I have a Yale Lock and a Open/Close contact. I’d like a piston that automatically locks the door X minutes after the last time the door is opened OR X minutes after the door is unlocked but not opened. We’ll use 15 for now.
Door is unlocked, I open and close the door. Once door is closed, 15 minute timer starts. Door locks. OR I unlock, open and close door. After 3 minutes, I open and close door again…15 minutes after that the door locks
Door is locking 15 minutes after the first open/close
(For the Log/Test, I set the time to 1 minute instead of 15). I unlocked the door, opened it, closed it, then opened it again 30 seconds after I unlocked it. I would expect/want the condition to cancel and restart the timer and then lock 1 minute later
9/15/2021, 8:22:47 AM +572ms
+5ms ╔Received event [Front Door Lock].lock = locked with a delay of 29ms, canQueue: true, calledMyself: false
+16ms ║RunTime initialize > 15 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 13 6 9)
+19ms ║Runtime (8915 bytes) successfully initialized in 1ms (v0.3.113.20210703_HE)
+20ms ║╔Execution stage started
+27ms ║║Comparison (enum) locked changes = true (0ms)
+28ms ║║Condition #6 evaluated true (5ms)
+29ms ║║Condition group #5 evaluated true (state did not change) (7ms)
+36ms ║║Comparison (enum) locked is (string) locked = true (1ms)
+37ms ║║Cancelling condition #9's schedules...
+38ms ║║Condition #9 evaluated true (8ms)
+40ms ║║Cancelling condition #8's schedules...
+41ms ║║Condition group #8 evaluated true (state changed) (10ms)
+42ms ║║Cancelling statement #10's schedules...
+48ms ║║Executed virtual command setVariable (2ms)
+57ms ║║Comparison (boolean) false stays (boolean) true = false (2ms)
+60ms ║║Cancelling any timed trigger schedule stays result false cancel timers for condition 23
+60ms ║║Cancelling statement #23's schedules...
+61ms ║║Cancelling condition #23's schedules...
+62ms ║║Condition #23 evaluated false (12ms)
+63ms ║║Cancelling condition #22's schedules...
+65ms ║║Condition group #22 evaluated false (state changed) (14ms)
+69ms ║╚Execution stage complete. (49ms)
+71ms ╚Event processed successfully (68ms)
9/15/2021, 8:22:44 AM +254ms
+7ms ╔Received event [10628].time = 1631708564175 with a delay of 79ms, canQueue: true, calledMyself: false
+20ms ║RunTime initialize > 19 LockT > 1ms > rtDT > 2ms > pistonT > 1ms (first state access 16 8 11)
+23ms ║Runtime (8927 bytes) successfully initialized in 2ms (v0.3.113.20210703_HE)
+29ms ║╔Execution stage started
+42ms ║║Cancelling condition #23's schedules...
+43ms ║║Condition #23 evaluated true (2ms)
+44ms ║║Cancelling condition #22's schedules...
+46ms ║║Condition group #22 evaluated true (state changed) (5ms)
+47ms ║║Cancelling statement #24's schedules...
+91ms ║║Executed physical command [Front Door Lock].lock() (29ms)
+92ms ║║Executed [Front Door Lock].lock (41ms)
+98ms ║╚Execution stage complete. (68ms)
+102ms ╚Event processed successfully (98ms)
9/15/2021, 8:21:43 AM +958ms
+4ms ╔Received event [Front Door Lock].lock = unlocked with a delay of 35ms, canQueue: true, calledMyself: false
+134ms ║RunTime initialize > 133 LockT > 1ms > rtDT > 121ms > pistonT > 120ms (first state access 11 5 128)
+137ms ║Runtime (8879 bytes) successfully initialized in 121ms (v0.3.113.20210703_HE)
+138ms ║╔Execution stage started
+147ms ║║Comparison (enum) unlocked changes = true (1ms)
+148ms ║║Cancelling condition #6's schedules...
+150ms ║║Condition #6 evaluated true (7ms)
+151ms ║║Cancelling condition #5's schedules...
+152ms ║║Condition group #5 evaluated true (state changed) (10ms)
+160ms ║║Comparison (enum) unlocked is (string) locked = false (2ms)
+162ms ║║Cancelling condition #9's schedules...
+164ms ║║Condition #9 evaluated false (9ms)
+165ms ║║Cancelling condition #8's schedules...
+167ms ║║Condition group #8 evaluated false (state changed) (13ms)
+175ms ║║Comparison (enum) unlocked is (string) unlocked = true (2ms)
+176ms ║║Cancelling condition #14's schedules...
+177ms ║║Condition #14 evaluated true (9ms)
+184ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+185ms ║║Condition #15 evaluated true (7ms)
+187ms ║║Cancelling condition #12's schedules...
+188ms ║║Condition group #12 evaluated true (state changed) (20ms)
+190ms ║║Cancelling statement #16's schedules...
+198ms ║║Executed virtual command setVariable (2ms)
+212ms ║║Comparison (boolean) true stays (boolean) true = true (4ms)
+216ms ║║Adding a timed trigger schedule stays result true scheduling timer for condition 23
+222ms ║║Condition #23 evaluated false (19ms)
+223ms ║║Condition group #22 evaluated false (state did not change) (21ms)
+227ms ║╚Execution stage complete. (89ms)
+246ms ║Setting up scheduled job for Wed, Sep 15 2021 @ 8:22:44 AM EDT (in 60015ms)
+248ms ╚Event processed successfully (245ms)
I guess I need to add more logging…
