I have a simple piston to activate curtains at 9:00AM and at 30 minutes before $nextsunset every day. The 9:00AM action works great, but the $nextsunset one has started executing twice. I wondered if this is because $nextsunset changes after the job is scheduled and because my execution is 30 mins before $nextsunset, the the next job gets scheduled for the same day.
27/12/2017, 15:29:28 +137ms
+0ms ╔Received event [Home].time = 1514388569267 with a delay of -1131ms
+122ms ║RunTime Analysis CS > 19ms > PS > 39ms > PE > 65ms > CE
+124ms ║Runtime (40585 bytes) successfully initialized in 39ms (v0.2.100.20171211) (123ms)
+161ms ║║Executed physical command [Lounge Curtain Motor].off() (21ms)
+162ms ║║Executed [Lounge Curtain Motor].off (22ms)
+169ms ║║Comparison (boolean) true is (boolean) false = false (2ms)
+170ms ║║Condition #30 evaluated false (5ms)
+171ms ║║Condition group #19 evaluated false (state did not change) (6ms)
+181ms ║║Condition #18 evaluated false (6ms)
+182ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+184ms ║╚Execution stage complete. (59ms)
+186ms ║Setting up scheduled job for Thu, Dec 28 2017 @ 9:00:00 AM GMT (in 63031.677s), with 1 more job pending
+192ms ╚Event processed successfully (193ms)
27/12/2017, 15:28:59 +79ms
+0ms ╔Received event [Home].time = 1514388540000 with a delay of -921ms
+121ms ║RunTime Analysis CS > 19ms > PS > 40ms > PE > 62ms > CE
+124ms ║Runtime (40587 bytes) successfully initialized in 40ms (v0.2.100.20171211) (122ms)
+124ms ║╔Execution stage started
+132ms ║║Comparison (time) 55739209 happens_daily_at (time) 32400000 = false (0ms)
+133ms ║║Condition #8 evaluated false (2ms)
+133ms ║║Cancelling statement #8’s schedules…
+136ms ║║Requesting time schedule wake up at Thu, Dec 28 2017 @ 9:00:00 AM GMT
+142ms ║║Comparison (time) 55739217 happens_daily_at (datetime) 1514390340000 = true (0ms)
+143ms ║║Time restriction check passed
+144ms ║║Condition #2 evaluated true (7ms)
+145ms ║║Cancelling statement #2’s schedules…
+149ms ║║Requesting time schedule wake up at Thu, Dec 28 2017 @ 3:29:00 PM GMT
+151ms ║║Condition group #9 evaluated true (state did not change) (20ms)
+151ms ║║Condition group #1 evaluated true (state did not change) (22ms)
+156ms ║║Comparison (boolean) true is (boolean) true = true (1ms)
+157ms ║║Condition #29 evaluated true (4ms)
+158ms ║║Condition group #28 evaluated true (state did not change) (5ms)
+160ms ║║Cancelling statement #4’s schedules…
+183ms ║║Executed physical command [Lounge Curtain Motor].on() (21ms)
+184ms ║║Executed [Lounge Curtain Motor].on (22ms)
+187ms ║║Executed virtual command [Lounge Curtain Motor].wait (0ms)
+187ms ║║Requesting a wake up for Wed, Dec 27 2017 @ 3:29:29 PM GMT (in 30.0s)
+192ms ║╚Execution stage complete. (68ms)
+194ms ║Setting up scheduled job for Wed, Dec 27 2017 @ 3:29:29 PM GMT (in 29.995s), with 2 more jobs pending
+200ms ╚Event processed successfully (200ms)
27/12/2017, 15:28:28 +152ms
+1ms ╔Received event [Home].time = 1514388509433 with a delay of -1281ms
+109ms ║RunTime Analysis CS > 17ms > PS > 30ms > PE > 62ms > CE
+112ms ║Runtime (40585 bytes) successfully initialized in 30ms (v0.2.100.20171211) (110ms)
+148ms ║║Executed physical command [Lounge Curtain Motor].off() (17ms)
+149ms ║║Executed [Lounge Curtain Motor].off (19ms)
+157ms ║║Comparison (boolean) true is (boolean) false = false (1ms)
+159ms ║║Condition #30 evaluated false (6ms)
+160ms ║║Condition group #19 evaluated false (state did not change) (8ms)
+170ms ║║Condition #18 evaluated false (6ms)
+171ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+175ms ║╚Execution stage complete. (62ms)
+177ms ║Setting up scheduled job for Wed, Dec 27 2017 @ 3:29:00 PM GMT (in 31.672s), with 1 more job pending
+183ms ╚Event processed successfully (183ms)
27/12/2017, 15:27:59 +84ms
+1ms ╔Received event [Home].time = 1514388480000 with a delay of -916ms
+106ms ║RunTime Analysis CS > 17ms > PS > 32ms > PE > 57ms > CE
+109ms ║Runtime (40586 bytes) successfully initialized in 32ms (v0.2.100.20171211) (107ms)
