Reporting the lowest battery level
variables
#21
Hello guys, I’m having problems with this piston again. I have {if $devices’s $status is ‘OFFLINE’} then save matching list to a variable, like in my piston above. This has been working flawlessly. However I noticed today some of my newer sensors were not being reported as offline. I looked at the devices status in the IDE and it said ‘HUB_DISCONNECTED’, while other offline sensors showed ‘OFFLINE’. I would like to add this other status to my piston but I can’t get it to work.
If I put {if $devices’s $status is ‘HUB_DISCONNECTED’} it reports the missing offline sensor. The problem is when I try to add ‘OFFLINE’. I tried:
But when testing it just evaluates as false and skips. I read through the webCoRE wiki on and it said you use ‘||’ for an OR, but I don’t know if I have worded the expression right to make it work.
In the comparison I tried ‘is’ & ‘is any of’ but neither made any difference. I also tried:
To no avail. Thanks for any help guys.
#22
Why not split into two conditions:
IF {SensorOnLine}'s $status is 'HUB_DISCONNECTED'
   or
   {SensorOnLine}'s $status is 'OFFLINE'
       Then do stuff
END IF
Alternatively, you can dump $status into a string variable, and then check conditions like this:
pic
#23
Perfect! Thank you. The second example worked.
I did try the first example but the problem was you had to have:
IF {SensorOnLine}'s $status is ‘HUB_DISCONNECTED’
-save matching list to var
or
{SensorOnLine}'s $status is ‘OFFLINE’
END IF
Meaning if you did have devices that were offline it would overwrite the list of hub_disconnected sensors and visa versa.
#24
So ever since the migration, this piston no longer works. Apparently the new messages system has a text limit so it doesn’t support the long piece of text this piston throws out. Anyone know if smartthings knows about this or if there is a work around?
#25
Are you receiving errors from the piston (logs?) or are you just not receiving push notifications from the new app. The new app requires you to set ‘store in messages’ as true. I have a multi-line message that is sent daily with no issues in the new app.
#26
  • Is it the trigger failing? (IE: piston not executing)
  • or is the outputed commands failing? (IE: no SMS received)
If it’s the failed trigger…
I wonder if it is the “IS ANY OF” comparison above…
(I have not tested that type of search in the new app yet)
#27
Sorry for the delay.
So I run the piston to give me a report and this is the log:
(Sorry I can’t remember how to put it into a container - Thanks WCmore)
9/13/2020, 7:40:22 AM +154ms
+0ms 	╔Received event [Our Home].routineExecuted = 892323bc-3d51-48e6-b72c-143048a9cc1d with a delay of 141ms
+151ms 	║RunTime Analysis CS > 20ms > PS > 91ms > PE > 40ms > CE
+154ms 	║Runtime (67961 bytes) successfully initialized in 91ms (v0.3.110.20191009) (152ms)
+154ms 	║╔Execution stage started
+161ms 	║║Comparison (string) :5cd4f21e809ad429c98c4ebc87b6804f: executes (string) :5cd4f21e809ad429c98c4ebc87b6804f: = true (1ms)
+163ms 	║║Cancelling condition #66's schedules...
+164ms 	║║Condition #66 evaluated true (5ms)
+165ms 	║║Cancelling condition #65's schedules...
+165ms 	║║Condition group #65 evaluated true (state changed) (7ms)
+167ms 	║║Cancelling statement #78's schedules...
