also can you link pistions to actiontiles via virtual switches
Playing sounds or a wav file
WCmore
#22
Technically, you donât need Nextos softwareâŚ
AutoHotkey or EventGhost can send a URL command to run any piston.
Yes. ActionTiles can toggle a Simulated Switch, and webCoRE can monitor that switch, and do different things depending on if it is an on or an off command