+110ms ║╔Execution stage started
+119ms ║║Comparison (time) 55679201 happens_daily_at (time) 32400000 = false (0ms)
+121ms ║║Cancelling condition #8’s schedules…
+121ms ║║Condition #8 evaluated false (4ms)
+122ms ║║Cancelling statement #8’s schedules…
+125ms ║║Requesting time schedule wake up at Thu, Dec 28 2017 @ 9:00:00 AM GMT
+132ms ║║Comparison (time) 55679212 happens_daily_at (datetime) 1514390340000 = true (1ms)
+133ms ║║Time restriction check passed
+134ms ║║Condition #2 evaluated true (7ms)
+135ms ║║Cancelling statement #2’s schedules…
+140ms ║║Requesting time schedule wake up at Wed, Dec 27 2017 @ 3:29:00 PM GMT
+142ms ║║Condition group #9 evaluated true (state did not change) (25ms)
+143ms ║║Condition group #1 evaluated true (state did not change) (27ms)
+150ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+151ms ║║Condition #29 evaluated true (5ms)
+152ms ║║Condition group #28 evaluated true (state did not change) (7ms)
+154ms ║║Cancelling statement #4’s schedules…
+343ms ║║Executed physical command [Lounge Curtain Motor].on() (186ms)
+344ms ║║Executed [Lounge Curtain Motor].on (188ms)
+348ms ║║Executed virtual command [Lounge Curtain Motor].wait (1ms)
+349ms ║║Requesting a wake up for Wed, Dec 27 2017 @ 3:28:29 PM GMT (in 30.0s)
+355ms ║╚Execution stage complete. (246ms)
+357ms ║Setting up scheduled job for Wed, Dec 27 2017 @ 3:28:29 PM GMT (in 29.992s), with 2 more jobs pending
+364ms ╚Event processed successfully (363ms)
27/12/2017, 09:00:28 +132ms
+1ms ╔Received event [Home].time = 1514365229327 with a delay of -1195ms
+118ms ║RunTime Analysis CS > 19ms > PS > 39ms > PE > 59ms > CE
+120ms ║Runtime (40584 bytes) successfully initialized in 39ms (v0.2.100.20171211) (119ms)
+158ms ║║Executed physical command [Lounge Curtain Motor].off() (21ms)
+159ms ║║Executed [Lounge Curtain Motor].off (22ms)
+165ms ║║Comparison (boolean) true is (boolean) false = false (1ms)
+166ms ║║Cancelling condition #30’s schedules…
+167ms ║║Condition #30 evaluated false (6ms)
+168ms ║║Cancelling condition #19’s schedules…
+169ms ║║Condition group #19 evaluated false (state changed) (7ms)
+177ms ║║Condition #18 evaluated false (6ms)
+178ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+181ms ║╚Execution stage complete. (60ms)
+182ms ║Setting up scheduled job for Wed, Dec 27 2017 @ 3:28:00 PM GMT (in 23251.686s), with 1 more job pending
+189ms ╚Event processed successfully (189ms)
27/12/2017, 08:59:59 +100ms
+1ms ╔Received event [Home].time = 1514365200000 with a delay of -900ms
+148ms ║RunTime Analysis CS > 19ms > PS > 47ms > PE > 82ms > CE
+151ms ║Runtime (40590 bytes) successfully initialized in 47ms (v0.2.100.20171211) (149ms)
+152ms ║╔Execution stage started
+164ms ║║Comparison (time) 32399261 happens_daily_at (time) 32400000 = true (1ms)
+166ms ║║Time restriction check passed
+167ms ║║Cancelling condition #8’s schedules…
+169ms ║║Condition #8 evaluated true (7ms)
+170ms ║║Cancelling statement #8’s schedules…
+173ms ║║Requesting time schedule wake up at Thu, Dec 28 2017 @ 9:00:00 AM GMT
+176ms ║║Condition group #9 evaluated true (state did not change) (15ms)
+177ms ║║Condition group #1 evaluated true (state did not change) (17ms)
+184ms ║║Comparison (boolean) true is (boolean) true = true (1ms)
+185ms ║║Cancelling condition #29’s schedules…
+186ms ║║Condition #29 evaluated true (7ms)
+187ms ║║Cancelling condition #28’s schedules…
+188ms ║║Condition group #28 evaluated true (state changed) (9ms)
+190ms ║║Cancelling statement #4’s schedules…
+221ms ║║Executed physical command [Lounge Curtain Motor].on() (26ms)
+222ms ║║Executed [Lounge Curtain Motor].on (28ms)
+226ms ║║Executed virtual command [Lounge Curtain Motor].wait (0ms)
+227ms ║║Requesting a wake up for Wed, Dec 27 2017 @ 9:00:29 AM GMT (in 30.0s)
+233ms ║╚Execution stage complete. (81ms)
+236ms ║Setting up scheduled job for Wed, Dec 27 2017 @ 9:00:29 AM GMT (in 29.992s), with 2 more jobs pending
+242ms ╚Event processed successfully (242ms)