+173ms 	║║Executed virtual command setVariable (2ms)
+179ms 	║║Executed virtual command setVariable (3ms)
+1652ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1655ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1657ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1660ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1663ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1666ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1669ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1671ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1674ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1677ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1680ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1683ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1685ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1688ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1691ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1694ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1696ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1699ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1702ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1704ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1707ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1710ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1713ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1716ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1718ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1721ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1724ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1726ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (1ms)
+1729ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1732ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1735ms 	║║Comparison (string) ONLINE is_any_of (string) OFFLINE, HUB_DISCONNECTED = false (2ms)
+1744ms 	║║Condition #38 evaluated false (1562ms)
+1745ms 	║║Condition group #5 evaluated false (state did not change) (1564ms)
+1840ms 	║║Comparison (integer) 84 is_less_than (integer) 55 = false (1ms)
+1842ms 	║║Comparison (integer) 78 is_less_than (integer) 55 = false (1ms)
+1845ms 	║║Comparison (integer) 44 is_less_than (integer) 55 = true (1ms)
+1847ms 	║║Comparison (integer) 68 is_less_than (integer) 55 = false (1ms)
+1849ms 	║║Comparison (integer) 59 is_less_than (integer) 55 = false (1ms)
+1851ms 	║║Comparison (integer) 56 is_less_than (integer) 55 = false (1ms)
+1853ms 	║║Comparison (integer) 64 is_less_than (integer) 55 = false (1ms)
+1856ms 	║║Comparison (integer) 98 is_less_than (integer) 55 = false (1ms)
+1858ms 	║║Comparison (integer) 94 is_less_than (integer) 55 = false (1ms)
+1860ms 	║║Comparison (integer) 100 is_less_than (integer) 55 = false (2ms)
+1862ms 	║║Comparison (integer) 67 is_less_than (integer) 55 = false (1ms)
+1864ms 	║║Comparison (integer) 92 is_less_than (integer) 55 = false (1ms)
+1866ms 	║║Comparison (integer) 45 is_less_than (integer) 55 = true (1ms)
+1869ms 	║║Comparison (integer) 32 is_less_than (integer) 55 = true (1ms)
+1871ms 	║║Comparison (integer) 100 is_less_than (integer) 55 = false (1ms)
+1873ms 	║║Comparison (integer) 58 is_less_than (integer) 55 = false (1ms)
+1880ms 	║║Condition #41 evaluated true (133ms)
+1881ms 	║║Condition group #39 evaluated true (state did not change) (134ms)
+1917ms 	║║Comparison (integer) 44 is_less_than (integer) 55 = true (1ms)
+1919ms 	║║Condition #51 evaluated true (36ms)
+1920ms 	║║Condition group #50 evaluated true (state did not change) (37ms)
+1921ms 	║║Cancelling statement #50's schedules...
+1928ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+1928ms 	║║ + (string)
+1928ms 	║║ >> (string) ******** SYSTEM CHECK ********
+1932ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+1932ms 	║║ + (string) Bedroom Motion, Lounge Room Motion and Main Hallway Motion >> (string) ******** SYSTEM CHECK ********
+1932ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion
+1935ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+1935ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion + (string) battery is low. >> (string) ******** SYSTEM CHECK ********
+1935ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+1940ms 	║║Executed virtual command setVariable (3ms)
+1961ms 	║║Comparison (integer) 44 is_greater_than_or_equal_to (integer) 55 = false (2ms)
+1963ms 	║║Comparison (integer) 45 is_greater_than_or_equal_to (integer) 55 = false (1ms)
+1966ms 	║║Comparison (integer) 32 is_greater_than_or_equal_to (integer) 55 = false (1ms)
+1967ms 	║║Condition #91 evaluated false (24ms)
+1968ms 	║║Condition group #89 evaluated false (state did not change) (26ms)
+1971ms 	║║Cancelling statement #60's schedules...
+2045ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2045ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low. + (string)
+2045ms 	║║Average Indoor Temp is >> (string) ******** SYSTEM CHECK ********
+2049ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2049ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2049ms 	║║Average Indoor Temp is + (string) 22 >> (string) ******** SYSTEM CHECK ********
+2049ms 	║║Average Indoor Temp is 22
+2052ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2053ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2053ms 	║║Average Indoor Temp is 22 + (string) °C
+2053ms 	║║Average Outdoor Temp is >> (string) ******** SYSTEM CHECK ********
+2053ms 	║║Average Indoor Temp is 22°C
+2056ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2056ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2056ms 	║║Average Indoor Temp is 22°C
+2056ms 	║║Average Outdoor Temp is + (string) 17 >> (string) ******** SYSTEM CHECK ********
+2056ms 	║║Average Outdoor Temp is 17
+2059ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2059ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2059ms 	║║Average Indoor Temp is 22°C
+2059ms 	║║Average Outdoor Temp is 17 + (string) °C >> (string) ******** SYSTEM CHECK ********
+2060ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2060ms 	║║Average Indoor Temp is 22°C
+2060ms 	║║Average Outdoor Temp is 17°C
+2065ms 	║║Executed virtual command setVariable (4ms)
+2070ms 	║║Condition #55 evaluated false (2ms)
+2071ms 	║║Condition group #53 evaluated false (state did not change) (3ms)
+2074ms 	║║Cancelling statement #2's schedules...
