Lights turning back on after switching off
Lights to remain off when requested
When multiple lights are turned off at the same time, say for example a lighting group or an away scene to turn off all lights. This causes some of the lights to switch back on.
For some additional background on my piston set up (of which this is one of two). Basically at night time specifically at 8pm it will dim my lights and change the colour temp IF the light is on. However there is a few qerks to this piston. Such as if I turn on my office light it will reset all of the lights that are currently on. Meaning if I had set the lounge room to be dimmer then preset in my rule it will increase the brightness.
One of the other qerks which is more annoying is when I turn off multiple lights off simultaneously either through a rule/scene/lighting group it will cause some of the lights to switch back on.
I suspect this is due to webCoRE taking a point in time view as to what lights are on when the rule starts so If light C is one when I turn off A, B & C it turns it back on as per my piston.
One way around this which I have fixed for my bedtime routine is once I close my bedroom door at night it will turn off light A instantly, light B off in 10 seconds, light c off in 20 seconds and so on. This ensures all lights get turned off and I don’t wake up in the morning with all lights on unexpectedly.
Hope that explains my problem well enough
4) Post a Green Snapshot of the piston!)
(UPLOAD YOUR IMAGE HERE)
11/23/2020, 8:17:02 PM +85ms
+0ms ╔Received event [BKTS Home].time = 1606126621772 with a delay of 313ms
+90ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 63ms > CE
+93ms ║Runtime (42988 bytes) successfully initialized in 6ms (v0.3.110.20191009) (92ms)
+123ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (7ms)
+123ms ║║Executed [Guest Room Light].setLevel (8ms)
+158ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (7ms)
+159ms ║║Executed [Play Room Light].setLevel (8ms)
+161ms ║╚Execution stage complete. (68ms)
+162ms ╚Event processed successfully (162ms)
11/23/2020, 8:16:49 PM +567ms
+1ms ╔Received event [Our Light].switch = on with a delay of 38ms
+10092ms ║RunTime Analysis CS > 11ms > PS > 10016ms > PE > 65ms > CE
+10093ms ║Piston waited at a semaphore for 10013ms
+10096ms ║Runtime (43064 bytes) successfully initialized in 10016ms (v0.3.110.20191009) (10094ms)
+10096ms ║╔Execution stage started
+10104ms ║║Comparison (enum) off is (string) off = true (1ms)
+10105ms ║║Condition #1 evaluated true (6ms)
+10109ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10110ms ║║Condition #2 evaluated true (3ms)
+10110ms ║║Condition group #null evaluated true (state did not change) (11ms)
+10115ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10116ms ║║Condition #16 evaluated true (4ms)
+10117ms ║║Condition group #15 evaluated true (state did not change) (4ms)
+10125ms ║║Comparison (enum) off is (string) on = false (1ms)
+10126ms ║║Condition #4 evaluated false (7ms)
+10127ms ║║Condition group #3 evaluated false (state did not change) (9ms)
+10132ms ║║Comparison (enum) on is (string) on = true (1ms)
+10133ms ║║Cancelling condition #8's schedules...
+10134ms ║║Condition #8 evaluated true (5ms)
+10135ms ║║Cancelling condition #7's schedules...
+10135ms ║║Condition group #7 evaluated true (state changed) (6ms)
+10143ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+10144ms ║║Condition #21 evaluated false (7ms)
+10145ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+10169ms ║║Comparison (enum) on is (string) on = true (1ms)
+10170ms ║║Condition #12 evaluated true (23ms)
+10171ms ║║Condition group #11 evaluated true (state did not change) (23ms)
+10172ms ║║Cancelling statement #13's schedules...
+10200ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (25ms)
+10201ms ║║Executed [Guest Room Light].setColorTemperature (26ms)
+10203ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+10204ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:17:01 PM AEST (in 2.0s)
+10214ms ║║Comparison (enum) on is (string) on = true (1ms)
+10215ms ║║Condition #25 evaluated true (6ms)
+10215ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+10217ms ║║Cancelling statement #26's schedules...
