Let me first say that I’ve done plenty of searching before reluctantly asking what may be a dumb question. I’ve tried multiple methods to accomplish this task, but nothing seems to work.
I basically want my Yale Assure lock to automatically lock if it is left unlocked (manually unlocked from the interior, for example), but if the contact sensor is or changes to open, to wait until the contact sensor closes again before locking.
Nothing is happening in either piston. If I manually unlock the door from the inside, I can see the piston kick off, but the lock is never re-locked, even if I leave the door closed (sensor stays closed).
Piston #1:
Piston #2:
Piston #1 Log:
5/31/2020, 8:44:03 AM +994ms
+1ms +Received event [Front Door Lock].lock = unlocked with a delay of 130ms
+61ms ¦RunTime Analysis CS > 13ms > PS > 31ms > PE > 16ms > CE
+63ms ¦Runtime (39466 bytes) successfully initialized in 31ms (v0.3.110.20191009) (62ms)
+64ms ¦+Execution stage started
+72ms ¦¦Comparison (enum) unlocked changes_to_any_of (string) unknown,unlocked,unlocked with timeout = true (2ms)
+73ms ¦¦Cancelling condition #28's schedules...
+74ms ¦¦Condition #28 evaluated true (7ms)
+81ms ¦¦Comparison (enum) closed is (string) closed = true (1ms)
+82ms ¦¦Condition #39 evaluated true (7ms)
+83ms ¦¦Cancelling condition #27's schedules...
+84ms ¦¦Condition group #27 evaluated true (state changed) (17ms)
+86ms ¦¦Cancelling statement #29's schedules...
+91ms ¦¦Executed virtual command [Front Door Lock].wait (1ms)
+92ms ¦¦Requesting a wake up for Sun, May 31 2020 @ 8:44:09 AM EDT (in 5.0s)
+96ms ¦+Execution stage complete. (33ms)
+97ms ¦Setting up scheduled job for Sun, May 31 2020 @ 8:44:09 AM EDT (in 4.997s)
+104ms +Event processed successfully (104ms)
5/31/2020, 8:43:41 AM +505ms
+1ms +Starting piston... (v0.3.110.20191009)
+96ms ¦+Subscribing to devices...
+113ms ¦¦Subscribing to Front Door Sensor.contact...
+122ms ¦¦Subscribing to Front Door Lock.lock...
+168ms ¦+Finished subscribing (74ms)
+191ms ¦Cancelling condition #28's schedules...
+199ms ¦Comparison (enum) closed is (string) closed = true (1ms)
+202ms ¦Cancelling condition #27's schedules...
+218ms ¦Comparison (enum) closed is (string) open = false (1ms)
+236ms +Piston successfully started (235ms)
Piston #2 Log:
5/31/2020, 8:46:46 AM +271ms
+2ms +Received event [Front Door Lock].lock = unlocked with a delay of 392ms
+97ms ¦RunTime Analysis CS > 22ms > PS > 55ms > PE > 19ms > CE
+99ms ¦Runtime (39440 bytes) successfully initialized in 55ms (v0.3.110.20191009) (96ms)
+100ms ¦+Execution stage started
+108ms ¦¦Comparison (enum) unlocked changes_to_any_of (string) unlocked,unlocked with timeout = true (2ms)
+109ms ¦¦Cancelling condition #28's schedules...
+110ms ¦¦Condition #28 evaluated true (6ms)
+118ms ¦¦Comparison (enum) closed is_any_of (string) closed = true (1ms)
+119ms ¦¦Condition #29 evaluated true (8ms)
+120ms ¦¦Cancelling condition #27's schedules...
+121ms ¦¦Condition group #27 evaluated true (state changed) (17ms)
+123ms ¦¦Cancelling statement #30's schedules...
+129ms ¦¦Executed virtual command [Front Door Lock].wait (1ms)
+130ms ¦¦Requesting a wake up for Sun, May 31 2020 @ 8:46:51 AM EDT (in 5.0s)
+134ms ¦+Execution stage complete. (34ms)
+135ms ¦Setting up scheduled job for Sun, May 31 2020 @ 8:46:51 AM EDT (in 4.996s)
+145ms +Event processed successfully (144ms)
I don’t know if it helps, but I’m basically just trying to replicate my old CoRE piston that worked up until recently (no idea what changed, other than SmartThings iOS updates). Here’s the basic workflow of it:
If Front Door Lock changes to unlocked
AND
Front Door Sensor contact is closed
THEN
Using Front Door Lock:
-Wait 5 minutes
-Lock
-Cancel on condition or piston state change
BUT IF
Front Door Sensor contact changes to open
When true:
-using Front Door Lock:
-Cancel all pending Local tasks
FOLLOWED BY
Front Door Sensor contact changes to closed
THEN
-Wait 5 minutes
-Lock
Any help would be immensely appreciated, as I’m trying to get the hang of webCoRE and replace other CoRE pistons with it.