+2078ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2078ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2078ms 	║║Average Indoor Temp is 22°C
+2078ms 	║║Average Outdoor Temp is 17°C + (string)
+2079ms 	║║Battery Levels are: >> (string) ******** SYSTEM CHECK ********
+2079ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2079ms 	║║Average Indoor Temp is 22°C
+2079ms 	║║Average Outdoor Temp is 17°C
+2084ms 	║║Executed virtual command setVariable (2ms)
+2094ms 	║║Cancelling statement #84's schedules...
+2102ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2102ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2102ms 	║║Average Indoor Temp is 22°C
+2102ms 	║║Average Outdoor Temp is 17°C
+2102ms 	║║Battery Levels are: + (string)
+2102ms 	║║- >> (string) ******** SYSTEM CHECK ********
+2103ms 	║║Average Indoor Temp is 22°C
+2103ms 	║║Average Outdoor Temp is 17°C
+2103ms 	║║Battery Levels are:
+2103ms 	║║-
+2111ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2111ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2111ms 	║║Average Indoor Temp is 22°C
+2111ms 	║║Average Outdoor Temp is 17°C
+2111ms 	║║Battery Levels are:
+2112ms 	║║- + (string) 84 >> (string) ******** SYSTEM CHECK ********
+2112ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2112ms 	║║Average Indoor Temp is 22°C
+2112ms 	║║Average Outdoor Temp is 17°C
+2112ms 	║║Battery Levels are:
+2112ms 	║║- 84
+2115ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2115ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2115ms 	║║Average Indoor Temp is 22°C
+2115ms 	║║Average Outdoor Temp is 17°C
+2115ms 	║║Battery Levels are:
+2115ms 	║║- 84 + (string) % = >> (string) ******** SYSTEM CHECK ********
+2116ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2116ms 	║║Average Indoor Temp is 22°C
+2116ms 	║║Average Outdoor Temp is 17°C
+2116ms 	║║Battery Levels are:
+2116ms 	║║- 84% =
+2119ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2119ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2119ms 	║║Average Indoor Temp is 22°C
+2119ms 	║║Average Outdoor Temp is 17°C
+2119ms 	║║Battery Levels are:
+2119ms 	║║- 84% = + (string) Back Door >> (string) ******** SYSTEM CHECK ********
+2120ms 	║║Average Indoor Temp is 22°C
+2120ms 	║║Average Outdoor Temp is 17°C
+2120ms 	║║Battery Levels are:
+2120ms 	║║- 84% = Back Door
+2125ms 	║║Executed virtual command setVariable (3ms)
+2135ms 	║║Cancelling statement #84's schedules...
+2142ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2142ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2142ms 	║║Average Indoor Temp is 22°C
+2143ms 	║║Average Outdoor Temp is 17°C
+2143ms 	║║Battery Levels are:
+2143ms 	║║- 84% = Back Door + (string)
+2143ms 	║║- >> (string) ******** SYSTEM CHECK ********
+2143ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2143ms 	║║Average Indoor Temp is 22°C
+2143ms 	║║-
+2153ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2153ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2153ms 	║║Average Indoor Temp is 22°C
+2153ms 	║║Average Outdoor Temp is 17°C
+2153ms 	║║Battery Levels are:
+2153ms 	║║- 84% = Back Door
+2153ms 	║║- + (string) 78 >> (string) ******** SYSTEM CHECK ********
+2154ms 	║║Battery Levels are:
+2154ms 	║║- 84% = Back Door
+2154ms 	║║- 78
+2157ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2157ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2157ms 	║║Average Indoor Temp is 22°C
+2157ms 	║║Average Outdoor Temp is 17°C
+2157ms 	║║Battery Levels are:
+2157ms 	║║- 84% = Back Door
+2157ms 	║║- 78 + (string) % = >> (string) ******** SYSTEM CHECK ********
+2158ms 	║║Average Indoor Temp is 22°C
+2158ms 	║║Average Outdoor Temp is 17°C
+2158ms 	║║Battery Levels are:
+2158ms 	║║- 84% = Back Door
+2158ms 	║║- 78% =
+2161ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2161ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2161ms 	║║Average Indoor Temp is 22°C
+2161ms 	║║Average Outdoor Temp is 17°C
+2161ms 	║║Battery Levels are:
+2161ms 	║║- 84% = Back Door
+2161ms 	║║- 78% = + (string) Bedroom Hallway Motion >> (string) ******** SYSTEM CHECK ********
+2162ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2162ms 	║║Average Indoor Temp is 22°C
+2162ms 	║║Average Outdoor Temp is 17°C
+2162ms 	║║Battery Levels are:
+2162ms 	║║- 84% = Back Door
+2162ms 	║║- 78% = Bedroom Hallway Motion
+2167ms 	║║Executed virtual command setVariable (3ms)
+2177ms 	║║Cancelling statement #84's schedules...
