I would like to be able to execute a piston both automatically via timer and manually.
Once a day the piston will run based on timer and also let me manually execute it from other pistons.
The piston works fine using the timing function but I can’t figure out how to enable the agility to call it from another piston and not be stopped due to the timer restrictions.