+10235ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (15ms)
+10236ms ║║Executed [Play Room Light].setColorTemperature (17ms)
+10238ms ║║Executed virtual command [Play Room Light].wait (0ms)
+10239ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:17:01 PM AEST (in 2.0s)
+10242ms ║╚Execution stage complete. (146ms)
+10244ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:17:01 PM AEST (in 1.962s), with 1 more job pending
+10250ms ╚Event processed successfully (10249ms)
11/23/2020, 8:16:57 PM +60ms
+0ms ╔Received event [BKTS Home].time = 1606126616541 with a delay of 518ms
+84ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 60ms > CE
+86ms ║Runtime (42991 bytes) successfully initialized in 6ms (v0.3.110.20191009) (85ms)
+87ms ║╔Execution stage started
+117ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (7ms)
+118ms ║║Executed [Guest Room Light].setLevel (8ms)
+184ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (39ms)
+185ms ║║Executed [Play Room Light].setLevel (41ms)
+187ms ║╚Execution stage complete. (100ms)
+188ms ╚Event processed successfully (188ms)
11/23/2020, 8:16:44 PM +355ms
+0ms ╔Received event [Our Light].switch = off with a delay of 46ms
+10106ms ║RunTime Analysis CS > 10ms > PS > 10023ms > PE > 73ms > CE
+10107ms ║Piston waited at a semaphore for 10020ms
+10109ms ║Runtime (43059 bytes) successfully initialized in 10023ms (v0.3.110.20191009) (10108ms)
+10110ms ║╔Execution stage started
+10118ms ║║Comparison (enum) off is (string) off = true (1ms)
+10120ms ║║Condition #1 evaluated true (7ms)
+10123ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10124ms ║║Condition #2 evaluated true (4ms)
+10125ms ║║Condition group #null evaluated true (state did not change) (13ms)
+10129ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10131ms ║║Condition #16 evaluated true (4ms)
+10132ms ║║Condition group #15 evaluated true (state did not change) (4ms)
+10140ms ║║Comparison (enum) off is (string) on = false (1ms)
+10141ms ║║Condition #4 evaluated false (7ms)
+10142ms ║║Condition group #3 evaluated false (state did not change) (8ms)
+10147ms ║║Comparison (enum) off is (string) on = false (1ms)
+10148ms ║║Cancelling condition #8's schedules...
+10149ms ║║Condition #8 evaluated false (5ms)
+10150ms ║║Cancelling condition #7's schedules...
+10151ms ║║Condition group #7 evaluated false (state changed) (7ms)
+10159ms ║║Comparison (enum) on is (string) on = true (1ms)
+10160ms ║║Condition #12 evaluated true (7ms)
+10161ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+10163ms ║║Cancelling statement #13's schedules...
+10182ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (16ms)
+10182ms ║║Executed [Guest Room Light].setColorTemperature (17ms)
+10185ms ║║Executed virtual command [Guest Room Light].wait (1ms)
+10186ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 2.0s)
+10195ms ║║Comparison (enum) on is (string) on = true (1ms)
+10197ms ║║Condition #25 evaluated true (7ms)
+10197ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+10199ms ║║Cancelling statement #26's schedules...
+10217ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (14ms)
+10217ms ║║Executed [Play Room Light].setColorTemperature (16ms)
+10220ms ║║Executed virtual command [Play Room Light].wait (1ms)
+10221ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 2.0s)
+10224ms ║╚Execution stage complete. (113ms)
+10225ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 1.962s), with 1 more job pending
+10233ms ╚Event processed successfully (10233ms)
11/23/2020, 8:16:45 PM +347ms
+1ms ╔Received event [Play Room Light].switch = off with a delay of 37ms
+9091ms ║RunTime Analysis CS > 10ms > PS > 9026ms > PE > 55ms > CE
+9092ms ║Piston waited at a semaphore for 9023ms
+9095ms ║Runtime (43059 bytes) successfully initialized in 9026ms (v0.3.110.20191009) (9093ms)
+9095ms ║╔Execution stage started
+9103ms ║║Comparison (enum) off is (string) off = true (1ms)
+9104ms ║║Condition #1 evaluated true (6ms)
+9107ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+9108ms ║║Condition #2 evaluated true (3ms)
+9109ms ║║Condition group #null evaluated true (state did not change) (12ms)
+9113ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+9114ms ║║Condition #16 evaluated true (3ms)
+9115ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+9123ms ║║Comparison (enum) off is (string) on = false (1ms)
+9124ms ║║Condition #4 evaluated false (7ms)
+9125ms ║║Condition group #3 evaluated false (state did not change) (8ms)
+9133ms ║║Comparison (enum) on is (string) on = true (1ms)
+9134ms ║║Condition #8 evaluated true (7ms)
+9135ms ║║Condition group #7 evaluated true (state did not change) (8ms)
+9142ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+9144ms ║║Condition #21 evaluated false (6ms)
+9144ms ║║Condition group #9 evaluated false (state did not change) (7ms)
+9152ms ║║Comparison (enum) on is (string) on = true (1ms)
+9154ms ║║Condition #12 evaluated true (7ms)
+9154ms ║║Condition group #11 evaluated true (state did not change) (8ms)
+9156ms ║║Cancelling statement #13's schedules...