+2184ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2184ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2184ms 	║║Average Indoor Temp is 22°C
+2184ms 	║║Average Outdoor Temp is 17°C
+2185ms 	║║Battery Levels are:
+2185ms 	║║- 84% = Back Door
+2185ms 	║║- 78% = Bedroom Hallway Motion + (string)
+2185ms 	║║- >> (string) ******** SYSTEM CHECK ********
+2185ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2185ms 	║║Average Indoor Temp is 22°C
+2185ms 	║║Average Outdoor Temp is 17°C
+2186ms 	║║-
+2194ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2194ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2194ms 	║║Average Indoor Temp is 22°C
+2194ms 	║║Average Outdoor Temp is 17°C
+2194ms 	║║Battery Levels are:
+2194ms 	║║- 84% = Back Door
+2194ms 	║║- 78% = Bedroom Hallway Motion
+2194ms 	║║- + (string) 44 >> (string) ******** SYSTEM CHECK ********
+2195ms 	║║Average Outdoor Temp is 17°C
+2195ms 	║║Battery Levels are:
+2195ms 	║║- 84% = Back Door
+2195ms 	║║- 78% = Bedroom Hallway Motion
+2195ms 	║║- 44
+2198ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2198ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2198ms 	║║Average Indoor Temp is 22°C
+2198ms 	║║Average Outdoor Temp is 17°C
+2198ms 	║║Battery Levels are:
+2198ms 	║║- 84% = Back Door
+2198ms 	║║- 78% = Bedroom Hallway Motion
+2199ms 	║║- 44 + (string) % = >> (string) ******** SYSTEM CHECK ********
+2199ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2199ms 	║║Average Indoor Temp is 22°C
+2199ms 	║║Average Outdoor Temp is 17°C
+2199ms 	║║Battery Levels are:
+2199ms 	║║- 84% = Back Door
+2199ms 	║║- 78% = Bedroom Hallway Motion
+2199ms 	║║- 44% =
+2202ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2202ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2202ms 	║║Average Indoor Temp is 22°C
+2202ms 	║║Average Outdoor Temp is 17°C
+2202ms 	║║Battery Levels are:
+2202ms 	║║- 84% = Back Door
+2203ms 	║║- 78% = Bedroom Hallway Motion
+2203ms 	║║- 44% = + (string) Bedroom Motion >> (string) ******** SYSTEM CHECK ********
+2203ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2203ms 	║║Average Indoor Temp is 22°C
+2203ms 	║║Average Outdoor Temp is 17°C
+2203ms 	║║Battery Levels are:
+2203ms 	║║- 84% = Back Door
+2203ms 	║║- 44% = Bedroom Motion
+2208ms 	║║Executed virtual command setVariable (3ms)
+2217ms 	║║Cancelling statement #84's schedules...
