Assistant relay works from webcore(ST) but not from webcore (Hubitat)
Broadcast to assistant relay
Not broadcasting. Pushmessage goes through… so only the AR part is not working.
28.1.2021 klo 22.01.14 +222ms +47ms ╔Received event [HubitatHome].wc_async_reply = httpRequest with a delay of 91ms, canQueue: false, calledMyself: true +51ms ║RunTime initialize > 50 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 48 48 2) +53ms ║Runtime (6573 bytes) successfully initialized in 1ms (v0.3.110.20210123_HE) +56ms ║╔Execution stage started +64ms ║╚Execution stage complete. (7ms) +96ms ╚Event processed successfully (95ms) 28.1.2021 klo 22.01.14 +23ms +2ms ╔Received event [Presence_vswitch].presence = not present with a delay of 29ms, canQueue: true, calledMyself: false +15ms ║RunTime initialize > 14 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 12 4 10) +17ms ║Runtime (6567 bytes) successfully initialized in 1ms (v0.3.110.20210123_HE) +19ms ║╔Execution stage started +26ms ║║Comparison (enum) not present changes_to (string) not present = true (1ms) +28ms ║║Cancelling condition #45's schedules... +30ms ║║Condition #45 evaluated true (7ms) +31ms ║║Cancelling condition #26's schedules... +33ms ║║Condition group #26 evaluated true (state changed) (11ms) +34ms ║║Cancelling statement #35's schedules... +61ms ║║Executed virtual command sendPushNotification (22ms) +68ms ║║Executed virtual command setVariable (3ms) +79ms ║║Sending asynchttpPost web request to: 192.168.86.30:3000/assistant +81ms ║║Executed virtual command httpRequest (6ms) +83ms ║║Requesting a wake up for Thu, Jan 28 2021 @ 10:01:38 PM EET (in 24s) +90ms ║╚Execution stage complete. (71ms) +110ms ║Setting up scheduled job for Thu, Jan 28 2021 @ 10:01:38 PM EET (in 24s) +112ms ╚Event processed successfully (112ms) 28.1.2021 klo 22.01.14 +132ms +3ms ╔Received event [HubitatHome].wc_async_reply = httpRequest with a delay of 1ms, canQueue: true, calledMyself: false +7ms ╚Event queued (7ms) 28.1.2021 klo 22.01.07 +666ms +2ms ╔Received event [Presence_vswitch].presence = present with a delay of 36ms, canQueue: true, calledMyself: false +28ms ║RunTime initialize > 27 LockT > 1ms > rtDT > 19ms > pistonT > 18ms (first state access 7 4 23) +31ms ║Runtime (6648 bytes) successfully initialized in 19ms (v0.3.110.20210123_HE) +32ms ║╔Execution stage started +40ms ║║Comparison (enum) present changes_to (string) not present = false (0ms) +42ms ║║Condition #45 evaluated false (6ms) +44ms ║║Condition group #26 evaluated false (state did not change) (7ms) +48ms ║╚Execution stage complete. (16ms) +51ms ╚Event processed successfully (50ms) 28.1.2021 klo 22.00.16 +908ms +13ms ╔Subscribing to devices... +16ms ║Using Attribute subscription +212ms ║Device missing from piston. Loading all from parent (193ms) +219ms ║Subscribing to Presence_vswitch.presence... +244ms ╚Finished subscribing (236ms) +262ms ╔Starting piston... (v0.3.110.20210123_HE) +264ms ╚Piston successfully started (256ms)
Thank you!