+9176ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (17ms)
+9177ms ║║Executed [Guest Room Light].setColorTemperature (19ms)
+9180ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+9181ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 2.0s)
+9187ms ║║Comparison (enum) off is (string) on = false (1ms)
+9188ms ║║Cancelling condition #25's schedules...
+9189ms ║║Condition #25 evaluated false (4ms)
+9189ms ║║Cancelling condition #24's schedules...
+9190ms ║║Condition group #24 evaluated false (state changed) (6ms)
+9192ms ║╚Execution stage complete. (97ms)
+9193ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 1.989s)
+9203ms ╚Event processed successfully (9202ms)
11/23/2020, 8:16:44 PM +193ms
+2ms ╔Received event [Lounge Room Light].switch = off with a delay of 72ms
+10094ms ║RunTime Analysis CS > 20ms > PS > 10017ms > PE > 57ms > CE
+10095ms ║Piston waited at a semaphore for 10013ms
+10097ms ║Runtime (43067 bytes) successfully initialized in 10017ms (v0.3.110.20191009) (10095ms)
+10098ms ║╔Execution stage started
+10106ms ║║Comparison (enum) off is (string) off = true (1ms)
+10107ms ║║Condition #1 evaluated true (7ms)
+10110ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10112ms ║║Condition #2 evaluated true (3ms)
+10112ms ║║Condition group #null evaluated true (state did not change) (12ms)
+10116ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10118ms ║║Condition #16 evaluated true (3ms)
+10118ms ║║Condition group #15 evaluated true (state did not change) (4ms)
+10123ms ║║Comparison (enum) off is (string) on = false (1ms)
+10124ms ║║Condition #4 evaluated false (4ms)
+10125ms ║║Condition group #3 evaluated false (state did not change) (5ms)
+10135ms ║║Comparison (enum) on is (string) on = true (1ms)
+10136ms ║║Condition #8 evaluated true (9ms)
+10137ms ║║Condition group #7 evaluated true (state did not change) (10ms)
+10144ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+10146ms ║║Condition #21 evaluated false (6ms)
+10146ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+10155ms ║║Comparison (enum) on is (string) on = true (1ms)
+10156ms ║║Condition #12 evaluated true (7ms)
+10157ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+10159ms ║║Cancelling statement #13's schedules...
+10186ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (25ms)
+10187ms ║║Executed [Guest Room Light].setColorTemperature (26ms)
+10189ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+10190ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 2.0s)
+10200ms ║║Comparison (enum) on is (string) on = true (1ms)
+10201ms ║║Condition #25 evaluated true (7ms)
+10202ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+10204ms ║║Cancelling statement #26's schedules...
+10228ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (21ms)
+10228ms ║║Executed [Play Room Light].setColorTemperature (22ms)
+10231ms ║║Executed virtual command [Play Room Light].wait (1ms)
+10232ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 2.0s)
+10235ms ║╚Execution stage complete. (137ms)
+10236ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:16:56 PM AEST (in 1.955s), with 1 more job pending
+10243ms ╚Event processed successfully (10243ms)
11/23/2020, 8:16:45 PM +43ms
+1ms ╔Received event [BKTS Home].time = 1606126603947 with a delay of 1096ms
+9334ms ║RunTime Analysis CS > 13ms > PS > 9268ms > PE > 53ms > CE
+9335ms ║Piston waited at a semaphore for 9265ms
+9337ms ║Runtime (43063 bytes) successfully initialized in 9268ms (v0.3.110.20191009) (9336ms)
+9338ms ║╔Execution stage started
+9339ms ║╚Execution stage complete. (1ms)
+9340ms ╚Event processed successfully (9340ms)
11/23/2020, 8:16:49 PM +564ms
+1ms ╔Received event [Our Light].switch = on with a delay of 35ms
+64ms ║RunTime Analysis CS > 10ms > PS > 4ms > PE > 50ms > CE
+66ms ║Runtime (42978 bytes) successfully initialized in 4ms (v0.3.110.20191009) (65ms)
+75ms ║║Comparison (enum) off is (string) off = true (1ms)
+76ms ║║Condition #1 evaluated true (7ms)
+79ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+80ms ║║Condition #2 evaluated true (3ms)
+81ms ║║Condition group #null evaluated true (state did not change) (12ms)
+85ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+86ms ║║Condition #16 evaluated true (3ms)
+87ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+95ms ║║Comparison (enum) off is (string) on = false (1ms)
+97ms ║║Condition #4 evaluated false (7ms)
+97ms ║║Condition group #3 evaluated false (state did not change) (8ms)
+102ms ║║Comparison (enum) on is (string) on = true (1ms)
+103ms ║║Cancelling condition #8's schedules...
