‘stays open’ condition evaluating true, when not true
door contact ‘stays open’ alert only evaluates true when door actually stays open
webcore received event for door open. then received event for door closed. door is closed and shows closed in Smartthings. but after timer expires, webcore still evaluates ‘stays open for x minutes’ as true and sends an alert as if the door stayed open. but it didn’t.
**4) Post a Green Snapshot of the piston![image|45x37] 3/3/2021, 10:55:32 AM +103ms
+0ms ╔Received event [Home].time = 1614786933534 with a delay of -1432ms
+97ms ║RunTime Analysis CS > 37ms > PS > 7ms > PE > 54ms > CE
+100ms ║Runtime (40429 bytes) successfully initialized in 7ms (v0.3.110.20191009) (99ms)
+106ms ║║Cancelling condition #6’s schedules…
+107ms ║║Condition #6 evaluated true (1ms)
+108ms ║║Cancelling condition #1’s schedules…
+109ms ║║Condition group #1 evaluated true (state changed) (4ms)
+111ms ║║Cancelling statement #3’s schedules…
+118ms ║║Executed virtual command setVariable (4ms)
+123ms ║║Calculating (string) Front door + (string) left open! >> (string) Front door left open!
+140ms ║║Executed virtual command sendPushNotification (15ms)
+158ms ║║Condition #8 evaluated false (14ms)
+159ms ║║Condition group #7 evaluated false (state did not change) (15ms)
+164ms ║╚Execution stage complete. (64ms)
+165ms ╚Event processed successfully (165ms)
3/3/2021, 10:53:33 AM +395ms
+2ms ╔Received event [Front door].contact = closed with a delay of 82ms
+10097ms ║RunTime Analysis CS > 19ms > PS > 10018ms > PE > 60ms > CE
+10098ms ║Piston waited at a semaphore for 10014ms
+10101ms ║Runtime (40509 bytes) successfully initialized in 10018ms (v0.3.110.20191009) (10099ms)
+10102ms ║╔Execution stage started
+10120ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+10123ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+10125ms ║║Cancelling any timed trigger schedules for device :e15f714fefa025df117dd7f6a367fc2e: for condition 2
+10126ms ║║Cancelling statement #2’s schedules…
+10127ms ║║Cancelling any timed trigger schedules for device :ab013e547a5357e7ba38e0bd47d21d64: for condition 2
+10128ms ║║Cancelling statement #2’s schedules…
+10129ms ║║Condition #2 evaluated false (22ms)
+10156ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+10159ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+10161ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+10163ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+10165ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+10167ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+10170ms ║║Cancelling any timed trigger schedules for device :9f125e85d7668f07630cda8669e2b54f: for condition 6
+10171ms ║║Cancelling statement #6’s schedules…
+10172ms ║║Cancelling any timed trigger schedules for device :545c96cd4154f43a033054a0560b355c: for condition 6
+10173ms ║║Cancelling statement #6’s schedules…
+10174ms ║║Cancelling any timed trigger schedules for device :89228cac944a8052eca54ec498767ce2: for condition 6
+10174ms ║║Cancelling statement #6’s schedules…
+10175ms ║║Cancelling any timed trigger schedules for device :8fb094e769ca309b8d39cf4bbe526d81: for condition 6
+10176ms ║║Cancelling statement #6’s schedules…
+10177ms ║║Cancelling any timed trigger schedules for device :28dff03eed807785c7129675dfda7dff: for condition 6
+10178ms ║║Cancelling statement #6’s schedules…
+10179ms ║║Cancelling any timed trigger schedules for device :f5e3232120c2ce6a145021e4ca2b4806: for condition 6
+10179ms ║║Cancelling statement #6’s schedules…
+10180ms ║║Condition #6 evaluated false (51ms)
+10181ms ║║Condition group #1 evaluated false (state did not change) (75ms)
+10191ms ║║Condition #8 evaluated false (6ms)
+10192ms ║║Condition group #7 evaluated false (state did not change) (8ms)
+10194ms ║╚Execution stage complete. (93ms)
+10195ms ╚Event processed successfully (10195ms)
3/3/2021, 10:53:33 AM +381ms
+1ms ╔Received event [Front door].contact = open with a delay of 91ms
+77ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 51ms > CE
+79ms ║Runtime (40426 bytes) successfully initialized in 5ms (v0.3.110.20191009) (77ms)
+80ms ║╔Execution stage started
+97ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+99ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+102ms ║║Cancelling any timed trigger schedules for device :e15f714fefa025df117dd7f6a367fc2e: for condition 2
+102ms ║║Cancelling statement #2’s schedules…
+103ms ║║Cancelling any timed trigger schedules for device :ab013e547a5357e7ba38e0bd47d21d64: for condition 2
+104ms ║║Cancelling statement #2’s schedules…
+105ms ║║Condition #2 evaluated false (20ms)
+132ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+135ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+137ms ║║Comparison (enum) open stays (string) open = true (1ms)
+139ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+142ms ║║Comparison (enum) closed stays (string) open = false (1ms)
+144ms ║║Comparison (enum) closed stays (string) open = false (2ms)
+147ms ║║Cancelling any timed trigger schedules for device :9f125e85d7668f07630cda8669e2b54f: for condition 6
+148ms ║║Cancelling statement #6’s schedules…
+148ms ║║Cancelling any timed trigger schedules for device :545c96cd4154f43a033054a0560b355c: for condition 6
+149ms ║║Cancelling statement #6’s schedules…
+152ms ║║Adding a timed trigger schedule for device :89228cac944a8052eca54ec498767ce2: for condition 6
+155ms ║║Cancelling any timed trigger schedules for device :8fb094e769ca309b8d39cf4bbe526d81: for condition 6
+155ms ║║Cancelling statement #6’s schedules…
+156ms ║║Cancelling any timed trigger schedules for device :28dff03eed807785c7129675dfda7dff: for condition 6
+157ms ║║Cancelling statement #6’s schedules…
+158ms ║║Cancelling any timed trigger schedules for device :f5e3232120c2ce6a145021e4ca2b4806: for condition 6
+159ms ║║Cancelling statement #6’s schedules…
+160ms ║║Condition #6 evaluated false (53ms)
+161ms ║║Condition group #1 evaluated false (state did not change) (76ms)
+170ms ║║Condition #8 evaluated false (7ms)
+171ms ║║Condition group #7 evaluated false (state did not change) (8ms)
+174ms ║╚Execution stage complete. (93ms)
+175ms ║Setting up scheduled job for Wed, Mar 3 2021 @ 10:55:33 AM EST (in 119.979s)
+184ms ╚Event processed successfully (184ms)
