I have a piston set up to manage my home theater lights. The piston is supposed to turn off certain lights and dim others when a button is pressed (entering movieMode ). When the button is pressed again, it should revert the lights to their original state (exiting movieMode ). However, the piston is not maintaining the movieMode state between button presses and instead, it seems to reverse the actions immediately after setting them.
Upon a single press of the button, the piston should:
- Turn off specific lights (e.g., A, B, C).
- Dim one light to 25% (e.g., Y).
- Set a
movieModevariable totrue. When the button is pressed again, the piston should: - Turn the specific lights back on.
- Restore light Y to its original brightness.
- Set the
movieModevariable tofalse.
The issue is that the lights do not stay in the ‘movieMode’ configuration. Instead, they immediately revert to their original state after the piston actions are executed, as if the commands to enter movieMode are being immediately followed by the commands to exit movieMode .
Equally strange is that while the piston does take action (turns the lights off and then back on again) the piston doesn’t show any logs recognizing the button press.
4) Post a Green Snapshot of the piston !
11/20/2023, 10:07:52 AM +457ms
+8ms ╔Starting piston... (v0.3.114.20230828_HE)
+21ms ║╔Subscribing to devices...
+218ms ║║Device missing from piston. Loading all from parent (195ms)
+220ms ║║Attempting Attribute pushed value [1] subscription for device: Basement Button
+238ms ║║Attempting Attribute doubleTapped value [1] subscription for device: Basement Button
+241ms ║║Subscribing to Basement Button.pushed.1...
+262ms ║║subscribe override: always @movieMode
+263ms ║║Subscribing to Westerfield.:4ec393bf4a47293be18551df1035ea85:.@movieMode...
+273ms ║║Subscribing to Basement Button.doubleTapped.1...
+281ms ║║Piston utilizes Basement Kitchen Downlights []...
+282ms ║║Piston utilizes Basement Office Desk Signe Light []...
+282ms ║║Piston utilizes Basement Office Downlights []...
+283ms ║║Piston utilizes Basement Office Lamp []...
+284ms ║║Piston utilizes Family Room Downlight 1 []...
+285ms ║║Piston utilizes Family Room Downlight 2 []...
+286ms ║║Piston utilizes Family Room Downlight 3 []...
+286ms ║║Piston utilizes Family Room Downlight 4 []...
+287ms ║║Piston utilizes Family Room Downlight 5 []...
+288ms ║║Piston utilizes Background Light []...
+289ms ║║Piston utilizes Fish Tank Lights []...
+316ms ║╚Finished subscribing (306ms)
+322ms ║Subscribing to Westerfield.pistonID...(:521f8aa9793e240f4eaae1b7849a778f:)
+329ms ║Subscribing to Westerfield.oldpistonID...(:a3e9d684b343479eb2e8153dd3efa937:)
+336ms ║Comparison gets = false (event device/attr eXcluded)
+340ms ║Comparison (dynamic) false is (boolean) false = true (2ms)
+349ms ║Comparison gets = false (event device/attr eXcluded)
+370ms ╚Piston started (361ms)
