The real temp of a room based on multiple temps
To come up with a “Virtual” temp
So I can come up with a piston and put the value into a variable and create a simulated device to hold the temp no problem. What I want to know is what you really want is the average? Let’s say I have 5 temp sensors in a room. Do I really want to average them. Let’s say that you have a sensor that the battery dies, and you missed it, and the last temp was out of the norm do you really want to use that temp or throw it out. Or do you really want to create a standard deviation and if the sensor falls outside of that you throw it out and what would that look like in an equation. OR is there a better way to do it. For you math junkies what is the real way to create the temp based on 5 sensors. Throw out the low and high and average?
