I cobbled together a repeat do until statement that isn’t working consistently. #62-#67 is where I’m having problems. It doesn’t consistently set the color.
Keep waiting 3 more minutes until motion sensor 8 is not active, then run statement #66 to set the bulb color
#66 doesn’t run
12/6/2021, 6:00:12 PM +813ms
+0ms ╔Received event [Home].time = 1638835211612 with a delay of 1201ms
+132ms ║RunTime Analysis CS > 57ms > PS > 7ms > PE > 68ms > CE
+135ms ║Runtime (46101 bytes) successfully initialized in 7ms (v0.3.110.20191009) (134ms)
+137ms ║╚Execution stage complete. (1ms)
+138ms ╚Event processed successfully (138ms)
12/6/2021, 5:57:41 PM +593ms
+1ms ╔Received event [Front Door].motion = inactive with a delay of 93ms
+99ms ║RunTime Analysis CS > 18ms > PS > 7ms > PE > 74ms > CE
+101ms ║Runtime (46094 bytes) successfully initialized in 7ms (v0.3.110.20191009) (99ms)
+111ms ║║Comparison (boolean) false is (boolean) false = true (1ms)
+113ms ║║Condition #49 evaluated true (5ms)
+122ms ║║Comparison (enum) on is (string) on = true (1ms)
+123ms ║║Condition #80 evaluated true (10ms)
+127ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+129ms ║║Cancelling condition #2's schedules...
+129ms ║║Condition #2 evaluated false (5ms)
+130ms ║║Cancelling condition #1's schedules...
+131ms ║║Condition group #1 evaluated false (state changed) (25ms)
+138ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+140ms ║║Condition #71 evaluated false (6ms)
+141ms ║║Condition group #68 evaluated false (state did not change) (8ms)
+143ms ║╚Execution stage complete. (41ms)
+144ms ╚Event processed successfully (144ms)
12/6/2021, 5:57:11 PM +436ms
+1ms ╔Received event [Front Door].motion = active with a delay of 88ms
+94ms ║RunTime Analysis CS > 21ms > PS > 7ms > PE > 65ms > CE
+96ms ║Runtime (46099 bytes) successfully initialized in 7ms (v0.3.110.20191009) (94ms)
+107ms ║║Comparison (boolean) false is (boolean) false = true (2ms)
+108ms ║║Condition #49 evaluated true (6ms)
+118ms ║║Comparison (enum) on is (string) on = true (1ms)
+120ms ║║Condition #80 evaluated true (11ms)
+124ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+125ms ║║Cancelling condition #2's schedules...
+126ms ║║Condition #2 evaluated true (5ms)
+134ms ║║Comparison (enum) off is (string) off = true (1ms)
+136ms ║║Condition #48 evaluated true (8ms)
+137ms ║║Cancelling condition #1's schedules...
+138ms ║║Condition group #1 evaluated true (state changed) (36ms)
+140ms ║║Cancelling statement #26's schedules...
+152ms ║║Executed physical command [Front Porch sengled].setColorTemperature([2700]) (7ms)
+153ms ║║Executed [Front Porch sengled].setColorTemperature (8ms)
+165ms ║║Skipped execution of physical command [Front Porch sengled].setLevel([100]) because it would make no change to the device. (9ms)
+166ms ║║Executed [Front Porch sengled].setLevel (11ms)
+170ms ║║Cancelling statement #64's schedules...
+173ms ║║Executed virtual command wait (0ms)
+175ms ║║Requesting a wake up for Mon, Dec 6 2021 @ 6:00:11 PM CST (in 180.0s)
+180ms ║╚Execution stage complete. (82ms)
+181ms ║Setting up scheduled job for Mon, Dec 6 2021 @ 6:00:11 PM CST (in 179.996s)
+189ms ╚Event processed successfully (189ms)
12/6/2021, 5:44:08 PM +442ms
+0ms ╔Starting piston... (v0.3.110.20191009)
+365ms ║╔Subscribing to devices...
+428ms ║║Subscribing to Front Door.motion...
+588ms ║║Subscribing to Front Porch sengled...
+589ms ║╚Finished subscribing (243ms)
+621ms ║Comparison (boolean) false is (boolean) false = true (2ms)
+632ms ║Comparison (enum) on is (string) on = true (2ms)
+659ms ║Comparison (enum) off is (string) off = true (2ms)
+687ms ║Comparison (enum) inactive is_not (string) active = true (2ms)
+700ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+710ms ║Comparison (enum) on is (string) on = true (1ms)
+711ms ║Cancelling condition #81's schedules...
+733ms ║Comparison (enum) off is (string) off = true (2ms)
+759ms ║Comparison (enum) inactive is_not (string) active = true (2ms)
+772ms ╚Piston successfully started (772ms)
12/6/2021, 5:43:10 PM +728ms
+1ms ╔Received event [Home].test = 1638834190728 with a delay of 0ms
+92ms ║RunTime Analysis CS > 19ms > PS > 7ms > PE > 66ms > CE
+95ms ║Runtime (46097 bytes) successfully initialized in 7ms (v0.3.110.20191009) (93ms)
+108ms ║║Comparison (boolean) false is (boolean) false = true (1ms)
+109ms ║║Condition #49 evaluated true (7ms)
+119ms ║║Comparison (enum) on is (string) on = true (1ms)
+121ms ║║Condition #80 evaluated true (11ms)
+140ms ║║Condition #2 evaluated false (18ms)
+141ms ║║Condition group #1 evaluated false (state did not change) (40ms)
+150ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+151ms ║║Condition #71 evaluated false (7ms)
+153ms ║║Condition group #68 evaluated false (state did not change) (8ms)
+157ms ║╚Execution stage complete. (61ms)
+158ms ╚Event processed successfully (158ms)