+104ms ║║Condition #8 evaluated true (5ms)
+105ms ║║Cancelling condition #7's schedules...
+106ms ║║Condition group #7 evaluated true (state changed) (7ms)
+113ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+115ms ║║Condition #21 evaluated false (7ms)
+115ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+124ms ║║Comparison (enum) on is (string) on = true (1ms)
+125ms ║║Condition #12 evaluated true (8ms)
+126ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+128ms ║║Cancelling statement #13's schedules...
+147ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (16ms)
+147ms ║║Executed [Guest Room Light].setColorTemperature (17ms)
+150ms ║║Executed virtual command [Guest Room Light].wait (1ms)
+151ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:51 PM AEST (in 2.0s)
+160ms ║║Comparison (enum) on is (string) on = true (1ms)
+162ms ║║Condition #25 evaluated true (8ms)
+163ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+164ms ║║Cancelling statement #26's schedules...
+183ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (16ms)
+184ms ║║Executed [Play Room Light].setColorTemperature (17ms)
+186ms ║║Executed virtual command [Play Room Light].wait (0ms)
+187ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:51 PM AEST (in 2.0s)
+191ms ║║Fast executing schedules, waiting for 1962ms to sync up
+2176ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (6ms)
+2177ms ║║Executed [Guest Room Light].setLevel (8ms)
+2179ms ║║Fast executing schedules, waiting for 9ms to sync up
+2213ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (5ms)
+2214ms ║║Executed [Play Room Light].setLevel (7ms)
+2216ms ║╚Execution stage complete. (2149ms)
+2217ms ╚Event processed successfully (2217ms)
11/23/2020, 8:16:46 PM +882ms
+1ms ╔Received event [Play Room Light].switch = on with a delay of 44ms
+75ms ║RunTime Analysis CS > 10ms > PS > 3ms > PE > 62ms > CE
+77ms ║Runtime (42981 bytes) successfully initialized in 3ms (v0.3.110.20191009) (75ms)
+78ms ║╔Execution stage started
+86ms ║║Comparison (enum) off is (string) off = true (0ms)
+87ms ║║Condition #1 evaluated true (7ms)
+90ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+91ms ║║Condition #2 evaluated true (4ms)
+92ms ║║Condition group #null evaluated true (state did not change) (12ms)
+96ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+97ms ║║Condition #16 evaluated true (3ms)
+98ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+106ms ║║Comparison (enum) off is (string) on = false (1ms)
+108ms ║║Condition #4 evaluated false (8ms)
+109ms ║║Condition group #3 evaluated false (state did not change) (8ms)
+117ms ║║Comparison (enum) off is (string) on = false (0ms)
+118ms ║║Cancelling condition #8's schedules...
+119ms ║║Condition #8 evaluated false (7ms)
+120ms ║║Cancelling condition #7's schedules...
+120ms ║║Condition group #7 evaluated false (state changed) (10ms)
+128ms ║║Comparison (enum) on is (string) on = true (1ms)
+130ms ║║Condition #12 evaluated true (7ms)
+130ms ║║Condition group #11 evaluated true (state did not change) (8ms)
+132ms ║║Cancelling statement #13's schedules...
+154ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (19ms)
+155ms ║║Executed [Guest Room Light].setColorTemperature (21ms)
+157ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+159ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:49 PM AEST (in 2.0s)
+165ms ║║Comparison (enum) on is (string) on = true (1ms)
+167ms ║║Condition #25 evaluated true (4ms)
+167ms ║║Condition group #24 evaluated true (state did not change) (5ms)
+169ms ║║Cancelling statement #26's schedules...
