Not sure what is going on but this error seems to randomly popup in the logs and not sure what causes it. It doesn’t seem to effect the operation of the piston and checking the piston itself does not seem to contain anything unusual, such as a device that no longer exists.
An error occurred while executing the event: org.h2.jdbc.JdbcSQLException: Column "device_id" not found [42122-197]
Not sure if you ever found a solution to this, but I’m seeing a similar one on my Hubitat, just shows up for the Webcore app, not a specific pistion:
2020-05-05 09:35:06.903 errororg.h2.jdbc.JdbcSQLException: Column "disabled" not found [42122-197] on line 1659 (api_intf_dashboard_piston_activity)
Similarly, it doesn’t seem to affect anything…
I believe I’m on: v0.3.110.20200210_HE (which I think is aka: v0.3.110.20191009 ? The version strings are getting confusing)
Never found a solution but the errors just stopped on their own. Have no idea what the problem is/was.
I am now on Hubitat using webCoRE - v0.3.110.20200210_HE and haven’t seen any errors lately.
I don’t think this webCoRE forum has much use anymore. Better to ask on the Hubitat forum as you are more likely to get a response.
