Hi,
I just made a fresh piston to control 3 of my Air Conditioners, I haven’t actually tested it yet but there’s somethings I would like to add but Im not entirely sure how-to. I struggled quite abit to make this piston and this is pretty much what I was capable of doing.
I set restriction to only happen during the day but what I would like is to also have a way to control my AC’s during the night but with a lower temperature conditions, do I need to make this piston from scratch and have the same piston but set a restriction for night time or is there a better way to handle “day / night” conditions?
Second question, kinda two in one type of question.
Instead of having set temperature conditions like the piston have below, can I somehow add a way to set the temperature conditions and the sensor’s conditions take reading from that instead of having to manually edit all temperature conditions?
Say if I feel like I would like to have it warmer certain days I could just flip a switch or edit two values instead of all of them in the piston?
Lastly, this piston is made to have a better energy consumption / stable temperature in the house and for me this one is easy since I have fixed working hours when I’m not home but my wife doesn’t. She could work late some days, early others and some days at home.
Is there a way to add a condition so this pistons only runs when we’re actually home?
Unfortunately I wasn’t able to install the smartthing app on her phone because somehow it says we’re from different regions so I couldn’t invite her to our “home”
I’m not sure how to fix this issue since both our phones are bought in Sweden so I’m not sure where this “region” thing is coming from so having to check if she’s working or not I’m clueless?
Anyone could help me out here?
Thanks alot for taking your time!
Best regards,
-Dixon
