16 device limit
What and where is this an issue? Is this per Variable or what?
This is just with the Piston Tiles on one piston regardless if it’s a device, expression, variable, virtual device, etc… If you want more than 16 tiles, just split into multiple pistons to get around this limit.
It was originally a 6 tile limit… we did some arm bending in the early days and got @ady624 to bump it up to 16 haha!
As noted above, that’s per piston so you can still stack up as many tiles as you like in the dashboard using multiple pistons.
