Maybe post a green snapshot of your piston so it’s easier to modify for the ones wanting to try it.
Simple piston to turn off power to a tablet mounted on wall every 3 hours
eibyer
#24
Give this a try… I only tested it briefly using minutes instead of hours. Edit the variables as you see fit.
dman97
#26
Thank you, this is working perfectly. Does having the checkInterval every minute but any processing burden on the hub? It seams like communicating every minute is a lot.
eibyer
#27
You can change it to however many minutes you feel comfortable with, maybe 10 mins to start with. I set it to 1 when I was trying it out.
