Hey, have been using webcore for a little while, so I get a few things, but still.
Im looking for a nice thermostat piston.
Anyone willing to share something with similar features as I need:
Pause or stop thermostat (in my case a Philips heat pump with sensibo), if a certain door is open.
Heat when outside temperature is low, and cooling if outside hot (maybe use Netatmo device?).
And maybe if there’s some real tech AI stuff which base temperatures based on outside temp and humidity.
I want to have 23 degrees in the winter with heat and 20 degrees in summer with cold.
Let me know if you can help, I would gladly give a donation through PayPal, I just need it done before wifey kills me
