This seems like it should be simple, and I’m sure I’m missing something obvious, but I have searched for 20 minutes and can’t find an answer. I cannot get my piston to execute another piston.
I have 2 locations and I want to lock a door on one location when the mode is set to Away on the other location (or I run a scene).
I’ve tested the piston to lock the door. It works fine. This is in the location Garage.
execute
with
Garage Side Door
do
Lock;
end with;
end execute;
But when I call it from another piston on the other location, nothing happens.
execute
if
{$locationMode} changes to ‘Away’
then
Execute piston “Garage \ webCoRE1 \ GarageGoodnight”;
end if;
end execute;
Even if I strip out the condition and just run the execute piston statement, it doesn’t work.
execute
end execute;
No logs are being generated. Do I need to set a variable or something? Appreciate the help.
