I have Alexa speak setup when someone enters a code on the door. When a code is entered, Alexa says “welcome home {username} and lights turn on. The PROBLEM I am having is if you unlock the door from inside the announcement and lights turn on.
We only want the piston to run when a code is entered from the outside.
Piston is running any way the door is being unlocked. Key, code, and inside dead bolt.
**5) Attach any logs
Log for unlocked from inside:
| 2/19/2019, 10:00:04 PM +664ms | |
| +1ms | ╔Received event [Front Door].lock = unlocked with a delay of 137ms |
| +70ms | ║RunTime Analysis CS > 14ms > PS > 27ms > PE > 28ms > CE |
| +73ms | ║Runtime (41683 bytes) successfully initialized in 27ms (v0.3.109.20181207) (70ms) |
| +74ms | ║╔Execution stage started |
| +86ms | ║║Comparison (enum) unlocked gets (string) unlocked = true (2ms) |
| +88ms | ║║Cancelling condition #7’s schedules… |
| +89ms | ║║Condition #7 evaluated true (8ms) |
| +91ms | ║║Cancelling statement #1’s schedules… |
| +92ms | ║║Condition group #1 made progress up the ladder, currently at step 1 of 1 |
| +93ms | ║║Cancelling statement #1’s schedules… |
| +94ms | ║║Cancelling condition #1’s schedules… |
| +95ms | ║║Condition group #1 evaluated true (state changed) (15ms) |
| +99ms | ║║Condition group #8 evaluated true (state did not change) (0ms) |
| +102ms | ║║Cancelling statement #23’s schedules… |
| +109ms | ║║Executed virtual command setVariable (4ms) |
| +113ms | ║║Evaluating switch with values [[i:11:null:0, v:[t:dynamic, v:null, vt:string]]] |
| +117ms | ║║Comparison (dynamic) null is (integer) 1 = false (2ms) |
| +122ms | ║║Comparison (dynamic) null is (integer) 2 = false (2ms) |
| +126ms | ║║Comparison (dynamic) null is (integer) 3 = false (2ms) |
| +130ms | ║║Cancelling statement #33’s schedules… |
| +252ms | ║║Executed physical command [Chair Light].on() (116ms) |
| +253ms | ║║Executed [Chair Light].on (119ms) |
| +292ms | ║║Executed physical command [Couch Light].on() (36ms) |
| +293ms | ║║Executed [Couch Light].on (38ms) |
| +333ms | ║║Executed physical command [TV Light].on() (37ms) |
| +335ms | ║║Executed [TV Light].on (39ms) |
| +358ms | ║║Executed physical command [TV Twinkles].on() (20ms) |
| +359ms | ║║Executed [TV Twinkles].on (22ms) |
| +363ms | ║║Cancelling statement #28’s schedules… |
| +370ms | ║║Calculating (string) Welcome Home + (string) Brittney >> (string) Welcome Home Brittney |
| +2236ms | ║║Executed physical command [Echo - Living Room].playText([Welcome Home Brittney]) (1858ms) |
| +2237ms | ║║Executed [Echo - Living Room].playText (1861ms) |
| +2240ms | ║║Cancelling statement #2’s schedules… |
| +2247ms | ║║Calculating (string) Front Door unlocked by + (string) Brittney >> (string) Front Door unlocked by Brittney |
| +2253ms | ║║Executed virtual command sendNotification (3ms) |
| +2260ms | ║║Calculating (string) Front Door unlocked by + (string) Brittney >> (string) Front Door unlocked by Brittney |
| +2315ms | ║║Executed virtual command sendSMSNotification (49ms) |
| +2324ms | ║║Comparison (enum) unlocked gets (string) unlocked = false (1ms) |
| +2326ms | ║║Condition #37 evaluated false (7ms) |
| +2327ms | ║║Condition group #36 evaluated false (state did not change) (8ms) |
| +2330ms | ║╚Execution stage complete. (2257ms) |
