I’ve noticed for some reason that my wife’s webCoRE Presence device is quickly changing from present to absent then back to present again when she returns home.
Log from my Presence piston is below, WC Presence is bolded:
2/13/2018, 5:23:17 PM +461ms
+1ms ╔Received event [Kery-Ann - WC Presence].presence = present with a delay of 95ms
+10029ms ║Piston waited at a semaphore for 9844ms
+10032ms ║Runtime (52636 bytes) successfully initialized in 9906ms (v0.2.102.20180116) (10030ms)
+10032ms ║╔Execution stage started
+10152ms ║║Executed virtual command setVariable (0ms)
+10154ms ║╚Execution stage complete. (122ms)
+10155ms ╚Event processed successfully (10155ms)
2/13/2018, 5:23:17 PM +233ms
+1ms ╔Received event [Guest Arrival].presence = present with a delay of 104ms
+136ms ║Runtime (52568 bytes) successfully initialized in 43ms (v0.2.102.20180116) (134ms)
+225ms ║║Executed virtual command setVariable (1ms)
+231ms ║║Executed [Kery-Ann].on (3ms)
+304ms ║║Executed virtual command sendPushNotification (19ms)
+313ms ║║Executed virtual command setVariable (1ms)
+315ms ║╚Execution stage complete. (179ms)
+316ms ╚Event processed successfully (316ms)
2/13/2018, 5:20:29 PM +473ms
+1ms ╔Received event [Kery-Ann - WC Presence].presence = not present with a delay of 98ms
+10333ms ║Piston waited at a semaphore for 10018ms
+10335ms ║Runtime (52651 bytes) successfully initialized in 10206ms (v0.2.102.20180116) (10326ms)
+10336ms ║╔Execution stage started
+10452ms ║║Executed virtual command setVariable (1ms)
+10454ms ║╚Execution stage complete. (118ms)
+10545ms ╚Event processed successfully (10545ms)
2/13/2018, 5:20:29 PM +109ms
+0ms ╔Received event [Kery-Ann’s iPhone (L360)].presence = present with a delay of 91ms
+9908ms ║Piston waited at a semaphore for 9768ms
+9911ms ║Runtime (52647 bytes) successfully initialized in 9811ms (v0.2.102.20180116) (9910ms)
+9912ms ║╔Execution stage started
+10039ms ║║Executed virtual command sendPushNotification (9ms)
+10050ms ║║Executed virtual command setVariable (0ms)
+10052ms ║╚Execution stage complete. (141ms)
+10053ms ╚Event processed successfully (10054ms)
2/13/2018, 5:20:29 PM +228ms
+0ms ╔Received event [Kery-Ann].switch = on with a delay of 190ms
+9681ms ║Piston waited at a semaphore for 9523ms
+9683ms ║Runtime (52625 bytes) successfully initialized in 9571ms (v0.2.102.20180116) (9682ms)
+9684ms ║╔Execution stage started
+9821ms ║║Executed virtual command sendPushNotification (8ms)
+9833ms ║║Executed virtual command setVariable (1ms)
+9835ms ║╚Execution stage complete. (151ms)
+9836ms ╚Event processed successfully (9837ms)
2/13/2018, 5:20:31 PM +720ms
+0ms ╔Received event [Home].mode = Home with a delay of 93ms
+140ms ║Runtime (52546 bytes) successfully initialized in 43ms (v0.2.102.20180116) (139ms)
+141ms ║╔Execution stage started
+273ms ║║Executed virtual command sendPushNotification (7ms)
+281ms ║║Executed virtual command setVariable (0ms)
+284ms ║╚Execution stage complete. (142ms)
+284ms ╚Event processed successfully (284ms)
2/13/2018, 5:20:29 PM +458ms
+0ms ╔Received event [Kery-Ann’s iPhone (ST)].presence = present with a delay of 92ms
+135ms ║Runtime (52578 bytes) successfully initialized in 44ms (v0.2.102.20180116) (134ms)
+410ms ║║Executed virtual command setVariable (0ms)
+416ms ║║Executed [Kery-Ann].on (4ms)
+471ms ║║Executed virtual command setVariable (0ms)
+473ms ║╚Execution stage complete. (338ms)
+474ms ╚Event processed successfully (474ms)
2/13/2018, 5:20:28 PM +636ms
+1ms ╔Received event [Kery-Ann - WC Presence].presence = present with a delay of 222ms
+165ms ║Runtime (52583 bytes) successfully initialized in 64ms (v0.2.102.20180116) (163ms)
+166ms ║╔Execution stage started
+255ms ║║Executed virtual command setVariable (1ms)
+526ms ║║Executed [Kery-Ann].on (268ms)
+581ms ║║Executed virtual command setVariable (1ms)
+583ms ║╚Execution stage complete. (418ms)
+584ms ╚Event processed successfully (584ms)
Any idea what might be going on? It switches from Present then to Away within 1 second of each other (at the same time that the Life360 and SmartThings presence sensors report her as “arrived”) then WC Presence changes back to “present” 3 minutes later.