+2225ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2225ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2225ms 	║║Average Indoor Temp is 22°C
+2225ms 	║║Average Outdoor Temp is 17°C
+2225ms 	║║Battery Levels are:
+2225ms 	║║- 84% = Back Door
+2225ms 	║║- 78% = Bedroom Hallway Motion
+2225ms 	║║- 44% = Bedroom Motion + (string)
+2225ms 	║║- >> (string) ******** SYSTEM CHECK ********
+2226ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2226ms 	║║Average Indoor Temp is 22°C
+2226ms 	║║Average Outdoor Temp is 17°C
+2226ms 	║║Battery Levels are:
+2226ms 	║║- 84% = Back Door
+2226ms 	║║- 78% = Bedroom Hallway Motion
+2226ms 	║║- 44% = Bedroom Motion
+2226ms 	║║-
+2234ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2234ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2234ms 	║║Average Indoor Temp is 22°C
+2234ms 	║║Average Outdoor Temp is 17°C
+2234ms 	║║Battery Levels are:
+2234ms 	║║- 84% = Back Door
+2234ms 	║║- 78% = Bedroom Hallway Motion
+2235ms 	║║- 44% = Bedroom Motion
+2235ms 	║║- + (string) 68 >> (string) ******** SYSTEM CHECK ********
+2235ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2235ms 	║║Average Indoor Temp is 22°C
+2235ms 	║║Average Outdoor Temp is 17°C
+2235ms 	║║Battery Levels are:
+2235ms 	║║- 84% = Back Door
+2235ms 	║║- 78% = Bedroom Hallway Motion
+2235ms 	║║- 68
+2238ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2238ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2238ms 	║║Average Indoor Temp is 22°C
+2239ms 	║║Average Outdoor Temp is 17°C
+2239ms 	║║Battery Levels are:
+2239ms 	║║- 84% = Back Door
+2239ms 	║║- 78% = Bedroom Hallway Motion
+2239ms 	║║- 44% = Bedroom Motion
+2239ms 	║║- 68 + (string) % = >> (string) ******** SYSTEM CHECK ********
+2239ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2239ms 	║║Average Indoor Temp is 22°C
+2240ms 	║║- 84% = Back Door
+2240ms 	║║- 78% = Bedroom Hallway Motion
+2240ms 	║║- 44% = Bedroom Motion
+2240ms 	║║- 68% =
+2243ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2243ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2243ms 	║║Average Indoor Temp is 22°C
+2243ms 	║║Average Outdoor Temp is 17°C
+2243ms 	║║Battery Levels are:
+2243ms 	║║- 84% = Back Door
+2243ms 	║║- 78% = Bedroom Hallway Motion
+2243ms 	║║- 44% = Bedroom Motion
+2243ms 	║║- 68% = + (string) En-Suite Shower Sensor >> (string) ******** SYSTEM CHECK ********
+2244ms 	║║Average Indoor Temp is 22°C
+2244ms 	║║Average Outdoor Temp is 17°C
+2244ms 	║║Battery Levels are:
+2244ms 	║║- 84% = Back Door
+2244ms 	║║- 78% = Bedroom Hallway Motion
+2244ms 	║║- 44% = Bedroom Motion
+2244ms 	║║- 68% = En-Suite Shower Sensor
+2249ms 	║║Executed virtual command setVariable (2ms)
+2258ms 	║║Cancelling statement #84's schedules...
+2265ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2266ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2266ms 	║║Average Indoor Temp is 22°C
+2266ms 	║║Average Outdoor Temp is 17°C
+2266ms 	║║Battery Levels are:
+2266ms 	║║- 84% = Back Door
+2266ms 	║║- 78% = Bedroom Hallway Motion
+2266ms 	║║- 44% = Bedroom Motion
+2266ms 	║║- 68% = En-Suite Shower Sensor + (string)
+2266ms 	║║- >> (string) ******** SYSTEM CHECK ********
+2267ms 	║║Average Indoor Temp is 22°C
+2267ms 	║║Average Outdoor Temp is 17°C
+2267ms 	║║Battery Levels are:
+2267ms 	║║- 84% = Back Door
+2267ms 	║║- 78% = Bedroom Hallway Motion
+2267ms 	║║- 44% = Bedroom Motion
+2267ms 	║║- 68% = En-Suite Shower Sensor
+2267ms 	║║-
+2275ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2275ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2275ms 	║║Average Indoor Temp is 22°C
+2275ms 	║║Average Outdoor Temp is 17°C
+2275ms 	║║Battery Levels are:
+2276ms 	║║- 84% = Back Door
+2276ms 	║║- 78% = Bedroom Hallway Motion
+2276ms 	║║- 44% = Bedroom Motion
+2276ms 	║║- 68% = En-Suite Shower Sensor
+2276ms 	║║- + (string) 59 >> (string) ******** SYSTEM CHECK ********
+2276ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2276ms 	║║Average Indoor Temp is 22°C
+2276ms 	║║Average Outdoor Temp is 17°C
+2276ms 	║║Battery Levels are:
+2277ms 	║║- 78% = Bedroom Hallway Motion
+2277ms 	║║- 44% = Bedroom Motion
+2277ms 	║║- 68% = En-Suite Shower Sensor
+2277ms 	║║- 59