| +2331ms | ╚Event processed successfully (2331ms |
Unlocked with keypad code:
| 2/19/2019, 5:02:22 PM +670ms | |
| +1ms | ╔Received event [Front Door].lock = unlocked with a delay of 168ms |
| +75ms | ║RunTime Analysis CS > 18ms > PS > 32ms > PE > 26ms > CE |
| +78ms | ║Runtime (41683 bytes) successfully initialized in 32ms (v0.3.109.20181207) (77ms) |
| +79ms | ║╔Execution stage started |
| +93ms | ║║Comparison (enum) unlocked gets (string) unlocked = true (4ms) |
| +95ms | ║║Cancelling condition #7’s schedules… |
| +103ms | ║║Condition #7 evaluated true (17ms) |
| +107ms | ║║Cancelling statement #1’s schedules… |
| +110ms | ║║Condition group #1 made progress up the ladder, currently at step 1 of 1 |
| +111ms | ║║Cancelling statement #1’s schedules… |
| +113ms | ║║Cancelling condition #1’s schedules… |
| +114ms | ║║Condition group #1 evaluated true (state changed) (29ms) |
| +117ms | ║║Condition group #8 evaluated true (state did not change) (1ms) |
| +121ms | ║║Cancelling statement #23’s schedules… |
| +128ms | ║║Executed virtual command setVariable (3ms) |
| +132ms | ║║Evaluating switch with values [[i:11:null:0, v:[t:dynamic, v:2, vt:string]]] |
| +136ms | ║║Comparison (dynamic) 2 is (integer) 1 = false (1ms) |
| +140ms | ║║Comparison (dynamic) 2 is (integer) 2 = true (2ms) |
| +143ms | ║║Cancelling statement #19’s schedules… |
| +150ms | ║║Executed virtual command setVariable (3ms) |
| +156ms | ║║Cancelling statement #33’s schedules… |
| +165ms | ║║Skipped execution of physical command [Chair Light].on([]) because it would make no change to the device. (3ms) |
| +166ms | ║║Executed [Chair Light].on (5ms) |
| +172ms | ║║Skipped execution of physical command [Couch Light].on([]) because it would make no change to the device. (3ms) |
| +174ms | ║║Executed [Couch Light].on (5ms) |
| +180ms | ║║Skipped execution of physical command [TV Light].on([]) because it would make no change to the device. (3ms) |
| +181ms | ║║Executed [TV Light].on (5ms) |
| +187ms | ║║Skipped execution of physical command [TV Twinkles].on([]) because it would make no change to the device. (4ms) |
| +188ms | ║║Executed [TV Twinkles].on (6ms) |
| +191ms | ║║Cancelling statement #28’s schedules… |
| +199ms | ║║Calculating (string) Welcome Home + (string) Brittney >> (string) Welcome Home Brittney |
| +2963ms | ║║Executed physical command [Echo - Living Room].playText([Welcome Home Brittney]) (2757ms) |
| +2964ms | ║║Executed [Echo - Living Room].playText (2759ms) |
| +2967ms | ║║Cancelling statement #2’s schedules… |
| +2975ms | ║║Calculating (string) Front Door unlocked by + (string) Brittney >> (string) Front Door unlocked by Brittney |
| +2981ms | ║║Executed virtual command sendNotification (4ms) |
| +2989ms | ║║Calculating (string) Front Door unlocked by + (string) Brittney >> (string) Front Door unlocked by Brittney |
| +3011ms | ║║Executed virtual command sendSMSNotification (16ms) |
| +3020ms | ║║Comparison (enum) unlocked gets (string) unlocked = false (1ms) |
| +3022ms | ║║Condition #37 evaluated false (7ms) |
| +3024ms | ║║Condition group #36 evaluated false (state did not change) (8ms) |
| +3026ms | ║╚Execution stage complete. (2947ms) |
| +3028ms | ╚Event processed successfully (3029ms) |
