This piston just went wrong about 4 days back…I didn’t touch it, i swear!
I have a 2nd exact piston which works fine, so to try and fix the problem, I created a copy of the working one, but still it doesn’t work. I even renamed it slightly difference, etc.
After 19:30pm, the piston should stop turning the lights on.
It turns the lights on all day and night. It first started at midnight and went on through out the night, no one got any sleep until 4am when I had the clever idea of pausing the piston.
22/04/2020, 17:18:00 +396ms
+1ms ╔Received event [Landing Light].switch = on with a delay of 52ms
+95ms ║RunTime Analysis CS > 16ms > PS > 40ms > PE > 39ms > CE
+98ms ║Runtime (42508 bytes) successfully initialized in 40ms (v0.3.110.20191009) (96ms)
+107ms ║║Cancelling condition #5’s schedules…
+108ms ║║Condition #5 evaluated false (6ms)
+109ms ║║Cancelling condition #1’s schedules…
+110ms ║║Condition group #1 evaluated false (state changed) (8ms)
+117ms ║║Condition #12 evaluated false (5ms)
+118ms ║║Condition group #8 evaluated false (state did not change) (6ms)
+123ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+124ms ║║Cancelling condition #18’s schedules…
+125ms ║║Condition #18 evaluated true (5ms)
+126ms ║║Cancelling condition #14’s schedules…
+127ms ║║Condition group #14 evaluated true (state changed) (7ms)
+132ms ║║Comparison (boolean) true is (boolean) true = true (1ms)
+134ms ║║Condition #30 evaluated true (4ms)
+135ms ║║Condition group #27 evaluated true (state did not change) (5ms)
+137ms ║║Cancelling statement #28’s schedules…
+142ms ║║Executed virtual command setVariable (2ms)
+148ms ║║Comparison (enum) on changes_to (string) off = false (0ms)
+149ms ║║Condition #26 evaluated false (4ms)
+150ms ║║Condition group #23 evaluated false (state did not change) (5ms)
+152ms ║╚Execution stage complete. (54ms)
+153ms ╚Event processed successfully (153ms)
22/04/2020, 17:17:58 +794ms
+1ms ╔Received event [Landing Motion Sensor].motion = active with a delay of 79ms
+108ms ║RunTime Analysis CS > 16ms > PS > 49ms > PE > 42ms > CE
+110ms ║Runtime (42524 bytes) successfully initialized in 49ms (v0.3.110.20191009) (108ms)
+111ms ║╔Execution stage started
+119ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+120ms ║║Cancelling condition #5’s schedules…
+121ms ║║Condition #5 evaluated true (5ms)
+128ms ║║Comparison (enum) off is (string) off = true (1ms)
+130ms ║║Condition #6 evaluated true (8ms)
+163ms ║║Comparison (time) 62278925 is_between (time) 1587582600000 … (time) 70200000 = true (8ms)
+165ms ║║Time restriction check passed
+166ms ║║Condition #32 evaluated true (35ms)
+167ms ║║Cancelling condition #1’s schedules…
+168ms ║║Condition group #1 evaluated true (state changed) (53ms)
+170ms ║║Cancelling statement #2’s schedules…
+270ms ║║Executed physical command [Landing Light].on() (97ms)
+272ms ║║Executed [Landing Light].on (99ms)
+277ms ║║Executed virtual command [Landing Light].setVariable (2ms)
+283ms ║║Comparison (enum) active changes_to (string) inactive = false (0ms)
+284ms ║║Condition #12 evaluated false (4ms)
+285ms ║║Condition group #8 evaluated false (state did not change) (6ms)
+292ms ║║Condition #18 evaluated false (4ms)
+293ms ║║Condition group #14 evaluated false (state did not change) (6ms)
+300ms ║║Condition #26 evaluated false (4ms)
+301ms ║║Condition group #23 evaluated false (state did not change) (6ms)
+303ms ║╚Execution stage complete. (192ms)
+304ms ╚Event processed successfully (304ms)
22/04/2020, 17:17:50 +962ms
+1ms ╔Starting piston… (v0.3.110.20191009)
+607ms ║╔Subscribing to devices…
+652ms ║║Subscribing to Landing Motion Sensor.motion…
+664ms ║║Subscribing to Landing Light.switch…
+847ms ║╚Finished subscribing (244ms)
+871ms ║Cancelling condition #5’s schedules…
+878ms ║Comparison (enum) off is (string) off = true (2ms)
+880ms ║Cancelling condition #6’s schedules…
+974ms ║Comparison (time) 62271895 is_between (time) 1587582600000 … (time) 70200000 = true (10ms)
+976ms ║Time restriction check passed
+990ms ║Comparison (boolean) true is (boolean) true = true (1ms)
+1004ms ║Comparison (boolean) true is (boolean) true = true (1ms)
+1021ms ╚Piston successfully started (1021ms)
21/04/2020, 20:12:26 +110ms
+10134ms ║Piston waited at a semaphore for 10013ms
Any help would be grateful please, as for my life I can’t see logic as to why even a copy of a working piston doesn’t work