+188ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (16ms)
+189ms ║║Executed [Play Room Light].setColorTemperature (17ms)
+248ms ║║Executed virtual command [Play Room Light].wait (1ms)
+249ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:49 PM AEST (in 2.0s)
+253ms ║║Fast executing schedules, waiting for 1907ms to sync up
+2185ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (7ms)
+2185ms ║║Executed [Guest Room Light].setLevel (9ms)
+2187ms ║║Fast executing schedules, waiting for 63ms to sync up
+2276ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (6ms)
+2277ms ║║Executed [Play Room Light].setLevel (7ms)
+2279ms ║╚Execution stage complete. (2201ms)
+2280ms ╚Event processed successfully (2280ms)
11/23/2020, 8:16:44 PM +160ms
+0ms ╔Received event [Lounge Room Light].switch = off with a delay of 39ms
+76ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 60ms > CE
+79ms ║Runtime (42981 bytes) successfully initialized in 4ms (v0.3.110.20191009) (77ms)
+87ms ║║Comparison (enum) off is (string) off = true (1ms)
+89ms ║║Condition #1 evaluated true (7ms)
+92ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (0ms)
+93ms ║║Condition #2 evaluated true (4ms)
+94ms ║║Condition group #null evaluated true (state did not change) (11ms)
+98ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+99ms ║║Condition #16 evaluated true (4ms)
+100ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+105ms ║║Comparison (enum) off is (string) on = false (1ms)
+106ms ║║Cancelling condition #4's schedules...
+107ms ║║Condition #4 evaluated false (5ms)
+108ms ║║Cancelling condition #3's schedules...
+109ms ║║Condition group #3 evaluated false (state changed) (6ms)
+117ms ║║Comparison (enum) on is (string) on = true (1ms)
+118ms ║║Condition #8 evaluated true (7ms)
+119ms ║║Condition group #7 evaluated true (state did not change) (8ms)
+126ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+128ms ║║Condition #21 evaluated false (7ms)
+128ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+137ms ║║Comparison (enum) on is (string) on = true (1ms)
+138ms ║║Condition #12 evaluated true (7ms)
+139ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+140ms ║║Cancelling statement #13's schedules...
+159ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (16ms)
+160ms ║║Executed [Guest Room Light].setColorTemperature (17ms)
+163ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+164ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:46 PM AEST (in 2.0s)
+173ms ║║Comparison (enum) on is (string) on = true (1ms)
+174ms ║║Condition #25 evaluated true (7ms)
+175ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+177ms ║║Cancelling statement #26's schedules...
+196ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (15ms)
+196ms ║║Executed [Play Room Light].setColorTemperature (17ms)
+199ms ║║Executed virtual command [Play Room Light].wait (1ms)
+200ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:46 PM AEST (in 2.0s)
+204ms ║║Fast executing schedules, waiting for 1960ms to sync up
+2188ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (6ms)
+2189ms ║║Executed [Guest Room Light].setLevel (7ms)
+2191ms ║║Fast executing schedules, waiting for 11ms to sync up
+2238ms ║║Executed physical command [Play Room Light].setLevel([60]) (16ms)
+2239ms ║║Executed [Play Room Light].setLevel (17ms)
+2241ms ║╚Execution stage complete. (2161ms)
+2242ms ╚Event processed successfully (2241ms)
11/23/2020, 8:16:31 PM +804ms
+1ms ╔Received event [Lounge Room Light].switch = on with a delay of 52ms
+10084ms ║RunTime Analysis CS > 12ms > PS > 10019ms > PE > 52ms > CE
+10085ms ║Piston waited at a semaphore for 10016ms
+10087ms ║Runtime (43063 bytes) successfully initialized in 10019ms (v0.3.110.20191009) (10086ms)
+10088ms ║╔Execution stage started
+10096ms ║║Comparison (enum) off is (string) off = true (1ms)
+10097ms ║║Condition #1 evaluated true (7ms)
+10100ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10101ms ║║Condition #2 evaluated true (3ms)
+10102ms ║║Condition group #null evaluated true (state did not change) (12ms)
+10106ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10107ms ║║Condition #16 evaluated true (4ms)
+10108ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+10112ms ║║Comparison (enum) on is (string) on = true (1ms)
+10113ms ║║Condition #4 evaluated true (3ms)
+10114ms ║║Condition group #3 evaluated true (state did not change) (5ms)
+10116ms ║║Cancelling statement #5's schedules...
+10138ms ║║Executed physical command [Lounge Room Light].setColorTemperature([2513]) (19ms)
+10139ms ║║Executed [Lounge Room Light].setColorTemperature (20ms)
+10142ms ║║Executed virtual command [Lounge Room Light].wait (1ms)
+10143ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:43 PM AEST (in 2.0s)
+10152ms ║║Comparison (enum) on is (string) on = true (1ms)
+10153ms ║║Condition #8 evaluated true (7ms)
+10154ms ║║Condition group #7 evaluated true (state did not change) (8ms)
+10161ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+10163ms ║║Condition #21 evaluated false (6ms)
+10163ms ║║Condition group #9 evaluated false (state did not change) (8ms)
+10172ms ║║Comparison (enum) on is (string) on = true (1ms)
+10173ms ║║Condition #12 evaluated true (8ms)
+10173ms ║║Condition group #11 evaluated true (state did not change) (8ms)
+10175ms ║║Cancelling statement #13's schedules...
