Hey guys. I just installed WebCoRE tonight and I plan to start messing aroung with it in the next few days. I have a few fairly complex things I’d like to happen. Hopefully someone can tell me if this is the avenue to make them happen, or if I’m barking up the wrong tree.
Step 1: Ask Alexa to “Turn on Air Hockey.” She then turns on the Smartthings switch, in turn turning on the table itself. She also turns the light over it to red, and the light under it to blue. She also plays Kiss’ version of the Star Spangled Banner on Spotify via a routine I set up. I need an additional switch to be triggered when I say this that will turn on spotlights illuminating an American Flag on my wall. And finally, after the song is over, I’d like the lights to return back to white, maybe typing in the exact time the song takes and then something turns off the flag spotlights, and changes the red and blue lights to white?
I also have another routine programmed similarly where I say: " Turn on black light Air Hockey." As you can imagine she turns the lights purple, turns on the table, and plays “Bangarang” on Spotify. I also need the spotlights to turn on and I’d also like the purple lights to strobe/flash white periodically similar to the Hue Disco app. Then when the song is over have something trigger the spotlights off and the lights to stop strobing/flashing white, but remain purple.
Step 2: Depending on which routine I trigger (normal or blacklight) I’d like 2 multi purpose sensors mounted inside the goals to do similar things, but different colors. For example, if I trigger the normal air hockey routine, when a contact sensor opens, an air horn sound is triggered, the overhead light changes to red (from white) and then when the contact sensor closes, have a “player 2 scored” sound play and have the overhead light change back to white. Obviously have the other contact sensor do similar things but say “player 1 scored” instead. But if the black light air hockey routine is on and the lights are all purple, do the same actions but return the overhead light back to purple instead of white.
I have Alexa, Sonos, Smart things, Hue, and just downloaded WebCoRE and RemindR in the hopes I could at least get the audio notifications of the airhorn and the Player 1 and player 2 scored notifications to work, but was unsuccessful. However, hopefully with some assistance, I could integrate WebCoRE and RemindR and try to get the delay time down and add that to the lighting pistons? Thanks for the help guys!!
