It seems the sunrise and sunset from the previous day are used to schedule the piston, even after I have added a trigger for it to run daily just after midnight.
Am I running it too soon after midnight, or is there something else at play here that I do not understand?
In any case, do I need to move the timer to after 3AM in order to correctly capture changes due to daylight savings time? We moved the clock forward on 28 March as can be seen in the logs.
I would expect the timer to turn the switch on or off should run at the current sunrise and sunset (eg. the same times as specified in the log statement run just after midnight)
The piston appears to trigger based on the sunrise and sunset from the previous day.
3/29/2021, 7:16:59 AM +62ms
+0ms ╔Received event [My home].time = 1616995020000 with a delay of -939ms
+45ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 18ms > CE
+47ms ║Runtime (39520 bytes) successfully initialized in 6ms (v0.3.113.20210203) (46ms)
+48ms ║╔Execution stage started
+82ms ║║Cancelling statement #7’s schedules…
+286ms ║║Executed physical command [Outdoor lights simulated switch].off() (199ms)
+287ms ║║Executed [Outdoor lights simulated switch].off (202ms)
+293ms ║║Calculating (string) Switch turned off at: + (string) Mon, Mar 29 2021 @ 7:16:59 AM CEST >> (string) Switch turned off at: Mon, Mar 29 2021 @ 7:16:59 AM CEST
+296ms ║║Switch turned off at: Mon, Mar 29 2021 @ 7:16:59 AM CEST
+297ms ║║Executed virtual command [Outdoor lights simulated switch].log (1ms)
+301ms ║╚Execution stage complete. (252ms)
+303ms ║Setting up scheduled job for Mon, Mar 29 2021 @ 7:54:00 PM CEST (in 45420s), with 2 more jobs pending
+310ms ╚Event processed successfully (311ms)
3/29/2021, 12:00:59 AM +47ms
+1ms ╔Received event [My home].time = 1616968860000 with a delay of -953ms
+65ms ║RunTime Analysis CS > 46ms > PS > 4ms > PE > 14ms > CE
+67ms ║Runtime (39520 bytes) successfully initialized in 4ms (v0.3.113.20210203) (66ms)
+68ms ║╔Execution stage started
+78ms ║║Cancelling statement #9’s schedules…
+83ms ║║Updating sunrise and sunset variables
+84ms ║║Executed virtual command log (2ms)
+136ms ║║Calculating (string) sunrise: + (string) Mon, Mar 29 2021 @ 7:14:00 AM CEST >> (string) sunrise: Mon, Mar 29 2021 @ 7:14:00 AM CEST
+139ms ║║sunrise: Mon, Mar 29 2021 @ 7:14:00 AM CEST
+140ms ║║Executed virtual command log (1ms)
+146ms ║║Calculating (string) sunset: + (string) Mon, Mar 29 2021 @ 8:12:00 PM CEST >> (string) sunset: Mon, Mar 29 2021 @ 8:12:00 PM CEST
+149ms ║║sunset: Mon, Mar 29 2021 @ 8:12:00 PM CEST
+150ms ║║Executed virtual command log (1ms)
+153ms ║╚Execution stage complete. (85ms)
+155ms ║Setting up scheduled job for Mon, Mar 29 2021 @ 7:17:00 AM CEST (in 26160s), with 2 more jobs pending
+162ms ╚Event processed successfully (162ms)
3/28/2021, 6:51:59 PM +60ms
+0ms ╔Received event [My home].time = 1616950320000 with a delay of -940ms
+40ms ║RunTime Analysis CS > 19ms > PS > 5ms > PE > 16ms > CE
+42ms ║Runtime (39520 bytes) successfully initialized in 5ms (v0.3.113.20210203) (41ms)
+43ms ║╔Execution stage started
+70ms ║║Cancelling statement #2’s schedules…
+108ms ║║Executed physical command [Outdoor lights simulated switch].on() (35ms)
+109ms ║║Executed [Outdoor lights simulated switch].on (37ms)
+115ms ║║Calculating (string) Switch turned on at: + (string) Sun, Mar 28 2021 @ 6:51:59 PM CEST >> (string) Switch turned on at: Sun, Mar 28 2021 @ 6:51:59 PM CEST
+118ms ║║Switch turned on at: Sun, Mar 28 2021 @ 6:51:59 PM CEST
+119ms ║║Executed virtual command [Outdoor lights simulated switch].log (1ms)
+122ms ║╚Execution stage complete. (79ms)
+123ms ║Setting up scheduled job for Mon, Mar 29 2021 @ 12:01:00 AM CEST (in 18540s), with 2 more jobs pending