+10195ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (16ms)
+10195ms ║║Executed [Guest Room Light].setColorTemperature (18ms)
+10198ms ║║Executed virtual command [Guest Room Light].wait (1ms)
+10199ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:44 PM AEST (in 2.0s)
+10208ms ║║Comparison (enum) on is (string) on = true (1ms)
+10209ms ║║Condition #25 evaluated true (7ms)
+10210ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+10212ms ║║Cancelling statement #26's schedules...
+10231ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (17ms)
+10232ms ║║Executed [Play Room Light].setColorTemperature (18ms)
+10235ms ║║Executed virtual command [Play Room Light].wait (0ms)
+10236ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:44 PM AEST (in 2.0s)
+10238ms ║╚Execution stage complete. (151ms)
+10240ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:16:43 PM AEST (in 1.904s), with 2 more jobs pending
+10246ms ╚Event processed successfully (10246ms)
11/23/2020, 8:16:38 PM +35ms
+1ms ╔Received event [Our Light].switch = on with a delay of 39ms
+65ms ║RunTime Analysis CS > 10ms > PS > 6ms > PE > 48ms > CE
+67ms ║Runtime (42975 bytes) successfully initialized in 6ms (v0.3.110.20191009) (65ms)
+77ms ║║Condition #1 evaluated true (6ms)
+81ms ║║Condition group #null evaluated true (state did not change) (11ms)
+87ms ║║Condition group #15 evaluated true (state did not change) (4ms)
+95ms ║║Comparison (enum) on is (string) on = true (1ms)
+96ms ║║Condition #4 evaluated true (7ms)
+97ms ║║Condition group #3 evaluated true (state did not change) (8ms)
+99ms ║║Cancelling statement #5's schedules...
+117ms ║║Executed physical command [Lounge Room Light].setColorTemperature([2513]) (16ms)
+118ms ║║Executed [Lounge Room Light].setColorTemperature (17ms)
+121ms ║║Executed virtual command [Lounge Room Light].wait (0ms)
+122ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:40 PM AEST (in 2.0s)
+128ms ║║Comparison (enum) on is (string) on = true (0ms)
+129ms ║║Cancelling condition #8's schedules...
+130ms ║║Condition #8 evaluated true (4ms)
+130ms ║║Cancelling condition #7's schedules...
+131ms ║║Condition group #7 evaluated true (state changed) (6ms)
+139ms ║║Comparison (integer) 2 is_greater_than (integer) 40 = false (1ms)
+140ms ║║Condition #21 evaluated false (7ms)
+141ms ║║Condition group #9 evaluated false (state did not change) (9ms)
+149ms ║║Comparison (enum) on is (string) on = true (1ms)
+150ms ║║Condition #12 evaluated true (7ms)
+151ms ║║Condition group #11 evaluated true (state did not change) (8ms)
+152ms ║║Cancelling statement #13's schedules...
+170ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (15ms)
+171ms ║║Executed [Guest Room Light].setColorTemperature (16ms)
+173ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+174ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:40 PM AEST (in 2.0s)
+183ms ║║Comparison (enum) on is (string) on = true (1ms)
+185ms ║║Condition #25 evaluated true (6ms)
+185ms ║║Condition group #24 evaluated true (state did not change) (8ms)
+187ms ║║Cancelling statement #26's schedules...
+204ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (15ms)
+205ms ║║Executed [Play Room Light].setColorTemperature (16ms)
+207ms ║║Executed virtual command [Play Room Light].wait (0ms)
+208ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:40 PM AEST (in 2.0s)
+211ms ║║Fast executing schedules, waiting for 1911ms to sync up
+2139ms ║║Skipped execution of physical command [Lounge Room Light].setLevel([60]) because it would make no change to the device. (6ms)
+2140ms ║║Executed [Lounge Room Light].setLevel (7ms)
+2142ms ║║Fast executing schedules, waiting for 33ms to sync up
+2198ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (6ms)
+2199ms ║║Executed [Guest Room Light].setLevel (7ms)
+2201ms ║║Fast executing schedules, waiting for 9ms to sync up
+2236ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (6ms)
+2237ms ║║Executed [Play Room Light].setLevel (7ms)
+2238ms ║╚Execution stage complete. (2171ms)
+2239ms ╚Event processed successfully (2239ms)
11/23/2020, 8:16:31 PM +792ms
+1ms ╔Received event [Play Room Light].switch = on with a delay of 39ms
+82ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 65ms > CE
+84ms ║Runtime (42990 bytes) successfully initialized in 4ms (v0.3.110.20191009) (82ms)
+94ms ║║Comparison (enum) off is (string) off = true (1ms)
+95ms ║║Condition #1 evaluated true (7ms)
+99ms ║║Condition #2 evaluated true (3ms)
+100ms ║║Condition group #null evaluated true (state did not change) (12ms)
+105ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+106ms ║║Condition #16 evaluated true (4ms)
+107ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+116ms ║║Comparison (enum) on is (string) on = true (1ms)
+117ms ║║Cancelling condition #4's schedules...
