Is it possible to set a global variable with a url? For example. @coomonsite = http://google.com?
Can you save a URL to a global variable?
Ty. Figured that out…smh. Now let’s take it one further?
@key=123456
@city=newyork
@url=‘http://weatherunderground.com/‘{@key}’/q/‘{@city}
Is that possible? To include variables to make up a complete url?
Tried to do that entering as an expression and it won’t take. Keeps coming up not set
Very close, it would either be this as a value:
@url=http://weatherunderground.com/{@key}/q/{@city}
Or this as an expression (a few of many possible ways):
@url=‘http://weatherunderground.com/{@key}/q/{@city}'
@url=‘http://weatherunderground.com/‘ + @key + ’/q/' + @city
It’s possible that it’s showing not set if you have yet to save the overall piston with new variables for the first time.
Yeah sorry… it looks like it’s not possible to define a global variable in terms of another global. When setting a global with an Expression I always get (not set) and when setting with a Value I just get the raw value http://weatherunderground.com/{@key}/q/{@city} without the key or city substituted in.
If you need to do a lot of this I recommend using string formatting. Set the value of @url to http://weatherunderground.com/%s/q/%s then to use it in a piston use the expression format(@url, @key, @city) which will give you the full URL (read more on format). With this approach I recommend naming the global in a way that helps you remember what values it expects and in which order, like @weatherUrlFormat__key_city.
Also, since your example used Weather Underground… if you are trying to get weather for your home (i.e. the location of your hub) there is an excellent $weather system variable with probably all the data you could want.
This is awesome info, did not know about the format stuff and the string pieces. Will definitely be doing some more research. Thank you.
As far as the precanned $weather. I am aware and yes, it does work Home hub location. Although some of the attributes are limited. Also, I am creating a couple of pistons to do the following, push weather alerts, current conditions and forcast conditions via text message to my phone. In addition to this I have 3 virtual switches set up to choose what city I want the info from. That is why I am actually using the weather underground api instead of the $weather expression.
