[Resolved] Using "For Each" to cycle devices and change attributes
I am trying to use a “for each” along with a couple of variables to set the volume individually on each Sonos Player. Is this correct approach?
Note: Currently to test it I am using its External URL to trigger the piston and hardcoding the PlayListSwitchChosen, manually changing it for each test.
This is only part of a larger piston I am working on, but I wanted to get this part working first because I am not quite clear on the use of “for each”. As an FYI, I have individual tested each of the variable expression and they are working.
The piston cycles through each Player and sets it appropriate volume using lookup expressions based on:
Players’ > PlayerVolumeToSet and PlayerList
Play list’s > PlayListIDList and PlayListSwitchList
Each Player’s Default Volume > DefaultVolumeList and VolumeModifierList
Nothing, the piston is not changing the volume at all. However, if I remove the “Set variable” line and hardcode a value into the setVolume line it works but it of course sets all the Players at the same volume, which is not the desired outcome.
3/25/2021, 2:10:05 PM +606ms
+0ms ╔Received event [My home].execute = 104.206.12.223 with a delay of 257ms
+147ms ║RunTime Analysis CS > 24ms > PS > 17ms > PE > 107ms > CE
+150ms ║Runtime (49180 bytes) successfully initialized in 17ms (v0.3.113.20210203) (149ms)
+151ms ║╔Execution stage started
+162ms ║║Cancelling statement #26’s schedules…
+167ms ║║Executed virtual command [Bedroom Player].setVariable (1ms)
+186ms ║║Executed physical command [Bedroom Player].setVolume([(round(PlayerDefaultVolume)(VolumeModifierChosen))]) (15ms)
+187ms ║║Executed [Bedroom Player].setVolume (17ms)
+195ms ║║Cancelling statement #26’s schedules…
+200ms ║║Executed virtual command [Kitchen Player].setVariable (1ms)
+212ms ║║Executed physical command [Kitchen Player].setVolume([(round(PlayerDefaultVolume)
(VolumeModifierChosen))]) (8ms)
+213ms ║║Executed [Kitchen Player].setVolume (11ms)
+221ms ║║Cancelling statement #26’s schedules…
+225ms ║║Executed virtual command [Laundry Player].setVariable (1ms)
+237ms ║║Executed physical command [Laundry Player].setVolume([(round(PlayerDefaultVolume)(VolumeModifierChosen))]) (9ms)
+238ms ║║Executed [Laundry Player].setVolume (10ms)
+246ms ║║Cancelling statement #26’s schedules…
+251ms ║║Executed virtual command [Living Player].setVariable (1ms)
+274ms ║║Executed physical command [Living Player].setVolume([(round(PlayerDefaultVolume)
(VolumeModifierChosen))]) (19ms)
+275ms ║║Executed [Living Player].setVolume (21ms)
+284ms ║║Cancelling statement #26’s schedules…
+289ms ║║Executed virtual command [Office Player].setVariable (1ms)
+302ms ║║Executed physical command [Office Player].setVolume([(round(PlayerDefaultVolume)(VolumeModifierChosen))]) (9ms)
+303ms ║║Executed [Office Player].setVolume (11ms)
+311ms ║║Cancelling statement #26’s schedules…
+316ms ║║Executed virtual command [Quin Room Player].setVariable (0ms)
+328ms ║║Executed physical command [Quin Room Player].setVolume([(round(PlayerDefaultVolume)
+329ms ║║Executed [Quin Room Player].setVolume (10ms)
+337ms ║║Cancelling statement #26’s schedules…
+341ms ║║Executed virtual command [TV Room Player].setVariable (1ms)
+353ms ║║Executed physical command [TV Room Player].setVolume([(round(PlayerDefaultVolume)*(VolumeModifierChosen))]) (9ms)
+354ms ║║Executed [TV Room Player].setVolume (11ms)
+357ms ║╚Execution stage complete. (205ms)
+358ms ╚Event processed successfully (358ms)
First glance, the setVolume parameter looks like it’s being sent as a string.
Edit: Change the field to Expression instead of Value
Thank you @eibyer, I completed missed that configuration requirement.