+118ms ║║Condition #4 evaluated true (9ms)
+119ms ║║Cancelling condition #3's schedules...
+120ms ║║Condition group #3 evaluated true (state changed) (10ms)
+121ms ║║Cancelling statement #5's schedules...
+143ms ║║Executed physical command [Lounge Room Light].setColorTemperature([2513]) (19ms)
+144ms ║║Executed [Lounge Room Light].setColorTemperature (20ms)
+147ms ║║Executed virtual command [Lounge Room Light].wait (0ms)
+148ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:33 PM AEST (in 2.0s)
+181ms ║║Comparison (enum) off is (string) on = false (1ms)
+183ms ║║Condition #8 evaluated false (31ms)
+184ms ║║Condition group #7 evaluated false (state did not change) (32ms)
+193ms ║║Comparison (enum) on is (string) on = true (1ms)
+194ms ║║Condition #12 evaluated true (8ms)
+195ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+197ms ║║Cancelling statement #13's schedules...
+217ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (17ms)
+218ms ║║Executed [Guest Room Light].setColorTemperature (18ms)
+220ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+221ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:34 PM AEST (in 2.0s)
+228ms ║║Comparison (enum) on is (string) on = true (1ms)
+229ms ║║Cancelling condition #25's schedules...
+230ms ║║Condition #25 evaluated true (4ms)
+231ms ║║Cancelling condition #24's schedules...
+231ms ║║Condition group #24 evaluated true (state changed) (7ms)
+233ms ║║Cancelling statement #26's schedules...
+253ms ║║Executed physical command [Play Room Light].setColorTemperature([2513]) (17ms)
+254ms ║║Executed [Play Room Light].setColorTemperature (18ms)
+257ms ║║Executed virtual command [Play Room Light].wait (0ms)
+258ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:34 PM AEST (in 2.0s)
+261ms ║║Fast executing schedules, waiting for 1887ms to sync up
+2165ms ║║Skipped execution of physical command [Lounge Room Light].setLevel([60]) because it would make no change to the device. (6ms)
+2166ms ║║Executed [Lounge Room Light].setLevel (7ms)
+2169ms ║║Fast executing schedules, waiting for 54ms to sync up
+2248ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (7ms)
+2249ms ║║Executed [Guest Room Light].setLevel (8ms)
+2251ms ║║Fast executing schedules, waiting for 7ms to sync up
+2286ms ║║Skipped execution of physical command [Play Room Light].setLevel([60]) because it would make no change to the device. (6ms)
+2287ms ║║Executed [Play Room Light].setLevel (8ms)
+2289ms ║╚Execution stage complete. (2204ms)
+2290ms ╚Event processed successfully (2290ms)
11/23/2020, 8:16:30 PM +67ms
+1ms ╔Received event [BKTS Home].time = 1606126589888 with a delay of 179ms
+77ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 50ms > CE
+80ms ║Runtime (42994 bytes) successfully initialized in 6ms (v0.3.110.20191009) (77ms)
+121ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (7ms)
+122ms ║║Executed [Guest Room Light].setLevel (8ms)
+125ms ║╚Execution stage complete. (45ms)
+127ms ╚Event processed successfully (126ms)
11/23/2020, 8:16:17 PM +727ms
+0ms ╔Received event [Play Room Light].switch = off with a delay of 34ms
+10075ms ║RunTime Analysis CS > 13ms > PS > 10016ms > PE > 46ms > CE
+10075ms ║Piston waited at a semaphore for 10012ms
+10078ms ║Runtime (43074 bytes) successfully initialized in 10016ms (v0.3.110.20191009) (10077ms)
+10079ms ║╔Execution stage started
+10088ms ║║Comparison (enum) off is (string) off = true (1ms)
+10089ms ║║Condition #1 evaluated true (8ms)
+10092ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10094ms ║║Condition #2 evaluated true (3ms)
+10094ms ║║Condition group #null evaluated true (state did not change) (13ms)
+10099ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+10100ms ║║Condition #16 evaluated true (4ms)
+10101ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+10110ms ║║Comparison (enum) off is (string) on = false (2ms)
+10111ms ║║Condition #4 evaluated false (8ms)
+10112ms ║║Condition group #3 evaluated false (state did not change) (9ms)
+10121ms ║║Comparison (enum) off is (string) on = false (1ms)
+10122ms ║║Condition #8 evaluated false (8ms)
+10123ms ║║Condition group #7 evaluated false (state did not change) (8ms)
+10131ms ║║Comparison (enum) on is (string) on = true (1ms)
+10133ms ║║Condition #12 evaluated true (7ms)
+10133ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+10135ms ║║Cancelling statement #13's schedules...
