Folks,
I’m trying to create a simple piston that makes my Echo speak when the doorbell (Ring) is pushed and then only if I answer it speaks again.
The first IF works - when the doorbell is rung, my Echo devices speak. The 2nd will not run.
I’m a complete novice at Piston design - though I am trying to learn.
I’ve considered the first IF running and then firing another piston with the 2nd IF - but I don’t know how to limit the 2nd Piston from running every time the door is opened and closed.
Does anyone have any ideas?
Cheers,
Rich
