I’m having issues with a piston with async sentences and I have created a small test piston to show the issue. Basically I included 2 async sentences, and for some reason the second one is not executed.
Both async sentences should be executed and the value of variable valor should be 3 instead of 7
Just the first async sentence is executed so the value of the variable valor is 7 after the execution
(UPLOAD YOUR IMAGE HERE)
26/12/2019, 15:42:18 +88ms
+1ms ╔Received event [Inicio].time = 1577371338221 with a delay of -133ms
+116ms ║RunTime Analysis CS > 37ms > PS > 39ms > PE > 40ms > CE
+119ms ║Runtime (37641 bytes) successfully initialized in 39ms (v0.3.110.20191009) (118ms)
+135ms ║║Executed virtual command setVariable (2ms)
+138ms ║╚Execution stage complete. (18ms)
+139ms ╚Event processed successfully (139ms)
26/12/2019, 15:42:14 +61ms
+1ms ╔Received event [Inicio].time = 1577371335273 with a delay of -1212ms
+130ms ║RunTime Analysis CS > 35ms > PS > 65ms > PE > 30ms > CE
+132ms ║Runtime (37642 bytes) successfully initialized in 65ms (v0.3.110.20191009) (130ms)
+133ms ║╔Execution stage started
+142ms ║║Executed virtual command setVariable (2ms)
+144ms ║║Cancelling statement #4’s schedules…
+148ms ║║Executed virtual command waitRandom (1ms)
+149ms ║║Requesting a wake up for Thu, Dec 26 2019 @ 2:42:18 PM GMT (in 4.01s)
+152ms ║╚Execution stage complete. (19ms)
+154ms ║Setting up scheduled job for Thu, Dec 26 2019 @ 2:42:18 PM GMT (in 4.007s)
+162ms ╚Event processed successfully (162ms)
26/12/2019, 15:42:10 +177ms
+0ms ╔Received event [Inicio].test = 1577371330176 with a delay of 1ms
+80ms ║RunTime Analysis CS > 12ms > PS > 37ms > PE > 31ms > CE
+83ms ║Runtime (37637 bytes) successfully initialized in 37ms (v0.3.110.20191009) (81ms)
+88ms ║║Cancelling statement #1’s schedules…
+94ms ║║Executed virtual command wait (0ms)
+95ms ║║Requesting a wake up for Thu, Dec 26 2019 @ 2:42:15 PM GMT (in 5.0s)
+109ms ║╚Execution stage complete. (25ms)
+115ms ║Setting up scheduled job for Thu, Dec 26 2019 @ 2:42:15 PM GMT (in 4.982s)
+123ms ╚Event processed successfully (123ms)