+10156ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (17ms)
+10157ms ║║Executed [Guest Room Light].setColorTemperature (18ms)
+10159ms ║║Executed virtual command [Guest Room Light].wait (0ms)
+10160ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:29 PM AEST (in 2.0s)
+10167ms ║║Comparison (enum) off is (string) on = false (1ms)
+10168ms ║║Condition #25 evaluated false (4ms)
+10169ms ║║Condition group #24 evaluated false (state did not change) (5ms)
+10171ms ║╚Execution stage complete. (93ms)
+10172ms ║Setting up scheduled job for Mon, Nov 23 2020 @ 8:16:29 PM AEST (in 1.99s)
+10178ms ╚Event processed successfully (10178ms)
11/23/2020, 8:16:17 PM +563ms
+1ms ╔Received event [Lounge Room Light].switch = off with a delay of 43ms
+65ms ║RunTime Analysis CS > 10ms > PS > 4ms > PE > 51ms > CE
+68ms ║Runtime (42984 bytes) successfully initialized in 4ms (v0.3.110.20191009) (65ms)
+77ms ║║Comparison (enum) off is (string) off = true (0ms)
+78ms ║║Condition #1 evaluated true (7ms)
+81ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+82ms ║║Condition #2 evaluated true (4ms)
+83ms ║║Condition group #null evaluated true (state did not change) (12ms)
+87ms ║║Comparison (string) :7ce977d20b2a079be9c264159385c191: is (string) :7ce977d20b2a079be9c264159385c191: = true (1ms)
+88ms ║║Condition #16 evaluated true (3ms)
+89ms ║║Condition group #15 evaluated true (state did not change) (5ms)
+94ms ║║Comparison (enum) off is (string) on = false (1ms)
+96ms ║║Cancelling condition #4's schedules...
+97ms ║║Condition #4 evaluated false (5ms)
+97ms ║║Cancelling condition #3's schedules...
+98ms ║║Condition group #3 evaluated false (state changed) (7ms)
+107ms ║║Comparison (enum) off is (string) on = false (1ms)
+108ms ║║Condition #8 evaluated false (8ms)
+109ms ║║Condition group #7 evaluated false (state did not change) (9ms)
+118ms ║║Condition #12 evaluated true (7ms)
+119ms ║║Condition group #11 evaluated true (state did not change) (9ms)
+121ms ║║Cancelling statement #13's schedules...
+145ms ║║Executed physical command [Guest Room Light].setColorTemperature([2513]) (22ms)
+146ms ║║Executed [Guest Room Light].setColorTemperature (22ms)
+148ms ║║Executed virtual command [Guest Room Light].wait (1ms)
+149ms ║║Requesting a wake up for Mon, Nov 23 2020 @ 8:16:19 PM AEST (in 2.0s)
+158ms ║║Comparison (enum) off is (string) on = false (1ms)
+160ms ║║Cancelling condition #25's schedules...
+160ms ║║Condition #25 evaluated false (8ms)
+161ms ║║Cancelling condition #24's schedules...
+162ms ║║Condition group #24 evaluated false (state changed) (10ms)
+164ms ║║Fast executing schedules, waiting for 1986ms to sync up
+2174ms ║║Skipped execution of physical command [Guest Room Light].setLevel([50]) because it would make no change to the device. (6ms)
+2175ms ║║Executed [Guest Room Light].setLevel (8ms)
+2176ms ║╚Execution stage complete. (2108ms)
+2177ms ╚Event processed successfully (2177ms)
