piston for when my wife turns up at around 4.30
Announcement Piston help
Gazza
#21
Gazza
#23
i do belive this has worked just need to find the volume for the alexa
| +0ms | âReceived event [My home].time = 1583424980577 with a delay of -485ms |
| +101ms | âRunTime Analysis CS > 36ms > PS > 5ms > PE > 59ms > CE |
| +105ms | âRuntime (58715 bytes) successfully initialized in 5ms (v0.3.110.20191009) (104ms) |
| +107ms | ââExecution stage started |
| +126ms | ââExecuted physical command [IKEA TRĂ DFRI LED Bulb porch].setLevel([40]) (14ms) |
| +128ms | ââFast executing schedules, waiting for 457ms to sync up |
| +599ms | ââExecuted physical command [IKEA TRĂ DFRI LED Bulb porch].setLevel([40]) (11ms) |
| +659ms | ââExecuted physical command [IKEA TRĂ DFRI LED Bulb porch].off() (16ms) |
| +660ms | ââExecuted [IKEA TRĂ DFRI LED Bulb porch].off (18ms) |
| +665ms | ââCancelling statement #52âs schedules⌠|
| +681ms | ââExecuted virtual command [Echo - Living room Echo].setVariable (3ms) |
| +702ms | ââCalculating (integer) 4 - (integer) -1 >> (integer) 5 |
| +706ms | ââCalculating (integer) 5 - (integer) 2 >> (integer) 3 |
| +714ms | ââCalculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and |
| +719ms | ââCalculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) isa >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and isa |
| +723ms | ââCalculating (integer) -1 > (integer) 0 >> (boolean) false |
| +729ms | ââExecuted virtual command [Echo - Living room Echo].setVariable (3ms) |
| +750ms | ââCalculating (integer) 4 - (integer) -1 >> (integer) 5 |
| +753ms | ââCalculating (integer) 5 - (integer) 2 >> (integer) 3 |
| +762ms | ââCalculating (integer) 1 == (integer) 1 >> (boolean) true |
| +773ms | ââCalculating (integer) 1 == (integer) 1 >> (boolean) true |
| +780ms | ââCalculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 + (string) and >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and |
| +785ms | ââCalculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and + (string) isa >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and isa |
| +790ms | ââCalculating (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and isa + (string) are >> (string) java.lang.StringIndexOutOfBoundsException: String index out of range: -1 and isa are |
| +795ms | ââCalculating (string) Lisa + (string) is >> (string) Lisa is |
| +799ms | ââCalculating (integer) -1 > (integer) 0 >> (boolean) false |
| +805ms | ââExecuted virtual command [Echo - Living room Echo].setVariable (3ms) |
| +816ms | ââCalculating (integer) 1 == (integer) 1 >> (boolean) true |
| +821ms | ââCalculating (string) Lisa is + (string) now at home. >> (string) Lisa is now at home. |
| +827ms | ââExecuted virtual command [Echo - Living room Echo].setVariable (4ms) |
| +842ms | ââCalculating (integer) 1 == (integer) 1 >> (boolean) true |
| +856ms | ââCalculating (integer) 1 == (integer) 2 >> (boolean) false |
| +863ms | ââCalculating (string) Nice you see you + (string) Lisa >> (string) Nice you see you Lisa |
| +867ms | ââCalculating (string) Nice you see you Lisa + (string) , >> (string) Nice you see you Lisa, |
| +872ms | ââCalculating (string) Nice you see you Lisa, + (string) Lisa is >> (string) Nice you see you Lisa, Lisa is |
| +875ms | ââCalculating (string) Nice you see you Lisa, Lisa is + (string) here. >> (string) Nice you see you Lisa, Lisa is here. |
| +881ms | ââExecuted virtual command [Echo - Living room Echo].setVariable (3ms) |
| +920ms | ââExecuted virtual command [Echo - Living room Echo].sendPushNotification (35ms) |
| +933ms | ââComparison (time) 58581015 is_between (time) 50400000 ⌠(time) 55800000 = false (8ms) |
| +936ms | ââCancelling condition #75âs schedules⌠|
| +937ms | ââCondition #75 evaluated false (14ms) |
| +938ms | ââCancelling condition #74âs schedules⌠|
| +939ms | ââCondition group #74 evaluated false (state changed) (17ms) |
| +942ms | ââCancelling statement #76âs schedules⌠|
| +947ms | ââExecuted virtual command setVariable (3ms) |
| +953ms | ââExecuted virtual command setVariable (3ms) |
| +958ms | ââExecution stage complete. (852ms) |
| +960ms | âSetting up scheduled job for Fri, Mar 6 2020 @ 4:12:56 PM GMT (in 86195.369s) |
| +979ms | âEvent processed successfully (979ms) |
Gazza
#24
i`ve added your modified piston and ill run it tonight before im at work and let you know the outcome later
thank you so much for helping me so far i really appreciate it
