum) on is (string) on = true (1ms)
+355ms ║║Condition #11 evaluated true (6ms)
+361ms ║║Comparison (enum) off is (string) on = false (1ms)
+362ms ║║Condition #13 evaluated false (6ms)
+367ms ║║Condition #14 evaluated false (3ms)
+368ms ║║Condition group #12 evaluated false (state did not change) (11ms)
+370ms ║║Condition group #10 evaluated false (state did not change) (21ms)
+391ms ║╚Execution stage complete. (216ms)
+447ms ║Setting up scheduled job for Tue, Feb 9 2021 @ 12:59:40 AM BRST (in 15s)
+449ms ╚Event processed successfully (447ms)