+2280ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2280ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2280ms 	║║Average Indoor Temp is 22°C
+2280ms 	║║Average Outdoor Temp is 17°C
+2280ms 	║║Battery Levels are:
+2280ms 	║║- 84% = Back Door
+2280ms 	║║- 78% = Bedroom Hallway Motion
+2281ms 	║║- 44% = Bedroom Motion
+2281ms 	║║- 68% = En-Suite Shower Sensor
+2281ms 	║║- 59 + (string) % = >> (string) ******** SYSTEM CHECK ********
+2281ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2281ms 	║║Average Indoor Temp is 22°C
+2281ms 	║║Average Outdoor Temp is 17°C
+2281ms 	║║Battery Levels are:
+2281ms 	║║- 84% = Back Door
+2281ms 	║║- 78% = Bedroom Hallway Motion
+2282ms 	║║- 68% = En-Suite Shower Sensor
+2282ms 	║║- 59% =
+2285ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2285ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2285ms 	║║Average Indoor Temp is 22°C
+2285ms 	║║Average Outdoor Temp is 17°C
+2285ms 	║║Battery Levels are:
+2285ms 	║║- 84% = Back Door
+2286ms 	║║- 78% = Bedroom Hallway Motion
+2286ms 	║║- 44% = Bedroom Motion
+2286ms 	║║- 68% = En-Suite Shower Sensor
+2286ms 	║║- 59% = + (string) Front Door >> (string) ******** SYSTEM CHECK ********
+2286ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2286ms 	║║Average Indoor Temp is 22°C
+2286ms 	║║Average Outdoor Temp is 17°C
+2286ms 	║║Battery Levels are:
+2286ms 	║║- 84% = Back Door
+2287ms 	║║- 44% = Bedroom Motion
+2287ms 	║║- 68% = En-Suite Shower Sensor
+2287ms 	║║- 59% = Front Door
+2293ms 	║║Executed virtual command setVariable (4ms)
+2303ms 	║║Cancelling statement #84's schedules...
+2311ms 	║║Calculating (string) ******** SYSTEM CHECK ********
+2311ms 	║║Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low.
+2311ms 	║║Average Indoor Temp is 22°C
+2311ms 	║║Average Outdoor Temp is 17°C
+2311ms 	║║Battery Levels are:
+2311ms 	║║- 84% = Back Door
+2311ms 	║║- 78% = Bedroom Hallway Motion
+2311ms 	║║- 44% = Bedroom Motion
+2311ms 	║║- 68% = En-Suite Shower Sensor
+2311ms 	║║- 59% = Front Door + (string)
+2312ms 	║║- >> (string) ******** SYSTEM CHECK ********
I know the piston worked as my health report variable has stored the report:
******** SYSTEM CHECK ******** Bedroom Motion, Lounge Room Motion and Main Hallway Motion battery is low. Average Indoor Temp is 22°C Average Outdoor Temp is 17°C Battery Levels are: - 84% = Back Door - 78% = Bedroom Hallway Motion - 44% = Bedroom Motion - 68% = En-Suite Shower Sensor - 59% = Front Door - 56% = Gaming Time Motion - 64% = Garage Door - 98% = Garage Inner Door - 94% = Garage Rear Door - 100% = Goodnight Button - 67% = Kitchen Motion - 92% = Laundry Door - 45% = Lounge Room Motion - 32% = Main Hallway Motion - 100% = TV Button - 58% = Water Cooler Level ***** END OF REPORT *****
But when I go into the new Smartthings app there is no message:
That;s the issue I’m having. It used to show the message in the old app but now I’ve migrated, the old app no longer shows these notifications and neither does the new app.
#28
I’m using “Send Notification”, as I didn’t want it as a push notification, but there is no store in messages option. I do know what your talking about though.
#29
Okay, update:
If I set it to push notification - Store in messages, it works.
The layout is all wrong so I’ll have to tweak it. So perhaps the send notification is broken? I’ll just use push from now on.
I’ll ask another question while I’m here. How are you guys now using your Smartthings ‘Automations’ aka routines to trigger webcore pistons? As the new app doesn’t allow an empty automation, how have you set it up to allow you to trigger webcore pistons?
UPDATE:
Also, some people wanted an updated piston so here you go:
I had planned to list the battery levels in ascending order using WCmore’s idea but I couldn’t figure out how to code it into my existing piston. Something like:
For each $device in SensorBatt do
only when
[$device: battery < 10]
do
Add $devices to report
only when
[$device: battery > 10 && < 21]
do
only when
[$device: battery > 20 && < 31]
do
But I couldn’t figure it out, sorry guys. I don’t really understand how to use expressions and operators, I just tend to code by trial and error.
