My piston to trigger the air exchanger only when at home works well until my location mode is changed. Then I need to pause and resume to get it updated with the conditions
Smart plug to work 10 minutes each hour, only on specific months, and only when location mode is Home
When location mode changes, I need to pause/resume to make the piston update
14/11/2020 à 07:09:58 +60ms
+0ms ╔Received event [Chalet].time = 1605355799350 with a delay of -1290ms
+116ms ║RunTime Analysis CS > 22ms > PS > 41ms > PE > 53ms > CE
+118ms ║Runtime (37380 bytes) successfully initialized in 41ms (v0.3.110.20191009) (117ms)
+119ms ║╔Execution stage started
+145ms ║║Executed physical command [échangeur air].off() (15ms)
+146ms ║║Executed [échangeur air].off (17ms)
+148ms ║╚Execution stage complete. (29ms)
+150ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 8:00:00 AM EST (in 3001.791s)
+157ms ╚Event processed successfully (157ms)
14/11/2020 à 06:59:59 +48ms
+159ms ╔Received event [Chalet].time = 1605355200000 with a delay of -952ms
+268ms ║RunTime Analysis CS > 177ms > PS > 30ms > PE > 61ms > CE
+270ms ║Runtime (37382 bytes) successfully initialized in 30ms (v0.3.110.20191009) (110ms)
+271ms ║╔Execution stage started
+281ms ║║Cancelling statement #2’s schedules…
+295ms ║║Executed physical command [échangeur air].on() (11ms)
+296ms ║║Executed [échangeur air].on (13ms)
+300ms ║║Executed virtual command [échangeur air].wait (1ms)
+301ms ║║Requesting a wake up for Sat, Nov 14 2020 @ 7:09:59 AM EST (in 600.0s)
+305ms ║╚Execution stage complete. (34ms)
+307ms ║Setting up scheduled job for Sat, Nov 14 2020 @ 7:09:59 AM EST (in 599.996s), with 1 more job pending
+315ms ╚Event processed successfully (315ms)
