I fused my piston with a couple others example pistons and its kind of working but im not sure how to fix it.
The idea is that when theres motion the lights turn on, when the motion stops with a delay the lights go off. If the switch is pressed, it overrides motion and the lights stay on until the switch is pressed again(kids bath time), and if the door is closed the lights stay on until the door is opened. The brightness is set from a global variable, and that part works great.
The manual override isnt keeping the lights on.
*4) Post a Green Snapshot of the piston![image|45xI 37]
