I created a webcore piston that I felt would allow two third reality switches to be used on a 3 way switch. The plan was to setup a virtual switch that I used to keep track of the light being off and on. Anytime I physically pressed either of the third reality switches it would toggle the virtual switch. Webcore has a setting to only respond to a physical interaction. I then setup all my apps to control the virtual switch and when they turned the virtual switch off or on it would then toggle the third reality switch I labeled as the master.
After initially sync the light with the virtual switch if I press a third reality switch it toggles the virtual switch. If I send a software update to the virtual switch then I want it to toggle one third reality switch, which would change the state of the light
The problem is when I send a software update from webcore to toggle a third reality switch, not a physical interaction, It treats it as a physical interaction and toggles the virtual switch. At this point the switch is no longer in sync with the light.
Switch 35 and 39 are the third reality switches. 36 is the virtual switch
[image|45x37]