+129ms ╚Event processed successfully (129ms)
3/28/2021, 6:19:59 AM +66ms
+0ms ╔Received event [My home].time = 1616905200000 with a delay of -934ms
+37ms ║RunTime Analysis CS > 19ms > PS > 5ms > PE > 13ms > CE
+40ms ║Runtime (39520 bytes) successfully initialized in 5ms (v0.3.113.20210203) (38ms)
+40ms ║╔Execution stage started
+71ms ║║Cancelling statement #7’s schedules…
+108ms ║║Executed physical command [Outdoor lights simulated switch].off() (33ms)
+109ms ║║Executed [Outdoor lights simulated switch].off (34ms)
+114ms ║║Calculating (string) Switch turned off at: + (string) Sun, Mar 28 2021 @ 6:19:59 AM CEST >> (string) Switch turned off at: Sun, Mar 28 2021 @ 6:19:59 AM CEST
+118ms ║║Switch turned off at: Sun, Mar 28 2021 @ 6:19:59 AM CEST
+118ms ║║Executed virtual command [Outdoor lights simulated switch].log (1ms)
+121ms ║╚Execution stage complete. (81ms)
+123ms ║Setting up scheduled job for Sun, Mar 28 2021 @ 6:52:00 PM CEST (in 45120s), with 2 more jobs pending
3/28/2021, 12:01:08 AM +847ms
+1ms ╔Received event [My home].time = 1616886060000 with a delay of 8847ms
+245ms ║RunTime Analysis CS > 225ms > PS > 6ms > PE > 14ms > CE
+248ms ║Runtime (39522 bytes) successfully initialized in 6ms (v0.3.113.20210203) (247ms)
+249ms ║╔Execution stage started
+262ms ║║Cancelling statement #9’s schedules…
+267ms ║║Updating sunrise and sunset variables
+269ms ║║Executed virtual command log (1ms)
+706ms ║║Calculating (string) sunrise: + (string) Sun, Mar 28 2021 @ 6:17:00 AM CEST >> (string) sunrise: Sun, Mar 28 2021 @ 6:17:00 AM CEST
+710ms ║║sunrise: Sun, Mar 28 2021 @ 6:17:00 AM CEST
+711ms ║║Executed virtual command log (1ms)
+719ms ║║Calculating (string) sunset: + (string) Sun, Mar 28 2021 @ 7:09:00 PM CEST >> (string) sunset: Sun, Mar 28 2021 @ 7:09:00 PM CEST
+724ms ║║sunset: Sun, Mar 28 2021 @ 7:09:00 PM CEST
+725ms ║║Executed virtual command log (2ms)
+729ms ║╚Execution stage complete. (479ms)
+731ms ║Setting up scheduled job for Sun, Mar 28 2021 @ 6:20:00 AM CEST (in 19130s), with 2 more jobs pending
+738ms ╚Event processed successfully (737ms)
3/27/2021, 6:49:59 PM +59ms
+0ms ╔Received event [My home].time = 1616867400000 with a delay of -941ms
+43ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 16ms > CE
+45ms ║Runtime (39520 bytes) successfully initialized in 5ms (v0.3.113.20210203) (44ms)
+46ms ║╔Execution stage started
+79ms ║║Cancelling statement #2’s schedules…
+416ms ║║Executed physical command [Outdoor lights simulated switch].on() (334ms)
+417ms ║║Executed [Outdoor lights simulated switch].on (336ms)
+424ms ║║Calculating (string) Switch turned on at: + (string) Sat, Mar 27 2021 @ 6:49:59 PM CET >> (string) Switch turned on at: Sat, Mar 27 2021 @ 6:49:59 PM CET
+428ms ║║Switch turned on at: Sat, Mar 27 2021 @ 6:49:59 PM CET
+429ms ║║Executed virtual command [Outdoor lights simulated switch].log (1ms)
+433ms ║╚Execution stage complete. (387ms)
+435ms ║Setting up scheduled job for Sun, Mar 28 2021 @ 12:01:00 AM CET (in 18660s), with 2 more jobs pending
+443ms ╚Event processed successfully (443ms)
3/27/2021, 6:22:59 AM +60ms
+126ms ║Switch turned off at: Sat, Mar 27 2021 @ 6:22:59 AM CET
3/27/2021, 12:01:01 AM +672ms
+281ms ║Updating sunrise and sunset variables
+476ms ║sunrise: Sat, Mar 27 2021 @ 6:20:00 AM CET
+487ms ║sunset: Sat, Mar 27 2021 @ 7:07:00 PM CET
3/26/2021, 6:46:59 PM +59ms
+359ms ║Switch turned on at: Fri, Mar 26 2021 @ 6:46:59 PM CET
3/26/2021, 6:25:59 AM +66ms
+114ms ║Switch turned off at: Fri, Mar 26 2021 @ 6:25:59 AM CET
3/26/2021, 12:01:03 AM +3ms
+250ms ║Updating sunrise and sunset variables
+504ms ║sunrise: Fri, Mar 26 2021 @ 6:23:00 AM CET
+512ms ║sunset: Fri, Mar 26 2021 @ 7:05:00 PM CET
