(PUT YOUR INFO HERE)
I have a piston which contains a boolean value JustGotHome in order to create different behaviors just after someone arrives home. I believe the value is getting stuck in ‘true’ mode.
I expect the boolean value to reset back to false after 12 minutes.
The value remains true… I do have another Piston which pauses this piston when the door opens – the sequence for that other piston tells my lights out piston with the Boolean value to pause, wait, resume, wait, execute. Is it POSSIBLE that this sequence is causing the Boolean value to act incorrectly, therefore, causing the piston to not work correctly?
(UPLOAD YOUR IMAGE HERE)
