Im trying to send commands to assistant relay , however ever this is proving to be an issue.
The cast command works and mute 100% of the time , the stop and unmute only seems to work if i put a 10 second delay any longer and the command never reaches assistant relay.
If i manually run the commands via assistant relay they all work 100% so its not a issue between assistant relay and google assistant.
