Is this the correct way to add data to a fuel stream? The piston seems to be using quite a bit of processor time.
Fuel streams update using minimal processor time.
It works, but I’m looking to see if there is a more efficient way.
Not sure why the bottom of the piston is not showing, but you get the idea.
Let me know if you need this.
