My wake up piston is designed to start at a fixed time, then turn on one lamp, then at another fixed time turn on another lamp, to give the effect of a smooth sunrise. I do not like the fixed times and want to add a Wait instead, so that when the first lamp turns on, before turning on the other lamp, wait X time. I have tried adding the wait before, but it did not work.
On top of that I have two restrictions (switches), that, when either is on, should stop the piston from running, but it doesn´t work.
When switch 4 or 6 is on, do not run the piston.
Piston runs even though either of the switches are on.
Any help would be appreciated, thanks
