I’d recommend using using IFTTT maker but then it will need to be on WAN and you already have that working.
I’m surprised digest works on WC over WAN… my understanding was that it shouldn’t work for LAN or WAN.
Out of interest, what commands are you trying to send to your camera?
Is it something Blue Iris can be the middle man for?
@Robin sorry for not responding sooner. Apparently new users on this forum are limited to the number of replies that can be made each day. So I was forced to wait.
So far I’m sending commands to the camera to enable/disable video recording, enable/disable motion detection, start/stop a tour, and go to a preset. I’m also querying the alarm status so I can determine if the camera has detected motion.
Yes, even before starting this recent effort of integrating the camera with SmartThings, when I first got the camera I was considering Blue Iris. However, for a couple of reasons I haven’t gone that route yet. First, I didn’t want to pay for a program I wasn’t sure I needed. (And, yes, I know they have a free version, but… There’s also other options like tinyCam, Amcrest’s apps & cloud, etc. so I needed the dust to settle a little before deciding.) Second, I’ve been an embedded software developer for over forty years and I haven’t done anything like this, so I’m also using this as a learning exercise.
@ady624 @ipaterson I don’t know if you’ve had time to follow this discussion, but I was wondering if you know why when using an internal (i.e., 192.168.x.x) address in WC’s web request action it doesn’t support digest authentication (which is required by the target of this request), but when using an external address (and without changing anything else about the request) it does properly negotiate with the target and use digest authentication? Or more importantly, can using an internal address be fixed/enhanced to properly negotiate and use digest authentication? If it helps, I can provide any logs, details or wireshark captures you might want.
Here is an example of negotiating Digest authentication with LAN requests using HubAction. It is possible if anyone wants to take on the challenge. The example is 3 years old now and the author indicated that at the time it was not possible to run more than one local request per minute, so there may still be some limitations.
This is not something I feel I could take on. I’m just too inexperienced in writing code for ST.
Should I add a new topic for this under Meta / Feature Suggestions?
BTW, I tend to agree with the comments in the ST forum topic I referenced above, and that is that the ST framework should add support for digest authentication. I.e., take the burden off the DTH or SmartApp. But that’s just my 2 cents.
Yep! Web requests and array variables are two areas that I hope to spend some time in once I start working on features, there should be a tag you can apply to the feature suggestion for web requests to make it easy to find later.
I created the feature request:
FWIW, I didn’t see a web request or todo tag. Can I just input a new tag, or can I only select from the options that come up?
@Robin… did this ever get figured out? I’m trying to have WebCore send an http or https command to my Blue Iris server. I want to trigger a camera to record when a Smartthings motion sensor “sees” motion. I’ve tried a lot of things but nothing is working. Thanks!
Here are example commands that work from a web browser on my LAN.
https://192.168.1.16:8344/admin?camera=Driveway_Clone&trigger&user=username&pw=password
http://192.168.1.16:8347/admin?camera=Driveway_Clone&trigger&user=username&pw=password
