Piston created to Turn on these lights (if they are off) or Turn off these lights (if they are on). Pushed uses a set of ‘these lights’, and Held uses ‘those lights’.
Both ‘Pushed’ and ‘Held’ are triggering at the same time. If I ‘Push’ the button ‘these lights’ turn off…and ‘those lights’ turn on. It is supposed to be: If I ‘Push’ the button, only ‘these lights’ should respond. If I ‘Hold’ the button, only ‘those lights’ should respond. Instead, If I ‘Push’ or ‘Hold’, both sets of lights (‘these lights’ and ‘those lights’) are responding. (hope that makes sense).
