Cannot create new piston if auto backup is enabled
I just tried to create a new piston and nothing happened when I clicked Create. Just for grins, I changed Automatic Backup to No and was able to create the piston. I tested this a number of times with the same results. Nothing has changed on my end in many months so I’m assuming this is a server issue on the WC side of things. Not having automatic backups created isn’t a showstopper but I suspect this will impact other uses as well.
I’ve just tried and it’s the same. With auto backup on, the create button doesn’t do anything.
